Search for backups in the SnapCenter Plug-in for VMware vSphere
You can search for and find a specific backup of a VM or datastore using the Restore wizard. After you locate a backup, you can then restore it.
In the VMware vSphere client user interface, select Menu in the toolbar, and then do one of the following:
To view backups for… Do the following… VMs
Select the Hosts and Clusters menu option, then select a VM, then select the Configure tab, and then select Backups in the SnapCenter Plug-in for VMware vSphere section.
Datastores
Select the Storage menu option, then select a datastore, then select the Configure tab, and then select Backups in the SnapCenter Plug-in for VMware vSphere section.
In the left navigator pane, expand the datacenter that contains the VM or datastore.
Optional: Right-click a VM or datastore, then select SnapCenter Plug-in for VMware vSphere in the drop-down list, and then select Restore in the secondary drop-down list.
In the Restore wizard enter a search name and select Search.
You can filter the backup list by selecting the filter icon and selecting a date and time range, selecting whether you want backups that contain VMware snapshots, whether you want mounted backups, and the location. Select OK.
