SnapCenter Plug-in for VMware vSphere 6.2
Manage resource groups in the SnapCenter Plug-in for VMware vSphere
Contributors netapp-jani jani ronya netapp-madhulik
You can create, modify, and delete backup resource groups, and perform backup operations on resource groups.
Note Resource groups are called backup jobs in Virtual Storage Console (VSC).
Suspend and resume operations on resource groups
Pause scheduled operations on a resource group. Enable them again when needed.
Steps
  1. In the left navigator pane of the SCV plug-in, select Resource Groups, select a resource group and select Suspend (or select Resume).
  2. In the confirmation box, select OK to confirm.
After you finish
On the Resource Groups page, the job status for the suspended resource is Under_Maintenance. You might need to scroll to the right of the table to see the Job Status column.
After backup operations are resumed, the Job Status changes to Production.
Modify resource groups
You can remove or add resources in resource groups in vCenter, detach or attach policies, modify schedules, or modify any other resource group option.
About this task
If you want to modify the name of a resource group, do not use the following special characters in VM, datastore, policy, backup, or resource group names:
% & * $ # @ ! \ / : * ? " < > - | ; ' , and space.
An underscore character (_) is allowed.
Steps
  1. In the left navigator pane of the SCV plug-in, select Resource Groups, then select a resource group and select Edit.
  2. On the left list in the Edit Resource Group wizard, select the category that you want to modify and enter your changes.
    You can make changes in multiple categories. You can also edit secondary protected resources in this option.
  3. Select Next until you see the Summary page, and then select Finish.
Delete resource groups
Delete a resource group in vCenter if you do not need to protect the resources. Delete all resource groups before removing SnapCenter Plug-in for VMware vSphere.
About this task
All resource group delete operations are performed as force deletes. When you delete a resource group, the system detaches all policies from the vCenter resource group, removes the resource group from SnapCenter Plug-in for VMware vSphere, and deletes all backups and snapshots of the resource group.
Note In a SnapVault relationship, you cannot delete the last snapshot, therefore you cannot delete the resource group. Before deleting a resource group in a SnapVault relationship, use System Manager or ONTAP CLI to remove the relationship, then delete the last snapshot.
Steps
  1. In the left navigator pane of the SCV plug-in, select Resource Groups, then select a resource group and select Delete.
  2. In the Delete resource group confirmation dialog, select OK to confirm. Deleting a resource group does not remove secondary protection. If needed, use System Manager to delete secondary protection. Consistency groups created for the resource group are not automatically removed; you must manually delete them from ONTAP using System Manager or another supported interface.
