The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Minimum ONTAP privileges required for the SCV
The minimum ONTAP privileges that are required vary according to the SnapCenter plug-ins you are using for data protection.
Beginning with SnapCenter Plug-in for VMware (SCV) 5.0, you need to add applications of type HTTP and ONTAPI as user login methods for any ONTAP users with customized role-based access to the SCV. Without access to these applications, backups will fail. You need to restart the SCV service to recognize changes to ONTAP user login methods.
All SnapCenter plug-ins require the following minimum privileges.
All-access commands: Minimum ONTAP privileges. |
event generate-autosupport-log |
job history show
job show
job stop |
lun
lun create
lun delete
lun igroup add
lun igroup create
lun igroup delete
lun igroup rename
lun igroup show
lun mapping add-reporting-nodes
lun mapping create
lun mapping delete
lun mapping remove-reporting-nodes
lun mapping show
lun modify
lun move-in-volume
lun offline
lun online
lun persistent-reservation clear
lun resize
lun serial
lun show |
snapmirror list-destinations
snapmirror policy add-rule
snapmirror policy modify-rule
snapmirror policy remove-rule
snapmirror policy show
snapmirror restore
snapmirror show
snapmirror show-history
snapmirror update
snapmirror update-ls-set |
Version |
volume clone create
volume clone show
volume clone split start
volume clone split status
volume clone split stop
volume create
volume delete
volume destroy
volume file clone create
volume file show-disk-usage
volume offline
volume online
volume managed-feature
volume modify
volume qtree create
volume qtree delete
volume qtree modify
volume qtree show
volume restrict
volume show
volume snapshot create
volume snapshot delete
volume snapshot modify
volume snapshot modify-snaplock-expiry-time
volume snapshot rename
volume snapshot restore
volume snapshot restore-file
volume snapshot show
volume snapshot show-delta
volume unmount |
vserver cifs
vserver export-policy
vserver export-policy create
vserver export-policy delete
vserver export-policy rule create
vserver export-policy rule show
vserver export-policy show
vserver iscsi
vserver nvme subsystem controller
vserver nvme subsystem controller show
vserver nvme subsystem create
vserver nvme subsystem delete
vserver nvme subsystem host
vserver nvme subsystem host show
vserver nvme subsystem host add
vserver nvme subsystem host remove
vserver nvme subsystem map
vserver nvme subsystem map show
vserver nvme subsystem map add
vserver nvme subsystem map remove
vserver nvme subsystem modify
vserver nvme subsystem show
vserver nvme namespace create
vserver nvme namespace delete
vserver nvme namespace modify
vserver nvme namespace show
network interface |
| Read-only Commands: Minimum ONTAP Privileges |
cluster identity show
network interface show
vserver |
| All-access commands: Minimum ONTAP privileges |
vserver consistency-group |
You can ignore the cluster identity show cluster level command when creating a role to associate with the data vServer.
You can ignore the warning messages about the unsupported vServer commands.
You need ONTAP 9.12.1 or later versions to use SnapMirror active sync feature.
To use TamperProof Snapshot (TPS) feature:
For NVMe over TCP and NVMe over FC protocol you need ONTAP 9.10.1 and later.
Beginning with ONTAP version 9.11.1, the communication to ONTAP cluster is through REST APIs. The ONTAP user should have http application enabled. However, if there are issues found with ONTAP REST APIs, the configuration key 'FORCE_ZAPI' helps the switchover to traditional ZAPI workflow. You might need to add or update this key using the config APIS and set it to true. Refer to KB article, How to use RestAPI to edit configuration parameters in SCV for more information.
