TR-4998: Oracle HA in AWS EC2 with Pacemaker Clustering and FSx ONTAP
This solution provides an overview and details for enabling Oracle high availability (HA) in AWS EC2 with Pacemaker clustering on Redhat Enterprise Linux (RHEL) and Amazon FSx ONTAP for the database storage HA via NFS protocol.
Purpose
Many customers who strive to self-manage and run Oracle in the public cloud need to overcome a few challenges. One of those challenges is enabling high availability for the Oracle database. Traditionally, Oracle customers rely on an Oracle database feature called "Real Application Cluster" or RAC for active-active transaction support on multiple cluster nodes. One failed node would not stall application processing. Unfortunately, Oracle RAC implementation is not readily available or supported in many popular public clouds such as AWS EC2. By leveraging built-in Pacemaker clustering (PCS) in RHEL and Amazon FSx ONTAP, customers can achieve a viable alternative without Oracle RAC license cost for active-passive clustering on both compute and storage to support mission-critical Oracle database workload in the AWS cloud.
This documentation demonstrates the details of setting up Pacemaker clustering on RHEL, deploying Oracle database on EC2 and Amazon FSx ONTAP with NFS protocol, configuring Oracle resources in Pacemaker for HA, and wrapping up the demo with validation under most often encountered HA scenarios. The solution also provides information on fast Oracle database backup, restore, and clone with the NetApp SnapCenter UI tool.
This solution addresses the following use cases:
Pacemaker HA clustering setup and configuration in RHEL.
Oracle database HA deployment in AWS EC2 and Amazon FSx ONTAP.
Audience
This solution is intended for the following people:
A DBA who would like to deploy Oracle in AWS EC2 and Amazon FSx ONTAP.
A database solution architect who would like to test Oracle workloads in AWS EC2 and Amazon FSx ONTAP.
A storage administrator who would like to deploy and manage an Oracle database in AWS EC2 and Amazon FSx ONTAP.
An application owner who would like to stand up an Oracle database in AWS EC2 and Amazon FSx ONTAP.
Solution test and validation environment
The testing and validation of this solution were performed in a lab setting that might not match the final deployment environment. See the section Key factors for deployment consideration for more information.
Architecture
Hardware and software components
Hardware |
Amazon FSx ONTAP storage |
Current version offered by AWS |
Single-AZ in us-east-1, 1024 GiB capacity, 128 MB/s throughput |
EC2 instances for DB server |
t2.xlarge/4vCPU/16G |
Two EC2 T2 xlarge EC2 instances, one as primary DB server and the other as a standby DB server |
VM for Ansible controller |
4 vCPUs, 16GiB RAM |
One Linux VM to run automated AWS EC2/FSx provisioning and Oracle deployment on NFS |
Software |
RedHat Linux |
RHEL Linux 8.6 (LVM) - x64 Gen2 |
Deployed RedHat subscription for testing |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
Pacemaker |
Version 0.10.18 |
High Availability Add-On for RHEL 8.0 by RedHat |
NFS |
Version 3.0 |
Oracle dNFS enabled |
Ansible |
core 2.16.2 |
Python 3.6.8 |
Oracle database active/passive configuration in the AWS EC2/FSx lab environment
Server |
Database |
DB Storage |
primary node: orapm01/ip-172.30.15.111 |
NTAP(NTAP_PDB1,NTAP_PDB2,NTAP_PDB3) |
/u01, /u02, /u03 NFS mounts on Amazon FSx ONTAP volumes |
standby node: orapm02/ip-172.30.15.5 |
NTAP(NTAP_PDB1,NTAP_PDB2,NTAP_PDB3) when failover |
/u01, /u02, /u03 NFS mounts when failover |
Amazon FSx ONTAP HA. Amazon FSx ONTAP is provisioned in an HA pair of storage controllers in single or multiple availability zones by default. It provides storage redundancy in an active/passive fashion for mission-critical database workloads. The storage failover is transparent to the end user. User intervention is not required in the event of a storage failover.
PCS resources group and resources ordering. A resources group allows multiple resources with dependency to run on the same cluster node. The resource order enforces the resources startup order and the shutdown order in reverse.
Preferred node. The Pacemaker cluster is purposely deployed in active/passive clustering (not a requirement by Pacemaker) and is in sync with FSx ONTAP clustering. The active EC2 instance is configured as a preferred node for Oracle resources when available with a location constraint.
Fence delay on standby node. In a two-node PCS cluster, a quorum is artificially set as 1. In the event of a communication issue between the cluster nodes, either node could try to fence the other node, which can potentially cause data corruption. Setting up a delay on the standby node mitigates the issue and allows the primary node to continue providing services while the standby node is fenced.
Multi az deployment consideration. The solution is deployed and validated in a single availability zone. For multi-az deployment, additional AWS networking resources are needed to move the PCS floating IP between the availability zones.
Oracle database storage layout. In this solution demonstration, we provision three database volumes for the test database NTAP to host Oracle binary, data, and log. The volumes are mounted on the Oracle DB server as /u01 - binary, /u02 - data, and /u03 - log via NFS. Dual control files are configured on /u02 and /u03 mount points for redundancy.
dNFS configuration. By using dNFS (available since Oracle 11g), an Oracle database running on a DB VM can drive significantly more I/O than the native NFS client. Automated Oracle deployment configures dNFS on NFSv3 by default.
Database backup. NetApp provides a SnapCenter software suite for database backup, restore, and cloning with a user-friendly UI interface. NetApp recommends implementing such a management tool to achieve fast (under a minute) snapshot backup, quick (minutes) database restore, and database clone.
Solution deployment
The following sections provide step-by-step procedures for deployment and configuration of Oracle database HA in AWS EC2 with Pacemaker clustering and Amazon FSx ONTAP for database storage protection.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
An AWS account has been set up, and the necessary VPC and network segments have been created within your AWS account.
Provision a Linux VM as the Ansible controller node with the latest version of Ansible and Git installed. Refer to the following link for details: Getting Started with NetApp solution automation^ in section -
Setup the Ansible Control Node for CLI deployments on RHEL / CentOSor
Setup the Ansible Control Node for CLI deployments on Ubuntu / Debian.Enable ssh public/private key authentication between Ansible controller and EC2 instance DB VMs.
