TR-4992: Simplified, Automated Oracle Deployment on NetApp C-Series with NFS
This solution provides an overview and details for automated Oracle deployment in NetApp AFF C-Series as primary database storage with NFS protocol. The Oracle database deploys as a container database with dNFS enabled.
Purpose
NetApp AFF C-Series is a capacity flash storage that makes all-flash more accessible and affordable for unified storage. It is sufficient performance-wise for many tier 1 or tier 2 Oracle database workloads. Powered by NetApp ONTAP data management software, AFF C-Series systems deliver industry-leading efficiency, superior flexibility, best-in-class data services, and cloud integration to help you scale your IT infrastructure, simplify your data management, and reduce storage cost and power consumption.
This documentation demonstrates the simplified deployment of Oracle databases in NetApp C-Series via NFS mounts using Ansible automation. The Oracle database deploys in a container database (CDB) and pluggable databases (PDB) configuration with Oracle dNFS protocol enabled to boost performance. Furthermore, the solution provides the best practices in setting up storage networking and storage virtual machine (SVM) with NFS protocol on C-Series storage controllers. The solution also includes information on fast Oracle database backup, restore, and clone with the NetApp SnapCenter UI tool.
This solution addresses the following use cases:
Automated Oracle container database deployment on NetApp C-Series storage controllers.
Oracle database protection and clone on C-Series with SnapCenter UI tool.
Audience
This solution is intended for the following people:
A DBA who would like to deploy Oracle on NetApp C-Series.
A database solution architect who would like to test Oracle workloads on NetApp C-Series.
A storage administrator who would like to deploy and manage an Oracle database on NetApp C-Series.
An application owner who would like to stand up an Oracle database on NetApp C-Series.
Solution test and validation environment
The testing and validation of this solution were performed in a lab setting that might not match the final deployment environment. See the section Key factors for deployment consideration for more information.
Architecture
Hardware and software components
Hardware |
NetApp C-Series C400 |
ONTAP Version 9.13.1P3 |
Two disk shelves / 24 disks with 278 TiB capacity |
VM for DB server |
4 vCPUs, 16GiB RAM |
Two Linux VM instances for concurrent deployment |
VM for SnapCenter |
One Windows VM instance |
Software |
RedHat Linux |
RHEL Linux 8.6 (LVM) - x64 Gen2 |
Deployed RedHat subscription for testing |
Windows Server |
2022 DataCenter x64 Gen2 |
Hosting SnapCenter server |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
SnapCenter Server |
Version 5.0 |
Workgroup deployment |
Open JDK |
Version java-11-openjdk |
SnapCenter plugin requirement on DB VMs |
NFS |
Version 3.0 |
Oracle dNFS enabled |
Ansible |
core 2.16.2 |
Python 3.6.8 |
Oracle database configuration in the lab environment
Server |
Database |
DB Storage |
ora_01 |
NTAP1(NTAP1_PDB1,NTAP1_PDB2,NTAP1_PDB3) |
/u01, /u02, /u03 NFS mounts on C400 volumes |
ora_02 |
NTAP2(NTAP2_PDB1,NTAP2_PDB2,NTAP2_PDB3) |
Oracle database storage layout. In this automated Oracle deployment, we provision three database volumes for each database to host Oracle binary, data, and logs by default. The volumes are mounted on Oracle DB server as /u01 - binary, /u02 - data, /u03 - logs via NFS. Dual control files are configured on /u02 and /u03 mount points for redundancy.
Multiple DB servers deployment. The automation solution can deploy an Oracle container database to multiple DB servers in a single Ansible playbook run. Regardless of the number of DB servers, the playbook execution remains the same. You can deploy multiple container databases to a single VM instance by repeating the deployment with different database instance IDs (Oracle SID). But ensure there is sufficient memory on the host to support deployed databases.
dNFS configuration. By using dNFS (available since Oracle 11g), an Oracle database running on a DB VM can drive significantly more I/O than the native NFS client. Automated Oracle deployment configures dNFS on NFSv3 by default.
