SnapCenter Plug-in for VMware vSphere 6.2
Set up proxy VMs for restore operations in the SCV
Contributors netapp-jani jani netapp-madhulik ronya
If you want to use a proxy VM for attaching a virtual disk for guest file restore operations, you must set up the proxy VM before you begin the restore operation. Although you can set up a proxy VM at any time, it might be more convenient to set it up immediately after the plug-in deployment completes.
Steps
  1. From the vSphere client shortcuts window, select SnapCenter Plug-in for VMware vSphere under plug-ins.
  2. In the left navigation select Guest File Restore.
  3. In the Run As Credentials section, do one of the following:
    To do this… Do this…
    Use existing credentials
    Select any of the configured credentials.
    Add new credentials
    1. Select Add.
    2. In the Run As Credentials dialog box, enter the credentials.
    3. Select Select VM, then select a VM in the Proxy VM dialog box. Select Save to return to the Run As Credentials dialog box.
    4. Enter the credentials.
      For Username, you must enter “Administrator”.
    SnapCenter Plug-in for VMware vSphere uses the selected credentials to log into the selected proxy VM.
    The Run As credentials must be the default domain administrator that is provided by Windows or the built-in local administrator. Workgroup users can use the built-in local administrator account.
  4. In the Proxy Credentials section, select Add to add a VM to use as a proxy.
  5. In the Proxy VM dialog box, complete the information, and then select Save.
Note You need to delete the proxy VM from the SnapCenter Plug-in for VMware vSphere UI before you can delete it from ESXi host.