Provision EC2 instances and Amazon FSx ONTAP storage cluster
Details
Although EC2 instance and Amazon FSx ONTAP can be provisioned from AWS console manually, it is recommended to use NetApp Terraform based automation toolkit to automate the provisioning of EC2 instances and FSx ONTAP storage cluster. Following are the detailed procedures.
From AWS CloudShell or Ansible controller VM, clone a copy of automation toolkit for EC2 and FSx ONTAP.
git clone https://bitbucket.ngage.netapp.com/scm/ns-bb/na_aws_fsx_ec2_deploy.gitIf the toolkit is not executed from AWS CloudShell, AWS CLI authentication is required with your AWS account using AWS user account access/secret key pair. -
Review READme.md file included in the toolkit. Revise main.tf and associated parameter files as necessary for the required AWS resources.
An example of main.tf: resource "aws_instance" "orapm01" { ami = var.ami instance_type = var.instance_type subnet_id = var.subnet_id key_name = var.ssh_key_name root_block_device { volume_type = "gp3" volume_size = var.root_volume_size } tags = { Name = var.ec2_tag1 } } resource "aws_instance" "orapm02" { ami = var.ami instance_type = var.instance_type subnet_id = var.subnet_id key_name = var.ssh_key_name root_block_device { volume_type = "gp3" volume_size = var.root_volume_size } tags = { Name = var.ec2_tag2 } } resource "aws_fsx_ontap_file_system" "fsx_01" { storage_capacity = var.fs_capacity subnet_ids = var.subnet_ids preferred_subnet_id = var.preferred_subnet_id throughput_capacity = var.fs_throughput fsx_admin_password = var.fsxadmin_password deployment_type = var.deployment_type disk_iops_configuration { iops = var.iops mode = var.iops_mode } tags = { Name = var.fsx_tag } } resource "aws_fsx_ontap_storage_virtual_machine" "svm_01" { file_system_id = aws_fsx_ontap_file_system.fsx_01.id name = var.svm_name svm_admin_password = var.vsadmin_password } -
Validate and execute the Terraform plan. A successful execution would create two EC2 instances and A FSx ONTAP storage cluster in target AWS account. The automation output displays the EC2 instance IP address and FSx ONTAP cluster end points.
terraform plan -out=main.planterraform apply main.plan
This completes the EC2 instances and FSx ONTAP provisioning for Oracle.
Pacemaker cluster setup
Details
The High Availability Add-On for RHEL is a clustered system that provides reliability, scalability, and availability to critical production services such as Oracle database services. In this use case demonstration, a two-node Pacemaker cluster is set up and configured to support the high availability of an Oracle database in an active/passive clustering scenario.
Login to EC2 instances, as ec2-user, complete following tasks on both EC2 instances:
Remove the AWS Red Hat Update Infrastructure (RHUI) client.
sudo -i yum -y remove rh-amazon-rhui-client* -
Register the EC2 instance VMs with Red Hat.
sudo subscription-manager register --username xxxxxxxx --password 'xxxxxxxx' --auto-attach -
Enable RHEL high availability rpms.
sudo subscription-manager config --rhsm.manage_repos=1sudo subscription-manager repos --enable=rhel-8-for-x86_64-highavailability-rpms -
Install pacemaker and fence agant.
sudo yum update -ysudo yum install pcs pacemaker fence-agents-aws -
Create a password for hacluster user on all cluster nodes. Use the same password for all nodes.
sudo passwd hacluster -
Start the pcs service and enable it to start on boot.
sudo systemctl start pcsd.servicesudo systemctl enable pcsd.service -
Validate pcsd service.
sudo systemctl status pcsd[ec2-user@ip-172-30-15-5 ~]$ sudo systemctl status pcsd ● pcsd.service - PCS GUI and remote configuration interface Loaded: loaded (/usr/lib/systemd/system/pcsd.service; enabled; vendor preset: disabled) Active: active (running) since Tue 2024-09-10 18:50:22 UTC; 33s ago Docs: man:pcsd(8) man:pcs(8) Main PID: 65302 (pcsd) Tasks: 1 (limit: 100849) Memory: 24.0M CGroup: /system.slice/pcsd.service └─65302 /usr/libexec/platform-python -Es /usr/sbin/pcsd Sep 10 18:50:21 ip-172-30-15-5.ec2.internal systemd[1]: Starting PCS GUI and remote configuration interface... Sep 10 18:50:22 ip-172-30-15-5.ec2.internal systemd[1]: Started PCS GUI and remote configuration interface. -
Add cluster nodes to host files.
sudo vi /etc/hosts[ec2-user@ip-172-30-15-5 ~]$ cat /etc/hosts 127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4 ::1 localhost localhost.localdomain localhost6 localhost6.localdomain6 # cluster nodes 172.30.15.111 ip-172-30-15-111.ec2.internal 172.30.15.5 ip-172-30-15-5.ec2.internal
Install and configure awscli for connectivity to AWS account.
sudo yum install awsclisudo aws configure[ec2-user@ip-172-30-15-111 ]# sudo aws configure AWS Access Key ID [None]: XXXXXXXXXXXXXXXXX AWS Secret Access Key [None]: XXXXXXXXXXXXXXXX Default region name [None]: us-east-1 Default output format [None]: json
Install the resource-agents package if not installed already.
sudo yum install resource-agents
On only one of the cluster node, complete following tasks to create pcs cluster.
