SnapCenter Plug-in for VMware vSphere 6.2
Add a single VM or datastore to a resource group
Contributors netapp-jani netapp-madhulik jani ronya
You can quickly add a single VM or datastore to any existing resource group managed by SnapCenter Plug-in for VMware vSphere.
About this task
You can add SAN and NAS datastores but not VSAN or VVOL datastores.
Steps
  1. In the vSphere client user interface, select Menu in the toolbar, and navigate to the VM or datastore that you want to add.
  2. In the left navigator pane, right-click on the VM or datastore, select SnapCenter Plug-in for VMware vSphere > Add To Resource Group from the secondary drop-down list.
    The system first checks that SnapCenter manages and is compatible with the storage system on which the selected VM is located and then displays the Add to Resource Group page. If the message SnapCenter Compatibility Error is displayed, then the selected VM is not compatible with SnapCenter and you must first add the appropriate storage VM to SnapCenter.
  3. In the Add To Resource Group page, select a resource group, and then select OK.
    When you select OK, the system first checks that SnapCenter manages and is compatible with the storage on which the selected VMs or datastores are located.
    If the message Selected <resource-name> is not SnapCenter compatible is displayed, then a selected VM or datastore is not compatible with SnapCenter. Refer to Manage compatibility check failures for more information.
