SnapCenter Plug-in for VMware vSphere 4.9
Search for backups
You can search for and find a specific backup of a VM or datastore using the Restore wizard. After you locate a backup, you can then restore it.
Steps
  1. In the VMware vSphere client GUI, click Menu in the toolbar, and then do one of the following:
    To view backups for… Do the following…
    VMs
    Click the Hosts and Clusters menu option, then select a VM, then click the Configure tab, and then click Backups in the SnapCenter Plug-in for VMware vSphere section.
    Datastores
    Click the Storage menu option, then select a datastore, then click the Configure tab, and then click Backups in the SnapCenter Plug-in for VMware vSphere section.
  2. In the left Navigator pane, expand the datacenter that contains the VM or datastore.
  3. Optional: Right-click a VM or datastore, then select NetApp SnapCenter in the drop-down list, and then select Restore in the secondary drop-down list.
  4. In the Restore wizard enter a search name and click Search.
    You can filter the backup list by selecting the filter icon and selecting a date and time range, selecting whether you want backups that contain VMware Snapshots, whether you want mounted backups, and the location. Click OK.