Authenticate the pcs user hacluster.
sudo pcs host auth ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal[ec2-user@ip-172-30-15-111 ~]$ sudo pcs host auth ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal Username: hacluster Password: ip-172-30-15-111.ec2.internal: Authorized ip-172-30-15-5.ec2.internal: Authorized
Create the pcs cluster.
sudo pcs cluster setup ora_ec2nfsx ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal[ec2-user@ip-172-30-15-111 ~]$ sudo pcs cluster setup ora_ec2nfsx ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal No addresses specified for host 'ip-172-30-15-5.ec2.internal', using 'ip-172-30-15-5.ec2.internal' No addresses specified for host 'ip-172-30-15-111.ec2.internal', using 'ip-172-30-15-111.ec2.internal' Destroying cluster on hosts: 'ip-172-30-15-111.ec2.internal', 'ip-172-30-15-5.ec2.internal'... ip-172-30-15-5.ec2.internal: Successfully destroyed cluster ip-172-30-15-111.ec2.internal: Successfully destroyed cluster Requesting remove 'pcsd settings' from 'ip-172-30-15-111.ec2.internal', 'ip-172-30-15-5.ec2.internal' ip-172-30-15-111.ec2.internal: successful removal of the file 'pcsd settings' ip-172-30-15-5.ec2.internal: successful removal of the file 'pcsd settings' Sending 'corosync authkey', 'pacemaker authkey' to 'ip-172-30-15-111.ec2.internal', 'ip-172-30-15-5.ec2.internal' ip-172-30-15-111.ec2.internal: successful distribution of the file 'corosync authkey' ip-172-30-15-111.ec2.internal: successful distribution of the file 'pacemaker authkey' ip-172-30-15-5.ec2.internal: successful distribution of the file 'corosync authkey' ip-172-30-15-5.ec2.internal: successful distribution of the file 'pacemaker authkey' Sending 'corosync.conf' to 'ip-172-30-15-111.ec2.internal', 'ip-172-30-15-5.ec2.internal' ip-172-30-15-111.ec2.internal: successful distribution of the file 'corosync.conf' ip-172-30-15-5.ec2.internal: successful distribution of the file 'corosync.conf' Cluster has been successfully set up.
Enable the cluster.
sudo pcs cluster enable --all[ec2-user@ip-172-30-15-111 ~]$ sudo pcs cluster enable --all ip-172-30-15-5.ec2.internal: Cluster Enabled ip-172-30-15-111.ec2.internal: Cluster Enabled
Start and validate the cluster.
sudo pcs cluster start --allsudo pcs status[ec2-user@ip-172-30-15-111 ~]$ sudo pcs status Cluster name: ora_ec2nfsx WARNINGS: No stonith devices and stonith-enabled is not false Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Wed Sep 11 15:43:23 2024 on ip-172-30-15-111.ec2.internal * Last change: Wed Sep 11 15:43:06 2024 by hacluster via hacluster on ip-172-30-15-111.ec2.internal * 2 nodes configured * 0 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * No resources Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled
This completes the Pacemaker cluster setup and initial configuration.
Pacemaker cluster fencing configuration
Details
Pacemaker fencing configuration is mandatory for a production cluster. It ensures that a malfunctioning node on your AWS EC2 cluster is automatically isolated, thus preventing the node from consuming the cluster's resources, compromising the cluster's functionality, or corrupting shared data. This section demonstrates the configuration of cluster fencing using the fence_aws fencing agent.
As root user, enter the following AWS metadata query to get the Instance ID for each EC2 instance node.
echo $(curl -s http://169.254.169.254/latest/meta-data/instance-id)[root@ip-172-30-15-111 ec2-user]# echo $(curl -s http://169.254.169.254/latest/meta-data/instance-id) i-0d8e7a0028371636f or just get instance-id from AWS EC2 console
Enter the following command to configure the fence device. Use the pcmk_host_map command to map the RHEL host name to the Instance ID. Use the AWS Access Key and the AWS Secret Access Key of the AWS user account that you previously used for AWS authentication.
sudo pcs stonith \ create clusterfence fence_aws access_key=XXXXXXXXXXXXXXXXX secret_key=XXXXXXXXXXXXXXXXXX \ region=us-east-1 pcmk_host_map="ip-172-30-15-111.ec2.internal:i-0d8e7a0028371636f;ip-172-30-15-5.ec2.internal:i-0bc54b315afb20a2e" \ power_timeout=240 pcmk_reboot_timeout=480 pcmk_reboot_retries=4 -
Validate the fencing configuration.
pcs status[root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Wed Sep 11 21:17:18 2024 on ip-172-30-15-111.ec2.internal * Last change: Wed Sep 11 21:16:40 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 1 resource instance configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-111.ec2.internal Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled
Set stonith-action to off instead of reboot at the cluster level.
pcs property set stonith-action=off[root@ip-172-30-15-111 ec2-user]# pcs property config Cluster Properties: cluster-infrastructure: corosync cluster-name: ora_ec2nfsx dc-version: 2.1.7-5.1.el8_10-0f7f88312 have-watchdog: false last-lrm-refresh: 1726257586 stonith-action: off
With stonith-action set to off, the fenced cluster node will initially be shutdown. After the period defined in stonith power_timeout (240 seconds), the fenced node will be rebooted and rejoins the cluster. -
Set fence delay to 10 seconds for standby node.
pcs stonith update clusterfence pcmk_delay_base="ip-172-30-15-111.ec2.internal:0;ip-172-30-15-5.ec2.internal:10s"[root@ip-172-30-15-111 ec2-user]# pcs stonith config Resource: clusterfence (class=stonith type=fence_aws) Attributes: clusterfence-instance_attributes access_key=XXXXXXXXXXXXXXXX pcmk_delay_base=ip-172-30-15-111.ec2.internal:0;ip-172-30-15-5.ec2.internal:10s pcmk_host_map=ip-172-30-15-111.ec2.internal:i-0d8e7a0028371636f;ip-172-30-15-5.ec2.internal:i-0bc54b315afb20a2e pcmk_reboot_retries=4 pcmk_reboot_timeout=480 power_timeout=240 region=us-east-1 secret_key=XXXXXXXXXXXXXXXX Operations: monitor: clusterfence-monitor-interval-60s interval=60s
Execute pcs stonith refresh command to refresh stopped stonith fence agent or clear failed stonith resource actions.
Deploy Oracle database in PCS cluster
Details
We recommend leveraging the NetApp-provided Ansible playbook to execute database installation and configuration tasks with predefined parameters on the PCS cluster. For this automated Oracle deployment, three user-defined parameter files need user input before playbook execution.
hosts - define targets that the automation playbook is running against.
vars/vars.yml - the global variable file that defines variables that apply to all targets.
host_vars/host_name.yml - the local variable file that defines variables that apply only to a named target. In our use case, these are the Oracle DB servers.