Load balancing on C400 controller pair. Place Oracle database volumes on C400 controller nodes evenly to balance the workload. DB1 on controller 1, DB2 on controller 2, and so on. Mount the DB volumes to its local lif address.
Database backup. NetApp provides a SnapCenter software suite for database backup, restore, and cloning with a user-friendly UI interface. NetApp recommends implementing such a management tool to achieve fast (under a minute) snapshot backup, quick (minutes) database restore, and database clone.
Solution deployment
The following sections provide step-by-step procedures for automated Oracle 19c deployment and information for Oracle database protection and clone after deployment.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
A NetApp C-Series storage controller pair is racked, stacked, and latest version of ONTAP operating system is installed and configured. Refer to this setup guide as necessary: Detailed guide - AFF C400
Provision two Linux VMs as Oracle DB servers. See the architecture diagram in the previous section for details about the environment setup.
Provision a Windows server to run the NetApp SnapCenter UI tool with the latest version. Refer to the following link for details: Install the SnapCenter Server
Provision a Linux VM as the Ansible controller node with the latest version of Ansible and Git installed. Refer to the following link for details: Getting Started with NetApp solution automation^ in section -
Setup the Ansible Control Node for CLI deployments on RHEL / CentOSor
Setup the Ansible Control Node for CLI deployments on Ubuntu / Debian.Enable ssh public/private key authentication between Ansible controller and database VMs.
From Ansible controller admin user home directory, clone a copy of the NetApp Oracle deployment automation toolkit for NFS.
git clone https://bitbucket.ngage.netapp.com/scm/ns-bb/na_oracle_deploy_nfs.git -
Stage following Oracle 19c installation files on DB VM /tmp/archive directory with 777 permission.
installer_archives: - "LINUX.X64_193000_db_home.zip" - "p34765931_190000_Linux-x86-64.zip" - "p6880880_190000_Linux-x86-64.zip"
Configure Networking and SVM on C-Series for Oracle
Details
This section of deployment guide demonstrates best practices to set up networking and storage virtual machine (SVM) on C-Series controller for Oracle workload with NFS protocol using ONTAP System Manager UI.
Login to ONTAP System Manager to review that after initial ONTAP cluster installation, broadcast domains have been configured with ethernet ports properly assigned to each domain. Generally, there should be a broadcast domain for cluster, a broadcast domain for management, and a broadcast domain for workload such as data.
From NETWORK - Ethernet Ports, click
Link Aggregate Groupto create a LACP link aggregate group port a0a, which provides load balance and failover among the member ports in the aggregate group port. There are 4 data ports - e0e, e0f, e0g, e0h available on C400 controllers.
Select the ethernet ports in the group,
LACPfor mode, andPortfor load distribution.
Validate LACP port a0a created and broadcast domain
Datais now operating on LACP port.
From
Ethernet Ports, clickVLANto add a VLAN on each controller node for Oracle workload on NFS protocol.
Login to C-Series controllers from cluster management IP via ssh to validate that network failover groups are configured correctly. ONTAP create and manage failover groups automatically.
HCG-NetApp-C400-E9U9::> net int failover-groups show (network interface failover-groups show) Failover Vserver Group Targets ---------------- ---------------- -------------------------------------------- Cluster Cluster HCG-NetApp-C400-E9U9a:e0c, HCG-NetApp-C400-E9U9a:e0d, HCG-NetApp-C400-E9U9b:e0c, HCG-NetApp-C400-E9U9b:e0d HCG-NetApp-C400-E9U9 Data HCG-NetApp-C400-E9U9a:a0a, HCG-NetApp-C400-E9U9a:a0a-3277, HCG-NetApp-C400-E9U9b:a0a, HCG-NetApp-C400-E9U9b:a0a-3277 Mgmt HCG-NetApp-C400-E9U9a:e0M, HCG-NetApp-C400-E9U9b:e0M 3 entries were displayed. -
From
STORAGE - Storage VMs, click +Add to create a SVM for Oracle.
