REST API to mark stuck jobs as failed
To find job IDs for VMware vSphere client jobs using the SnapCenter Plug-in for VMware vSphere REST APIs, you must use the REST API calls for VMware vSphere. These REST APIs were added in SnapCenter Plug-in for VMware vSphere 4.4.
For each REST API, add https://<server>:<port> at the front of the REST API to form a complete endpoint.
Use the following REST API in the Jobs section to change jobs that are stuck in a running state to a failed state:
| REST API | Comments |
When you pass the IDs of jobs that are stuck in a running state, |