In addition to these user-defined variable files, there are several default variable files that contain default parameters that do not require change unless necessary. The following shows the details of automated Oracle deployment in AWS EC2 and FSx ONTAP in a PCS clustering configuration.
From Ansible controller admin user home directory, clone a copy of the NetApp Oracle deployment automation toolkit for NFS.
git clone https://bitbucket.ngage.netapp.com/scm/ns-bb/na_oracle_deploy_nfs.gitThe Ansible controller can be located in the same VPC as the database EC2 instance or on-premises as long as there is network connectivity between them. -
Fill in the user defined parameters in hosts parameter files. Following are example of typical host file configuration.
[admin@ansiblectl na_oracle_deploy_nfs]$ cat hosts #Oracle hosts [oracle] orapm01 ansible_host=172.30.15.111 ansible_ssh_private_key_file=ec2-user.pem orapm02 ansible_host=172.30.15.5 ansible_ssh_private_key_file=ec2-user.pem
Fill in the user defined parameters in vars/vars.yml parameter files. Following are example of typical vars.yml file configuration.
[admin@ansiblectl na_oracle_deploy_nfs]$ cat vars/vars.yml ###################################################################### ###### Oracle 19c deployment user configuration variables ###### ###### Consolidate all variables from ONTAP, linux and oracle ###### ###################################################################### ########################################### ### ONTAP env specific config variables ### ########################################### # Prerequisite to create three volumes in NetApp ONTAP storage from System Manager or cloud dashboard with following naming convention: # db_hostname_u01 - Oracle binary # db_hostname_u02 - Oracle data # db_hostname_u03 - Oracle redo # It is important to strictly follow the name convention or the automation will fail. ########################################### ### Linux env specific config variables ### ########################################### redhat_sub_username: xxxxxxxx redhat_sub_password: "xxxxxxxx" #################################################### ### DB env specific install and config variables ### #################################################### # Database domain name db_domain: ec2.internal # Set initial password for all required Oracle passwords. Change them after installation. initial_pwd_all: "xxxxxxxx"
Fill in the user defined parameters in host_vars/host_name.yml parameter files. Following are example of typical host_vars/host_name.yml file configuration.
[admin@ansiblectl na_oracle_deploy_nfs]$ cat host_vars/orapm01.yml # User configurable Oracle host specific parameters # Database SID. By default, a container DB is created with 3 PDBs within the CDB oracle_sid: NTAP # CDB is created with SGA at 75% of memory_limit, MB. Consider how many databases to be hosted on the node and # how much ram to be allocated to each DB. The grand total of SGA should not exceed 75% available RAM on node. memory_limit: 8192 # Local NFS lif ip address to access database volumes nfs_lif: 172.30.15.95
nfs_lif address can be retrieved from FSx ONTAP cluster end points output from automated EC2 and FSx ONTAP deployment in previous section. -
Create database volumes from AWS FSx console. Ensure to use PCS primary node host name (orapm01) as prefix for the volumes as demonstrated below.
Stage following Oracle 19c installation files on PCS primary node EC2 instance ip-172-30-15-111.ec2.internal /tmp/archive directory with 777 permission.
installer_archives: - "LINUX.X64_193000_db_home.zip" - "p34765931_190000_Linux-x86-64.zip" - "p6880880_190000_Linux-x86-64.zip"
Execute playbook for Linux config for
all nodes.ansible-playbook -i hosts 2-linux_config.yml -u ec2-user -e @vars/vars.yml[admin@ansiblectl na_oracle_deploy_nfs]$ ansible-playbook -i hosts 2-linux_config.yml -u ec2-user -e @vars/vars.yml PLAY [Linux Setup and Storage Config for Oracle] **************************************************************************************************************************************************************************************************************************************************************************** TASK [Gathering Facts] ****************************************************************************************************************************************************************************************************************************************************************************************************** ok: [orapm01] ok: [orapm02] TASK [linux : Configure RedHat 7 for Oracle DB installation] **************************************************************************************************************************************************************************************************************************************************************** skipping: [orapm01] skipping: [orapm02] TASK [linux : Configure RedHat 8 for Oracle DB installation] **************************************************************************************************************************************************************************************************************************************************************** included: /home/admin/na_oracle_deploy_nfs/roles/linux/tasks/rhel8_config.yml for orapm01, orapm02 TASK [linux : Register subscriptions for RedHat Server] ********************************************************************************************************************************************************************************************************************************************************************* ok: [orapm01] ok: [orapm02] . . .
Execute playbook for oracle config
only on primary node(comment out standby node in hosts file).ansible-playbook -i hosts 4-oracle_config.yml -u ec2-user -e @vars/vars.yml --skip-tags "enable_db_start_shut"[admin@ansiblectl na_oracle_deploy_nfs]$ ansible-playbook -i hosts 4-oracle_config.yml -u ec2-user -e @vars/vars.yml --skip-tags "enable_db_start_shut" PLAY [Oracle installation and configuration] ******************************************************************************************************************************************************************************************************************************************************************************** TASK [Gathering Facts] ****************************************************************************************************************************************************************************************************************************************************************************************************** ok: [orapm01] TASK [oracle : Oracle software only install] ******************************************************************************************************************************************************************************************************************************************************************************** included: /home/admin/na_oracle_deploy_nfs/roles/oracle/tasks/oracle_install.yml for orapm01 TASK [oracle : Create mount points for NFS file systems / Mount NFS file systems on Oracle hosts] *************************************************************************************************************************************************************************************************************************** included: /home/admin/na_oracle_deploy_nfs/roles/oracle/tasks/oracle_mount_points.yml for orapm01 TASK [oracle : Create mount points for NFS file systems] ******************************************************************************************************************************************************************************************************************************************************************** changed: [orapm01] => (item=/u01) changed: [orapm01] => (item=/u02) changed: [orapm01] => (item=/u03) . . .
