SnapCenter Plug-in for VMware vSphere 6.2
Remove the SnapCenter Plug-in for VMware vSphere
Contributors netapp-jani jani ronya
If you no longer need to use the SnapCenter data protection features, you must disable the SnapCenter Plug-in for VMware vSphere to unregister it from vCenter, then remove the SnapCenter Plug-in for VMware vSphere from vCenter, and then manually delete leftover files.
Before you begin
  • You must have administrator privileges.
  • Make sure that no SnapCenter jobs are running.
Steps
  1. Log in to the SnapCenter Plug-in for VMware vSphere management user interface using the format https://<OVA-IP-address>:8080.
    The IP address of the SnapCenter Plug-in for VMware vSphere is displayed when you deploy the plug-in.
  2. Select Configuration in the left navigation pane, and then unselect the Service option in the Plug-in Details section to disable the plug-in.
  3. Log in to VMware vSphere.
  4. In the left navigator screen, right-click the instance of the SnapCenter Plug-in for VMware vSphere (the name of the .tar file that was used when the virtual appliance was deployed) and select Delete from Disk.
  5. If you used the SnapCenter Plug-in for VMware vSphere to support other SnapCenter plug-ins for application-consistent backups, log in to SnapCenter and remove the vSphere host.
After you finish
The virtual appliance is still deployed but the SnapCenter Plug-in for VMware vSphere is removed.
After removing the host VM for the SnapCenter Plug-in for VMware vSphere, the plug-in might remain listed in vCenter until the local vCenter cache is refreshed. However, because the plug-in was removed, no SnapCenter VMware vSphere operations can be performed on that host. If you want to refresh the local vCenter cache, first make sure the appliance is in a Disabled state on the SnapCenter Plug-in for VMware vSphere Configuration page, and then restart the vCenter web client service.
