SnapCenter Plug-in for VMware vSphere 6.2
Data protection workflow for the SnapCenter Plug-in for VMware vSphere
Contributors jani netapp-madhulik netapp-jani ronya
Note Enhance VMware protection using NetApp Backup and Recovery, which provides 3-2-1 backup, ransomware protection, automated backup management, improved scalability, reduced costs, and centralized management of multiple vCenter instances. You can migrate SCV policies, snapshots, and schedules to NetApp Backup and Recovery and manage all VM protection from a single console. For more information, refer to NetApp Backup and Recovery documentation.
Use the SnapCenter vSphere client to perform data protection operations for VMs, VMDKs, and datastores. All backup operations are performed on resource groups, which can contain any combination of one or more VMs and datastores. You can back up on demand or according to a defined protection schedule.
When you back up a datastore, you are backing up all the VMs in that datastore.
Backup and restore operations cannot be performed simultaneously on the same resource group.
You should review the information on what the SnapCenter Plug-in for VMware vSphere does and does not support.
Deployment planning and requirements
In MetroCluster configurations:
The following workflow figure shows the sequence in which you must perform backup operations:
Backup operations workflow