After database is deployed, comment out /u01, /u02, /u03 mounts in /etc/fstab on primary node since the mount points will be managed by PCS only.
sudo vi /etc/fstab[root@ip-172-30-15-111 ec2-user]# cat /etc/fstab UUID=eaa1f38e-de0f-4ed5-a5b5-2fa9db43bb38 / xfs defaults 0 0 /mnt/swapfile swap swap defaults 0 0 #172.30.15.95:/orapm01_u01 /u01 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 #172.30.15.95:/orapm01_u02 /u02 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0 #172.30.15.95:/orapm01_u03 /u03 nfs rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 0 0
Copy /etc/oratab /etc/oraInst.loc, /home/oracle/.bash_profile to standby node. Ensure to maintain proper file ownership and permissions.
Shutdown database, listener, and umount /u01, /u02, /u03 on primary node.
[root@ip-172-30-15-111 ec2-user]# su - oracle Last login: Wed Sep 18 16:51:02 UTC 2024 [oracle@ip-172-30-15-111 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Wed Sep 18 16:51:16 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> shutdown immediate; SQL> exit Disconnected from Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 [oracle@ip-172-30-15-111 ~]$ lsnrctl stop listener.ntap [oracle@ip-172-30-15-111 ~]$ exit logout [root@ip-172-30-15-111 ec2-user]# umount /u01 [root@ip-172-30-15-111 ec2-user]# umount /u02 [root@ip-172-30-15-111 ec2-user]# umount /u03
Create mount points on standby node ip-172-30-15-5.
mkdir /u01 mkdir /u02 mkdir /u03 -
Mount the FSx ONTAP database volumes on standby node ip-172-30-15-5.
mount -t nfs 172.30.15.95:/orapm01_u01 /u01 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536mount -t nfs 172.30.15.95:/orapm01_u02 /u02 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536mount -t nfs 172.30.15.95:/orapm01_u03 /u03 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536[root@ip-172-30-15-5 ec2-user]# df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.7G 33M 7.7G 1% /dev/shm tmpfs 7.7G 17M 7.7G 1% /run tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup /dev/xvda2 50G 21G 30G 41% / tmpfs 1.6G 0 1.6G 0% /run/user/1000 172.30.15.95:/orapm01_u01 48T 47T 844G 99% /u01 172.30.15.95:/orapm01_u02 285T 285T 844G 100% /u02 172.30.15.95:/orapm01_u03 190T 190T 844G 100% /u03
Changed to oracle user, relink binary.
[root@ip-172-30-15-5 ec2-user]# su - oracle Last login: Thu Sep 12 18:09:03 UTC 2024 on pts/0 [oracle@ip-172-30-15-5 ~]$ env | grep ORA ORACLE_SID=NTAP ORACLE_HOME=/u01/app/oracle/product/19.0.0/NTAP [oracle@ip-172-30-15-5 ~]$ cd $ORACLE_HOME/bin [oracle@ip-172-30-15-5 bin]$ ./relink writing relink log to: /u01/app/oracle/product/19.0.0/NTAP/install/relinkActions2024-09-12_06-21-40PM.log
Copy dnfs lib back to odm folder. Relink could lose the dfns library file.
[oracle@ip-172-30-15-5 odm]$ cd /u01/app/oracle/product/19.0.0/NTAP/rdbms/lib/odm [oracle@ip-172-30-15-5 odm]$ cp ../../../lib/libnfsodm19.so .
Start database to validate on standby node ip-172-30-15-5.
[oracle@ip-172-30-15-5 odm]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Thu Sep 12 18:30:04 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to an idle instance. SQL> startup; ORACLE instance started. Total System Global Area 6442449688 bytes Fixed Size 9177880 bytes Variable Size 1090519040 bytes Database Buffers 5335154688 bytes Redo Buffers 7598080 bytes Database mounted. Database opened. SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- NTAP READ WRITE SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP_PDB1 READ WRITE NO 4 NTAP_PDB2 READ WRITE NO 5 NTAP_PDB3 READ WRITE NO -
Shutdown db and failback database to primary node ip-172-30-15-111.
SQL> shutdown immediate; Database closed. Database dismounted. ORACLE instance shut down. SQL> exit [root@ip-172-30-15-5 ec2-user]# df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.7G 33M 7.7G 1% /dev/shm tmpfs 7.7G 17M 7.7G 1% /run tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup /dev/xvda2 50G 21G 30G 41% / tmpfs 1.6G 0 1.6G 0% /run/user/1000 172.30.15.95:/orapm01_u01 48T 47T 844G 99% /u01 172.30.15.95:/orapm01_u02 285T 285T 844G 100% /u02 172.30.15.95:/orapm01_u03 190T 190T 844G 100% /u03 [root@ip-172-30-15-5 ec2-user]# umount /u01 [root@ip-172-30-15-5 ec2-user]# umount /u02 [root@ip-172-30-15-5 ec2-user]# umount /u03 [root@ip-172-30-15-111 ec2-user]# mount -t nfs 172.30.15.95:/orapm01_u01 /u01 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 mount: (hint) your fstab has been modified, but systemd still uses the old version; use 'systemctl daemon-reload' to reload. [root@ip-172-30-15-111 ec2-user]# mount -t nfs 172.30.15.95:/orapm01_u02 /u02 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 mount: (hint) your fstab has been modified, but systemd still uses the old version; use 'systemctl daemon-reload' to reload. [root@ip-172-30-15-111 ec2-user]# mount -t nfs 172.30.15.95:/orapm01_u03 /u03 -o rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536 mount: (hint) your fstab has been modified, but systemd still uses the old version; use 'systemctl daemon-reload' to reload. [root@ip-172-30-15-111 ec2-user]# df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.8G 48M 7.7G 1% /dev/shm tmpfs 7.8G 33M 7.7G 1% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/xvda2 50G 29G 22G 58% / tmpfs 1.6G 0 1.6G 0% /run/user/1000 172.30.15.95:/orapm01_u01 48T 47T 844G 99% /u01 172.30.15.95:/orapm01_u02 285T 285T 844G 100% /u02 172.30.15.95:/orapm01_u03 190T 190T 844G 100% /u03 [root@ip-172-30-15-111 ec2-user]# su - oracle Last login: Thu Sep 12 18:13:34 UTC 2024 on pts/1 [oracle@ip-172-30-15-111 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Thu Sep 12 18:38:46 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to an idle instance. SQL> startup; ORACLE instance started. Total System Global Area 6442449688 bytes Fixed Size 9177880 bytes Variable Size 1090519040 bytes Database Buffers 5335154688 bytes Redo Buffers 7598080 bytes Database mounted. Database opened. SQL> exit Disconnected from Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 [oracle@ip-172-30-15-111 ~]$ lsnrctl start listener.ntap LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 12-SEP-2024 18:39:17 Copyright (c) 1991, 2022, Oracle. All rights reserved. Starting /u01/app/oracle/product/19.0.0/NTAP/bin/tnslsnr: please wait... TNSLSNR for Linux: Version 19.0.0.0.0 - Production System parameter file is /u01/app/oracle/product/19.0.0/NTAP/network/admin/listener.ora Log messages written to /u01/app/oracle/diag/tnslsnr/ip-172-30-15-111/listener.ntap/alert/log.xml Listening on: (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=ip-172-30-15-111.ec2.internal)(PORT=1521))) Listening on: (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521))) Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=ip-172-30-15-111.ec2.internal)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias listener.ntap Version TNSLSNR for Linux: Version 19.0.0.0.0 - Production Start Date 12-SEP-2024 18:39:17 Uptime 0 days 0 hr. 0 min. 0 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File /u01/app/oracle/product/19.0.0/NTAP/network/admin/listener.ora Listener Log File /u01/app/oracle/diag/tnslsnr/ip-172-30-15-111/listener.ntap/alert/log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=ip-172-30-15-111.ec2.internal)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521))) The listener supports no services The command completed successfully
Configure Oracle resources for PCS management
Details
The goal of configuring Pacemaker clustering is to set up an active/passive high-availability solution for running Oracle in AWS EC2 and FSx ONTAP environment with minimal user intervention in the event of a failure. The following demonstrates Oracle resources configuration for PCS management.
