Learn about REST APIs in the SnapCenter Plug-in for VMware vSphere
You can use the SnapCenter Plug-in for VMware vSphere REST APIs to perform common data protection operations. The plug-in has different Swagger web pages from the Windows SnapCenter Swagger web pages.
REST API workflows are documented for the following operations on VMs and datastores using the REST APIs for VMware vSphere:
Add, modify, and delete storage VMs and clusters
Create, modify, and delete resource groups
Backup VMs, scheduled and on-demand
Restore existing VMs and deleted VMs
Restore VMDKs
Attach and detach VMDKs
Mount and unmount datastores
Download jobs and generate reports
Modify built-in schedules
Configure secondary protection for ASA r2
Operations that are not supported by the REST APIs for VMware vSphere
Guest file restore
Installation and configuration of the SnapCenter Plug-in for VMware vSphere
Assign RBAC roles or access to users
uriparameterThe
uriparameter always returns a "null" value. -
Login timeout
The default timeout is 120 minutes (2 hours). You can configure a different timeout value in the vCenter settings.
Token management
For security, REST APIs use a mandatory token that is passed with each request and is used in all API calls for client validation. The REST APIs for VMware vSphere use the VMware authentication API to obtain the token. VMware provides the token management.
To obtain the token, use
/4.1/auth/loginREST API and provide the vCenter credentials. -
API version designations
Each REST API name includes the SnapCenter version number in which the REST API was first released. For example, the REST API
/4.1/datastores/{moref}/backupswas first released in SnapCenter 4.1.REST APIs in future releases will usually be backward compatible and will be modified to accommodate new features as needed.