Name your Oracle SVM, check
Enable NFSandAllow NFS client access.
Add NFS export policy
Defaultrules.
In
NETWORK INTERFACE, fill in IP address on each node for NFS lif addresses.
Validate SVM for Oracle is up/running and NFS lifs status is active.
From
STORAGE-Volumestab to add NFS volumes for Oracle database.
Name your volume, assign capacity, and performance level.
In
Access Permission, choose the default policy created from previous step. UncheckEnable Snapshot Copiesas we prefer to use SnapCenter to create application consistent snapshots.
Create three DB volumes for each DB server: server_name_u01 - binary, server_name_u02 - data, server_name_u03 - logs.
The DB volume naming convention should strictly follow format as stated above to ensure automation to work correctly.
This completes the C-series controller configuration for Oracle.
Automation parameter files
Details
Ansible playbook executes database installation and configuration tasks with predefined parameters. For this Oracle automation solution, there are three user-defined parameter files that need user input before playbook execution.
hosts - define targets that the automation playbook is running against.
vars/vars.yml - the global variable file that defines variables that apply to all targets.
host_vars/host_name.yml - the local variable file that defines variables that apply only to a named target. In our use case, these are the Oracle DB servers.
In addition to these user-defined variable files, there are several default variable files that contain default parameters that do not require change unless necessary. The following sections show how to configure the user-defined variable files.
Parameter files configuration
Details
Ansible target
hostsfile configuration:# Enter Oracle servers names to be deployed one by one, follow by each Oracle server public IP address, and ssh private key of admin user for the server. [oracle] ora_01 ansible_host=10.61.180.21 ansible_ssh_private_key_file=ora_01.pem ora_02 ansible_host=10.61.180.23 ansible_ssh_private_key_file=ora_02.pem
Global
vars/vars.ymlfile configuration###################################################################### ###### Oracle 19c deployment user configuration variables ###### ###### Consolidate all variables from ONTAP, linux and oracle ###### ###################################################################### ########################################### ### ONTAP env specific config variables ### ########################################### # Prerequisite to create three volumes in NetApp ONTAP storage from System Manager or cloud dashboard with following naming convention: # db_hostname_u01 - Oracle binary # db_hostname_u02 - Oracle data # db_hostname_u03 - Oracle redo # It is important to strictly follow the name convention or the automation will fail. ########################################### ### Linux env specific config variables ### ########################################### redhat_sub_username: XXXXXXXX redhat_sub_password: XXXXXXXX #################################################### ### DB env specific install and config variables ### #################################################### # Database domain name db_domain: solutions.netapp.com # Set initial password for all required Oracle passwords. Change them after installation. initial_pwd_all: XXXXXXXX
Local DB server
host_vars/host_name.ymlconfiguration such as ora_01.yml, ora_02.yml …# User configurable Oracle host specific parameters # Enter container database SID. By default, a container DB is created with 3 PDBs within the CDB oracle_sid: NTAP1 # Enter database shared memory size or SGA. CDB is created with SGA at 75% of memory_limit, MB. The grand total of SGA should not exceed 75% available RAM on node. memory_limit: 8192 # Local NFS lif ip address to access database volumes nfs_lif: 172.30.136.68
Playbook execution
Details
There are a total of five playbooks in the automation toolkit. Each performs different task blocks and serves different purposes.
0-all_playbook.yml - execute playbooks from 1-4 in one playbook run. 1-ansible_requirements.yml - set up Ansible controller with required libs and collections. 2-linux_config.yml - execute Linux kernel configuration on Oracle DB servers. 4-oracle_config.yml - install and configure Oracle on DB servers and create a container database. 5-destroy.yml - optional to undo the environment to dismantle all.
There are three options to run the playbooks with the following commands.