As root user on primary EC2 instance ip-172-30-15-111, create a secondary private IP address with an unused private IP address in the VPC CIDR block as floating IP. In the process, create an oracle resource group that the secondary private IP address will belong to.
pcs resource create privip ocf:heartbeat:awsvip secondary_private_ip=172.30.15.33 --group oracle[root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 16:25:35 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 16:25:23 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 2 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-111.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-5.ec2.internal Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabledIf the privip happens to be created on standby cluster node, move it to primary node as shown below. -
Move a resource between cluster nodes.
pcs resource move privip ip-172-30-15-111.ec2.internal[root@ip-172-30-15-111 ec2-user]# pcs resource move privip ip-172-30-15-111.ec2.internal Warning: A move constraint has been created and the resource 'privip' may or may not move depending on other configuration [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx WARNINGS: Following resources have been moved and their move constraints are still in place: 'privip' Run 'pcs constraint location' or 'pcs resource clear <resource id>' to view or remove the constraints, respectively Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 16:26:38 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 16:26:27 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 2 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-111.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-111.ec2.internal (Monitoring) Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled -
Create a virtual IP (vip) for Oracle. Virtual IP will float between primary and standby node as needed.
pcs resource create vip ocf:heartbeat:IPaddr2 ip=172.30.15.33 cidr_netmask=25 nic=eth0 op monitor interval=10s --group oracle[root@ip-172-30-15-111 ec2-user]# pcs resource create vip ocf:heartbeat:IPaddr2 ip=172.30.15.33 cidr_netmask=25 nic=eth0 op monitor interval=10s --group oracle [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx WARNINGS: Following resources have been moved and their move constraints are still in place: 'privip' Run 'pcs constraint location' or 'pcs resource clear <resource id>' to view or remove the constraints, respectively Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 16:27:34 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 16:27:24 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 3 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-111.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-111.ec2.internal * vip (ocf::heartbeat:IPaddr2): Started ip-172-30-15-111.ec2.internal Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled -
As oracle user, update listener.ora and tnsnames.ora file to point to vip address. Restart the listener. Bounce database if needed for DB to register with listener.
vi $ORACLE_HOME/network/admin/listener.oravi $ORACLE_HOME/network/admin/tnsnames.ora[oracle@ip-172-30-15-111 admin]$ cat listener.ora # listener.ora Network Configuration File: /u01/app/oracle/product/19.0.0/NTAP/network/admin/listener.ora # Generated by Oracle configuration tools. LISTENER.NTAP = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = 172.30.15.33)(PORT = 1521)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) ) [oracle@ip-172-30-15-111 admin]$ cat tnsnames.ora # tnsnames.ora Network Configuration File: /u01/app/oracle/product/19.0.0/NTAP/network/admin/tnsnames.ora # Generated by Oracle configuration tools. NTAP = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = 172.30.15.33)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = NTAP.ec2.internal) ) ) LISTENER_NTAP = (ADDRESS = (PROTOCOL = TCP)(HOST = 172.30.15.33)(PORT = 1521)) [oracle@ip-172-30-15-111 admin]$ lsnrctl status listener.ntap LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 13-SEP-2024 18:28:17 Copyright (c) 1991, 2022, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=172.30.15.33)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias listener.ntap Version TNSLSNR for Linux: Version 19.0.0.0.0 - Production Start Date 13-SEP-2024 18:15:51 Uptime 0 days 0 hr. 12 min. 25 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File /u01/app/oracle/product/19.0.0/NTAP/network/admin/listener.ora Listener Log File /u01/app/oracle/diag/tnslsnr/ip-172-30-15-111/listener.ntap/alert/log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=172.30.15.33)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=ip-172-30-15-111.ec2.internal)(PORT=5500))(Security=(my_wallet_directory=/u01/app/oracle/product/19.0.0/NTAP/admin/NTAP/xdb_wallet))(Presentation=HTTP)(Session=RAW)) Services Summary... Service "21f0b5cc1fa290e2e0636f0f1eacfd43.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "21f0b74445329119e0636f0f1eacec03.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "21f0b83929709164e0636f0f1eacacc3.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "NTAP.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "NTAPXDB.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "ntap_pdb1.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "ntap_pdb2.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "ntap_pdb3.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... The command completed successfully **Oracle listener now listens on vip for database connection** -
Add /u01, /u02, /u03 mount points to oracle resource group.
pcs resource create u01 ocf:heartbeat:Filesystem device='172.30.15.95:/orapm01_u01' directory='/u01' fstype='nfs' options='rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536' --group oraclepcs resource create u02 ocf:heartbeat:Filesystem device='172.30.15.95:/orapm01_u02' directory='/u02' fstype='nfs' options='rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536' --group oraclepcs resource create u03 ocf:heartbeat:Filesystem device='172.30.15.95:/orapm01_u03' directory='/u03' fstype='nfs' options='rw,bg,hard,vers=3,proto=tcp,timeo=600,rsize=65536,wsize=65536' --group oracle -
Create a PCS monitor user ID in oracle DB.
