SnapCenter Plug-in for VMware vSphere 4.5
  • SnapCenter Plug-in for VMware vSphere 4.5
  • SnapCenter Plug-in for VMware vSphere 4.8
  • SnapCenter Plug-in for VMware vSphere 4.7
  • SnapCenter Plug-in for VMware vSphere 4.6
Request doc changesEdit this pageLearn how to contribute
ON THIS PAGE
    • Product and Solutions
    • Support and Training
    • Cloud Central
    • Community
    • Blog
    • Customer Stories
    • Contact
    Menu bars
    netapp-mark netapp-logo
    English globe
    • English
    • 日本語
    • 한국어
    • 简体中文
    • 繁體中文
    • Deutsch
    • Español
    • Français
    • Italiano
    Available PDFs
    • PDF of this doc site
      • Concepts
      • Get started
        • Requirements for deploying SCV
      • Quick start
      • Monitor and report
      • Manage storage
      • Protect data
      • Mount and unmount datastores
      • Restore from backups
      • Restore guest files and folders
      • Manage SnapCenter Plug-in for VMware vSphere appliance
      • REST APIs
      • Upgrade
      • Migrate
    Creating your file...
    Your file is ready
    • SnapCenter Plug-in for VMware vSphere 4.5 docs
    • Release notes
    • Concepts
      • Product overview
      • Overview of the different SnapCenter GUIs
      • Licensing
      • Role-Based Access Control (RBAC)
      • Types of RBAC for SnapCenter Plug-in for VMware vSphere users
      • ONTAP RBAC features in SnapCenter Plug-in for VMware vSphere
      • Predefined roles packaged with SnapCenter Plug-in for VMware vSphere
      • How to configure ONTAP RBAC for SnapCenter Plug-in for VMware vSphere
    • Get started
      • Deployment Overview
      • Deployment workflow for new users
      • Deployment workflow for existing users
        • Deployment planning and requirements
        • Minimum ONTAP privileges required
      • Download the SnapCenter Plug-in for VMware vSphere OVA (Open Virtual Appliance)
      • Deploy SnapCenter Plug-in for VMware vSphere
      • Post deployment required operations and issues
      • Log in to the SnapCenter VMware vSphere web client
    • Quick start
      • Overview
      • Download the OVA (Open Virtual Appliance)
      • Add storage
      • Create backup policies
      • Create resource groups
      • View status information
      • Monitor jobs
      • Download job logs
      • Access reports
      • Generate a support bundle from the SnapCenter Plug-in for VMware vSphere GUI
      • Generate a support bundle from the maintenance console
    • Manage storage
      • Add storage
      • Manage storage VMs - modify, rename, remove
      • Modify the configured storage timeout
    • Protect data
      • Data protection workflow
      • View VM and datastore backups
      • Create backup policies for VMs and datastores
      • Create resource groups for VMs and datastores
      • Prescripts and postscripts
      • Add a single VM or datastore to a resource group
      • Add multiple VMs and datastores to a resource group
      • Back up resource groups on demand
      • Back up the SnapCenter Plug-in for VMware vSphere MySQL database
      • Manage resource groups - suspend, resume, modify, delete
      • Manage policies - detach, modify, delete
      • Manage backups - rename, delete
      • Mount a backup
      • Unmount a backup
      • Overview
      • How restore operations are performed
      • Search for backups
      • Restore VMs from backups
      • Restore deleted VMs from backups
      • Restore VMDKs from backups
      • Restore the most recent backup of the MySQL database
      • Restore a specific backup of the MySQL database
      • Attach VMDKs to a VM
      • Detach a virtual disk
      • Workflow, prerequisites, and limitations
      • Restore guest files and folders from VMDKs
      • Set up proxy VMs for restore operations
      • Configure credentials for VM guest file restores
      • Extend the time of a guest file restore session
      • Guest file restore scenarios you might encounter
      • Restart the VMware vSphere web client service
      • Access the maintenance console
      • Modify the SnapCenter VMware Plug-in password from the maintenance console
      • Create and import certificates
      • Unregister SnapCenter Plug-in for VMware vSphere from vCenter
      • Disable and enable SnapCenter Plug-in for VMware vSphere
      • Remove SnapCenter Plug-in for VMware vSphere
    • Manage your configuration
    • REST APIs
      • Overview
      • Access REST APIs using the Swagger API web page
      • REST API workflows to add and modify storage VMs
      • REST API workflows to create and modify resource groups
      • REST API workflow to back up on demand
      • REST API workflow to restore VMs
      • REST API workflow to restore deleted VMs
      • REST API workflow to restore VMDKs
      • REST API workflows to attach and detach VMDKs
      • REST API workflows to mount and unmount datastores
      • REST APIs to download jobs and generate reports
      • REST APIs workflows to modify built-in schedules
      • REST API to mark stuck jobs as failed
    • Upgrade
      • Upgrade from an earlier release of SnapCenter Plug-in for VMware vSphere
      • Upgrade to a new patch of the same release
      • Information not displayed after upgrading to a new patch of the same release
    • Migrate
      • Migration options and supported paths
      • Migration overview
      • Prerequisites for migration
      • Migrate from Windows-based SnapCenter Plug-in for VMware vSphere
      • Migrate Windows-based SnapCenter VMware backup metadata
      • Post-migration
      • Correct bad gateway errors during migration
      • Manage authentication errors
    • Legal notices
    • docs.netapp.com
    Add storage
    01/11/2022
    1. In the left Navigator pane of the VMware vSphere web client, click Storage Systems and then click Error: Missing Graphic Image Add.
    2. On the Add Storage System dialog box, enter the basic SVM or cluster information, and then click Add.
    • © 2023 NetApp, Inc.
    • Terms of Use
    • Privacy Policy
    • Cookie Policy
    • Cookie Settings
    • Send feedback about this page
    • blog blog@
    • community community@
    • twitter twitter@
    • facebook facebook@
    • linkedin linkedin@
    • youtube youtube@
    • slideshare slideshare@
