Enable SSH for the SnapCenter Plug-in for VMware vSphere
When the SnapCenter Plug-in for VMware vSphere is deployed, SSH is disabled by default.
Steps
From the VMware vSphere client, select the VM where the SnapCenter Plug-in for VMware vSphere is located.
In the Summary tab of the virtual appliance select Launch Remote Console to open a maintenance console window, and then log on.
For information on accessing and logging on to the maintenance console, refer to Access the Maintenance Console.
From the Main Menu, select menu option 2) System Configuration.
From the System Configuration Menu, select menu option 6) Enable SSH access and then enter “y” at the confirmation prompt.
Wait for the message “Enabling SSH Access…” then press Enter to continue, and then enter X at the prompt to exit Maintenance Mode.