[root@ip-172-30-15-111 ec2-user]# su - oracle Last login: Fri Sep 13 18:12:24 UTC 2024 on pts/0 [oracle@ip-172-30-15-111 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Fri Sep 13 19:08:41 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> CREATE USER c##ocfmon IDENTIFIED BY "XXXXXXXX"; User created. SQL> grant connect to c##ocfmon; Grant succeeded. SQL> exit Disconnected from Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0
Add database to oracle resource group.
pcs resource create ntap ocf:heartbeat:oracle sid='NTAP' home='/u01/app/oracle/product/19.0.0/NTAP' user='oracle' monuser='C##OCFMON' monpassword='XXXXXXXX' monprofile='DEFAULT' --group oracle -
Add database listener to oracle resource group.
pcs resource create listener ocf:heartbeat:oralsnr sid='NTAP' listener='listener.ntap' --group=oracle -
Update all resources location constraints in oracle resource group to primary node as preferred node.
pcs constraint location privip prefers ip-172-30-15-111.ec2.internal pcs constraint location vip prefers ip-172-30-15-111.ec2.internal pcs constraint location u01 prefers ip-172-30-15-111.ec2.internal pcs constraint location u02 prefers ip-172-30-15-111.ec2.internal pcs constraint location u03 prefers ip-172-30-15-111.ec2.internal pcs constraint location ntap prefers ip-172-30-15-111.ec2.internal pcs constraint location listener prefers ip-172-30-15-111.ec2.internal[root@ip-172-30-15-111 ec2-user]# pcs constraint config Location Constraints: Resource: listener Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Resource: ntap Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Resource: privip Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Resource: u01 Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Resource: u02 Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Resource: u03 Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Resource: vip Enabled on: Node: ip-172-30-15-111.ec2.internal (score:INFINITY) Ordering Constraints: Colocation Constraints: Ticket Constraints: -
Validate Oracle resources configuration.
pcs status[root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 19:25:32 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 19:23:40 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 8 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-111.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-111.ec2.internal * vip (ocf::heartbeat:IPaddr2): Started ip-172-30-15-111.ec2.internal * u01 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * u02 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * u03 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * ntap (ocf::heartbeat:oracle): Started ip-172-30-15-111.ec2.internal * listener (ocf::heartbeat:oralsnr): Started ip-172-30-15-111.ec2.internal Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled
Post deployment HA validation
Details
After the deployment, it is vital to run some testing and validation to ensure that the PCS Oracle database failover cluster is configured correctly and functions as expected. The test validation includes managed failover and simulated unexpected resource failure and recovery by the cluster protection mechanism.
Validate node fencing by manually triggering the fencing of standby node and observe that standby node was brought offline and rebooted after a timeout.
pcs stonith fence <standbynodename>[root@ip-172-30-15-111 ec2-user]# pcs stonith fence ip-172-30-15-5.ec2.internal Node: ip-172-30-15-5.ec2.internal fenced [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 21:58:45 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 21:55:12 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 8 resource instances configured Node List: * Online: [ ip-172-30-15-111.ec2.internal ] * OFFLINE: [ ip-172-30-15-5.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-111.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-111.ec2.internal * vip (ocf::heartbeat:IPaddr2): Started ip-172-30-15-111.ec2.internal * u01 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * u02 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * u03 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * ntap (ocf::heartbeat:oracle): Started ip-172-30-15-111.ec2.internal * listener (ocf::heartbeat:oralsnr): Started ip-172-30-15-111.ec2.internal Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled -
Simulate an database listener failure by killing listener process and observe that PCS monitored the listener failure and restarted it in a few seconds.
[root@ip-172-30-15-111 ec2-user]# ps -ef | grep lsnr oracle 154895 1 0 18:15 ? 00:00:00 /u01/app/oracle/product/19.0.0/NTAP/bin/tnslsnr listener.ntap -inherit root 217779 120186 0 19:36 pts/0 00:00:00 grep --color=auto lsnr [root@ip-172-30-15-111 ec2-user]# kill -9 154895 [root@ip-172-30-15-111 ec2-user]# su - oracle Last login: Thu Sep 19 14:58:54 UTC 2024 [oracle@ip-172-30-15-111 ~]$ lsnrctl status listener.ntap LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 13-SEP-2024 19:36:51 Copyright (c) 1991, 2022, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=172.30.15.33)(PORT=1521))) TNS-12541: TNS:no listener TNS-12560: TNS:protocol adapter error TNS-00511: No listener Linux Error: 111: Connection refused Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC1521))) TNS-12541: TNS:no listener TNS-12560: TNS:protocol adapter error TNS-00511: No listener Linux Error: 111: Connection refused [oracle@ip-172-30-15-111 ~]$ lsnrctl status listener.ntap LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 19-SEP-2024 15:00:10 Copyright (c) 1991, 2022, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=172.30.15.33)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias listener.ntap Version TNSLSNR for Linux: Version 19.0.0.0.0 - Production Start Date 16-SEP-2024 14:00:14 Uptime 3 days 0 hr. 59 min. 56 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File /u01/app/oracle/product/19.0.0/NTAP/network/admin/listener.ora Listener Log File /u01/app/oracle/diag/tnslsnr/ip-172-30-15-111/listener.ntap/alert/log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=172.30.15.33)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=ip-172-30-15-111.ec2.internal)(PORT=5500))(Security=(my_wallet_directory=/u01/app/oracle/product/19.0.0/NTAP/admin/NTAP/xdb_wallet))(Presentation=HTTP)(Session=RAW)) Services Summary... Service "21f0b5cc1fa290e2e0636f0f1eacfd43.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "21f0b74445329119e0636f0f1eacec03.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "21f0b83929709164e0636f0f1eacacc3.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "NTAP.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "NTAPXDB.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "ntap_pdb1.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "ntap_pdb2.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... Service "ntap_pdb3.ec2.internal" has 1 instance(s). Instance "NTAP", status READY, has 1 handler(s) for this service... The command completed successfully
Simulate an database failure by killing the pmon process and observe that PCS monitored the databadse failure and restarted it in a few seconds.