Execute all deployment playbooks in one combined run.
ansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -
Execute playbooks one at a time with the number sequence from 1-4.
ansible-playbook -i hosts 1-ansible_requirements.yml -u admin -e @vars/vars.ymlansible-playbook -i hosts 2-linux_config.yml -u admin -e @vars/vars.ymlansible-playbook -i hosts 4-oracle_config.yml -u admin -e @vars/vars.yml -
Execute 0-all_playbook.yml with a tag.
ansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t ansible_requirementsansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t linux_configansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t oracle_config -
Undo the environment
ansible-playbook -i hosts 5-destroy.yml -u admin -e @vars/vars.yml
Post execution validation
Details
After the playbook run, login to the Oracle DB server VM to validate that Oracle is installed and configured and a container database is created successfully. Following is an example of Oracle database validation on DB VM ora_01 or ora_02.
Validate NFS mounts
[admin@ora_01 ~]$ cat /etc/fstab # # /etc/fstab # Created by anaconda on Wed Oct 18 19:43:31 2023 # # Accessible filesystems, by reference, are maintained under '/dev/disk/'. # See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info. # # After editing this file, run 'systemctl daemon-reload' to update systemd # units generated from this file. # /dev/mapper/rhel-root / xfs defaults 0 0 UUID=aff942c4-b224-4b62-807d-6a5c22f7b623 /boot xfs defaults 0 0 /dev/mapper/rhel-swap none swap defaults 0 0 /root/swapfile swap swap defaults 0 0 172.21.21.100:/ora_01_u01 /u01 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 172.21.21.100:/ora_01_u02 /u02 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 172.21.21.100:/ora_01_u03 /u03 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 [admin@ora_01 tmp]$ df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs 7.8G 18M 7.8G 1% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/mapper/rhel-root 44G 28G 17G 62% / /dev/sda1 1014M 258M 757M 26% /boot tmpfs 1.6G 12K 1.6G 1% /run/user/42 tmpfs 1.6G 4.0K 1.6G 1% /run/user/1000 172.21.21.100:/ora_01_u01 50G 8.7G 42G 18% /u01 172.21.21.100:/ora_01_u02 200G 384K 200G 1% /u02 172.21.21.100:/ora_01_u03 100G 320K 100G 1% /u03 [admin@ora_02 ~]$ df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs 7.8G 18M 7.8G 1% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/mapper/rhel-root 44G 28G 17G 63% / /dev/sda1 1014M 258M 757M 26% /boot tmpfs 1.6G 12K 1.6G 1% /run/user/42 tmpfs 1.6G 4.0K 1.6G 1% /run/user/1000 172.21.21.101:/ora_02_u01 50G 7.8G 43G 16% /u01 172.21.21.101:/ora_02_u02 200G 320K 200G 1% /u02 172.21.21.101:/ora_02_u03 100G 320K 100G 1% /u03
Validate Oracle listener
[admin@ora_02 ~]$ sudo su [root@ora_02 admin]# su - oracle [oracle@ora_02 ~]$ lsnrctl status listener.ntap2 LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 29-MAY-2024 12:13:30 Copyright (c) 1991, 2022, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=ora_02.cie.netapp.com)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias LISTENER.NTAP2 Version TNSLSNR for Linux: Version 19.0.0.0.0 - Production Start Date 23-MAY-2024 16:13:03 Uptime 5 days 20 hr. 0 min. 26 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File /u01/app/oracle/product/19.0.0/NTAP2/network/admin/listener.ora Listener Log File /u01/app/oracle/diag/tnslsnr/ora_02/listener.ntap2/alert/log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=ora_02.cie.netapp.com)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=ora_02.cie.netapp.com)(PORT=5500))(Security=(my_wallet_directory=/u01/app/oracle/product/19.0.0/NTAP2/admin/NTAP2/xdb_wallet))(Presentation=HTTP)(Session=RAW)) Services Summary... Service "192551f1d7e65fc3e06308b43d0a63ae.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "1925529a43396002e06308b43d0a2d5a.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "1925530776b76049e06308b43d0a49c3.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "NTAP2.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "NTAP2XDB.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "ntap2_pdb1.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "ntap2_pdb2.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... Service "ntap2_pdb3.solutions.netapp.com" has 1 instance(s). Instance "NTAP2", status READY, has 1 handler(s) for this service... The command completed successfully [oracle@ora_02 ~]$
