Manage resource groups
You can create, modify, and delete backup resource groups, and perform backup operations on resource groups.
Resource groups are called backup jobs in Virtual Storage Console (VSC). |
Suspend and resume operations on resource groups
You can temporarily disable scheduled operations from starting on a resource group. Later when you want, you can enable those operations.
In the left Navigator pane of the SCV plug-in, click Resource Groups, then right-click a resource group and click Suspend (or click Resume).
In the confirmation box, click OK to confirm.
On the Resource Groups page, the job status for the suspended resource is Under_Maintenance. You might need to scroll to the right of the table to see the Job Status column.
After backup operations are resumed, the Job Status changes to Production.
Modify resource groups
You can remove or add resources in resource groups in vCenter, detach or attach policies, modify schedules, or modify any other resource group option.
If you want to modify the name of a resource group, do not use the following special characters in VM, datastore, policy, backup, or resource group names:
% & * $ # @ ! \ / : * ? " < > - | ; ' , and space.
An underscore character (_) is allowed.
In the left Navigator pane of the SCV plug-in, click Resource Groups, then select a resource group and click Edit.
On the left list in the Edit Resource Group wizard, click the category that you want to modify and enter your changes.
You can make changes in multiple categories.
Click Next until you see the Summary page, and then click Finish.
Delete resource groups
You can delete a resource group in vCenter if you no longer need to protect the resources in the resource group. You must ensure that all resource groups are deleted before you remove SnapCenter Plug-in for VMware vSphere from vCenter.
All resource group delete operations are performed as force deletes. The delete operation detaches all policies from the vCenter resource group, removes the resource group from SnapCenter Plug-in for VMware vSphere, and deletes all backups and Snapshots of the resource group.
In a SnapVault relationship, the last Snapshot cannot be deleted; therefore, the resource group cannot be deleted. Before deleting a resource group that is part of a SnapVault relationship, you must use either OnCommand System Manager or use the ONTAP CLI to remove the SnapVault relationship, and then you must delete the last Snapshot. |
In the left Navigator pane of the SCV plug-in, click Resource Groups, then select a resource group and click Delete.
In the Delete resource group confirmation box, click OK to confirm.
