Add storage systems to the SnapCenter Plug-in for VMware vSphere
Follow the steps in this section to add storage.
In the left navigator pane of the SCV plug-in, select Storage Systems and then select Add option.
On the Add Storage System dialog box, enter the basic SVM or cluster information, and select Add.
