Configure credentials for VM guest file restores in the SCV
When you attach a virtual disk for guest file or folder restore operations, the target VM for the attach must have credentials configured before you restore.
The following table lists the credential requirements for guest restore operations.
| User access control enabled | User access control disabled | |
Domain user |
A domain user with “administrator” as the username works fine. For example, “NetApp\administrator”. |
Either a domain user with “administrator” as the username or a domain user with “xyz” as the username that belongs to a local administrator group, works fine. For example, “NetApp\administrator” or “NetApp\xyz”. |
Workgroup user |
A local user with “administrator” as the username works fine. |
Either a local user with “administrator” as the username or a local user with “xyz” as the username that belongs to a local administrator group, works fine. |
In the preceding examples, “NetApp” is the dummy domain name and “xyz” is the dummy local username
From the vSphere client shortcuts window, select SnapCenter Plug-in for VMware vSphere under plug-ins.
In the left navigation select Guest File Restore.
In the Run As Credentials section, do one of the following:
To do this… Do this… Use existing credentials
Select any of the configured credentials.
Add new credentials
Select Add.
In the Run As Credentials dialog box, enter the credentials.
For Username, you must enter “Administrator”. -
Select Select VM, then select a VM in the Proxy VM dialog box. Select Save to return to the Run As Credentials dialog box.
Select the VM that should be used to authenticate the credentials.
SnapCenter Plug-in for VMware vSphere uses the selected credentials to log on to the selected VM.
Select Save.
