SnapCenter Plug-in for VMware vSphere 6.2
Mark stuck jobs as failed using REST APIs in SCV
Contributors ronya netapp-jani jani
To find job IDs for VMware vSphere client jobs using the SnapCenter Plug-in for VMware vSphere REST APIs, you must use the REST API calls for VMware vSphere. These REST APIs were added in SnapCenter Plug-in for VMware vSphere 4.4.
For each REST API, add https://<server>:<port>` at the front of the REST API to form a complete endpoint.
Use the following REST API in the Jobs section to change jobs that are stuck in a running state to a failed state:
REST API Comments
/4.1/jobs/{id}/failJobs
When you pass the IDs of jobs that are stuck in a running state, failJobs marks those jobs as failed. To identify jobs that are stuck in a running state, use the job monitor user interface to see the state of every job and the job ID.
