SnapCenter Plug-in for VMware vSphere 4.7
Remove SnapCenter Plug-in for VMware vSphere
If you no longer need to use the SnapCenter data protection features, you must disable the SnapCenter VMware plug-in to unregister it from vCenter, then remove the SnapCenter VMware plug-in from vCenter, and then manually delete leftover files.
Before you begin
  • You must have administrator privileges.
  • Make sure that no SnapCenter jobs are running.
Steps
  1. Log in to the SnapCenter VMware plug-in management GUI using the format https://<OVA-IP-address>:8080.
    The IP of the SnapCenter VMware plug-in is displayed when you deploy the plug-in.
  2. Click Configuration in the left navigation pane, and then unselect the Service option in the Plug-in Details section to disable the plug-in.
  3. Log in to VMware vSphere.
  4. In the left navigator screen, right-click the instance of the SnapCenter VMware plug-in (the name of the .ova file that was used when the virtual appliance was deployed) and select Delete from Disk.
  5. Navigate to /etc/vmware/vsphere-ui/vc-packages/vsphere-client-serenity/com.netapp.scvm.webclient-4.5.0.5942045/plugins and manually delete the following files in the pickup folder of the vCenter server:
    vsc-httpclient3-security.jar
    scv-api-model.jar
    scvm_webui_service.jar
    scvm_webui_ui.war
    gson-2.5.jar
  6. If you used the SnapCenter VMware plug-in to support other SnapCenter plug-ins for application-consistent backups, log in to SnapCenter and remove the vSphere host.
After you finish
The virtual appliance is still deployed but the SnapCenter VMware plug-in is removed.
After removing the host VM for the SnapCenter VMware plug-in, the plug-in might remain listed in vCenter until the local vCenter cache is refreshed. However, because the plug-in was removed, no SnapCenter VMware vSphere operations can be performed on that host. If you want to refresh the local vCenter cache, first make sure the appliance is in a Disabled state on the SnapCenter VMware plug-in Configuration page, and then restart the vCenter web client service.
