The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
REST API workflows to mount and unmount datastores in the SCV
To perform mount and unmount operations for datastore backups using the SnapCenter Plug-in for VMware vSphere REST APIs, you must follow the prescribed sequence of REST API calls.
For each REST API, add https://<server>:<port> at the front of the REST API to form a complete endpoint.
To mount datastores, follow this workflow:
| Step |
REST API |
Comments |
1 |
Go to http://<vCenter-IP>/mob |
Find the datastore moref from the VMware Managed Objects URL.
Note the moref for the datastore that you want to mount. |
2 |
/4.1/datastores/{moref}/
backups
Get the list of backups for a datastore gets a list of backups for the specified datastore.
Pass the moref from Step 1.
Note the backupId that you want to mount.
3 |
/4.1/datastores/backups/
{backupId}/snapshotlocators
Get the list of Snapshot Locations gets details about the location of the specified backup.
Pass the backupId from Step 2.
Note the datastore and the location from the snapshotLocationsList list.
4 |
availableEsxHosts
Get the list of Available Esxi Hosts gets the list of ESXi hosts that are available for mount operations.
Note the availableEsxHostsList information.
5 |
{backupId}/mount
Mount datastores for a backup mounts the specified datastore backup.
In the datastore and location attributes, pass the information from snapshotLocationsList in Step 3.
In the esxHostName attribute, pass the information from availableEsxHostsList in Step 4.
To unmount datastores, follow this workflow:
| Step |
REST API |
Comments |
1 |
{backupId}/mounted
Get the list of mounted datastores.
Note the datastore moref(s) that you want to unmount.
2 |
/4.1/datastores/unmount
UnMount datastores for a backup unmounts the specified datastore backup.
Pass the datastore moref(s) from Step 1.