Validate Oracle database and dNFS
[oracle@ora-01 ~]$ cat /etc/oratab # # This file is used by ORACLE utilities. It is created by root.sh # and updated by either Database Configuration Assistant while creating # a database or ASM Configuration Assistant while creating ASM instance. # A colon, ':', is used as the field terminator. A new line terminates # the entry. Lines beginning with a pound sign, '#', are comments. # # Entries are of the form: # $ORACLE_SID:$ORACLE_HOME:<N|Y>: # # The first and second fields are the system identifier and home # directory of the database respectively. The third field indicates # to the dbstart utility that the database should , "Y", or should not, # "N", be brought up at system boot time. # # Multiple entries with the same $ORACLE_SID are not allowed. # # NTAP1:/u01/app/oracle/product/19.0.0/NTAP1:Y [oracle@ora-01 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Thu Feb 1 16:37:51 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode, log_mode from v$database; NAME OPEN_MODE LOG_MODE --------- -------------------- ------------ NTAP1 READ WRITE ARCHIVELOG SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP1_PDB1 READ WRITE NO 4 NTAP1_PDB2 READ WRITE NO 5 NTAP1_PDB3 READ WRITE NO SQL> select name from v$datafile; NAME -------------------------------------------------------------------------------- /u02/oradata/NTAP1/system01.dbf /u02/oradata/NTAP1/sysaux01.dbf /u02/oradata/NTAP1/undotbs01.dbf /u02/oradata/NTAP1/pdbseed/system01.dbf /u02/oradata/NTAP1/pdbseed/sysaux01.dbf /u02/oradata/NTAP1/users01.dbf /u02/oradata/NTAP1/pdbseed/undotbs01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/system01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/sysaux01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/undotbs01.dbf /u02/oradata/NTAP1/NTAP1_pdb1/users01.dbf NAME -------------------------------------------------------------------------------- /u02/oradata/NTAP1/NTAP1_pdb2/system01.dbf /u02/oradata/NTAP1/NTAP1_pdb2/sysaux01.dbf /u02/oradata/NTAP1/NTAP1_pdb2/undotbs01.dbf /u02/oradata/NTAP1/NTAP1_pdb2/users01.dbf /u02/oradata/NTAP1/NTAP1_pdb3/system01.dbf /u02/oradata/NTAP1/NTAP1_pdb3/sysaux01.dbf /u02/oradata/NTAP1/NTAP1_pdb3/undotbs01.dbf /u02/oradata/NTAP1/NTAP1_pdb3/users01.dbf 19 rows selected. SQL> select name from v$controlfile; NAME -------------------------------------------------------------------------------- /u02/oradata/NTAP1/control01.ctl /u03/orareco/NTAP1/control02.ctl SQL> select member from v$logfile; MEMBER -------------------------------------------------------------------------------- /u03/orareco/NTAP1/onlinelog/redo03.log /u03/orareco/NTAP1/onlinelog/redo02.log /u03/orareco/NTAP1/onlinelog/redo01.log SQL> select svrname, dirname from v$dnfs_servers; SVRNAME -------------------------------------------------------------------------------- DIRNAME -------------------------------------------------------------------------------- 172.21.21.100 /ora_01_u02 172.21.21.100 /ora_01_u03 172.21.21.100 /ora_01_u01 -
Login to Oracle Enterprise Manager Express to validate database.
Oracle backup, restore, and clone with SnapCenter
Details
NetApp recommends SnapCenter UI tool to manage Oracle database deployed in C-Series. Refer to TR-4979 Simplified, Self-managed Oracle in VMware Cloud on AWS with guest-mounted FSx ONTAP section Oracle backup, restore, and clone with SnapCenter for details on setting up SnapCenter and executing the database backup, restore, and clone workflows.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
