Minimum ONTAP privileges required
The minimum ONTAP privileges that are required vary according to the SnapCenter plug-ins you are using for data protection.
All SnapCenter plug-ins require the following minimum privileges.
All-access commands: Minimum privileges required for ONTAP 8.3 and later |
event generate-autosupport-log |
job history show |
lun |
snapmirror list-destinations |
Version |
volume clone create |
vserver cifs |
Read-only Commands: Minimum Privileges Required for ONTAP 8.3 and Later |
vserver |
Additional ONTAP information
If you are running ONTAP 8.2.x:
You must login as
vsadmin
on the storage VM to have the appropriate privileges for SnapCenter Plug-in for VMware vSphere operations. -
If you are running ONTAP 8.3 and later:
You must login as
vsadmin
or with a role that has the minimum privileges listed in the tables above.
