SnapCenter Plug-in for VMware vSphere 6.2
REST API workflows to add and modify storage VMs in the SCV
Contributors netapp-madhulik netapp-jani ronya
To perform add and modify storage VM operations using the SnapCenter Plug-in for VMware vSphere REST APIs, you must follow the prescribed sequence of REST API calls.
For each REST API, add https://<server>:<port> at the front of the REST API to form a complete endpoint.
To add storage VM operations, follow this workflow:
Step REST API Comments
1
/4.1/storage-system
Add Storage System adds the specified storage VM to SnapCenter Plug-in for VMware vSphere.
To modify storage VM operations, follow this workflow:
1
/4.1/storage-system
getSvmAll gets the list of all available storage VMs.
Note the name of the storage VM that you want to modify.
2
/4.1/storage-system
Modify Storage System modifies the specified storage VM.
Pass the name from Step 1 in addition to all the other required attributes.