**Make a remote connection to ntap database** [oracle@ora_01 ~]$ sqlplus system@//172.30.15.33:1521/NTAP.ec2.internal SQL*Plus: Release 19.0.0.0.0 - Production on Fri Sep 13 15:42:42 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Enter password: Last Successful login time: Thu Sep 12 2024 13:37:28 -04:00 Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select instance_name, host_name from v$instance; INSTANCE_NAME ---------------- HOST_NAME ---------------------------------------------------------------- NTAP ip-172-30-15-111.ec2.internal SQL> **Kill ntap pmon process to simulate a failure** [root@ip-172-30-15-111 ec2-user]# ps -ef | grep pmon oracle 159247 1 0 18:27 ? 00:00:00 ora_pmon_NTAP root 230595 120186 0 19:44 pts/0 00:00:00 grep --color=auto pmon [root@ip-172-30-15-111 ec2-user]# kill -9 159247 **Observe the DB failure** SQL> / select instance_name, host_name from v$instance * ERROR at line 1: ORA-03113: end-of-file on communication channel Process ID: 227424 Session ID: 396 Serial number: 4913 SQL> exit Disconnected from Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 **Reconnect to DB after reboot** [oracle@ora_01 ~]$ sqlplus system@//172.30.15.33:1521/NTAP.ec2.internal SQL*Plus: Release 19.0.0.0.0 - Production on Fri Sep 13 15:47:24 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Enter password: Last Successful login time: Fri Sep 13 2024 15:42:47 -04:00 Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select instance_name, host_name from v$instance; INSTANCE_NAME ---------------- HOST_NAME ---------------------------------------------------------------- NTAP ip-172-30-15-111.ec2.internal SQL>
Validate a managed database failover from primary to standby by putting primary node on standby-mode to failover Oracle resources to standby node.
pcs node standby <nodename>**Stopping Oracle resources on primary node in reverse order** [root@ip-172-30-15-111 ec2-user]# pcs node standby ip-172-30-15-111.ec2.internal [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 20:01:16 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 20:01:08 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 8 resource instances configured Node List: * Node ip-172-30-15-111.ec2.internal: standby (with active resources) * Online: [ ip-172-30-15-5.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-5.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-111.ec2.internal * vip (ocf::heartbeat:IPaddr2): Started ip-172-30-15-111.ec2.internal * u01 (ocf::heartbeat:Filesystem): Stopping ip-172-30-15-111.ec2.internal * u02 (ocf::heartbeat:Filesystem): Stopped * u03 (ocf::heartbeat:Filesystem): Stopped * ntap (ocf::heartbeat:oracle): Stopped * listener (ocf::heartbeat:oralsnr): Stopped Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled **Starting Oracle resources on standby node in sequencial order** [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 20:01:34 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 20:01:08 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 8 resource instances configured Node List: * Node ip-172-30-15-111.ec2.internal: standby * Online: [ ip-172-30-15-5.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-5.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-5.ec2.internal * vip (ocf::heartbeat:IPaddr2): Started ip-172-30-15-5.ec2.internal * u01 (ocf::heartbeat:Filesystem): Started ip-172-30-15-5.ec2.internal * u02 (ocf::heartbeat:Filesystem): Started ip-172-30-15-5.ec2.internal * u03 (ocf::heartbeat:Filesystem): Started ip-172-30-15-5.ec2.internal * ntap (ocf::heartbeat:oracle): Starting ip-172-30-15-5.ec2.internal * listener (ocf::heartbeat:oralsnr): Stopped Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled **NFS mount points mounted on standby node** [root@ip-172-30-15-5 ec2-user]# df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.7G 33M 7.7G 1% /dev/shm tmpfs 7.7G 17M 7.7G 1% /run tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup /dev/xvda2 50G 21G 30G 41% / tmpfs 1.6G 0 1.6G 0% /run/user/1000 172.30.15.95:/orapm01_u01 48T 47T 840G 99% /u01 172.30.15.95:/orapm01_u02 285T 285T 840G 100% /u02 172.30.15.95:/orapm01_u03 190T 190T 840G 100% /u03 tmpfs 1.6G 0 1.6G 0% /run/user/54321 **Database opened on standby node** [oracle@ora_01 ~]$ sqlplus system@//172.30.15.33:1521/NTAP.ec2.internal SQL*Plus: Release 19.0.0.0.0 - Production on Fri Sep 13 16:34:08 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Enter password: Last Successful login time: Fri Sep 13 2024 15:47:28 -04:00 Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- NTAP READ WRITE SQL> select instance_name, host_name from v$instance; INSTANCE_NAME ---------------- HOST_NAME ---------------------------------------------------------------- NTAP ip-172-30-15-5.ec2.internal SQL> -
Validate a managed database failback from standby to primary by unstandby primary node and observe that Oracle resources failback automatically due to prefered node setting.
pcs node unstandby <nodename>**Stopping Oracle resources on standby node for failback to primary** [root@ip-172-30-15-111 ec2-user]# pcs node unstandby ip-172-30-15-111.ec2.internal [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 20:41:30 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 20:41:18 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 8 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-5.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Stopping ip-172-30-15-5.ec2.internal * vip (ocf::heartbeat:IPaddr2): Stopped * u01 (ocf::heartbeat:Filesystem): Stopped * u02 (ocf::heartbeat:Filesystem): Stopped * u03 (ocf::heartbeat:Filesystem): Stopped * ntap (ocf::heartbeat:oracle): Stopped * listener (ocf::heartbeat:oralsnr): Stopped Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled **Starting Oracle resources on primary node for failback** [root@ip-172-30-15-111 ec2-user]# pcs status Cluster name: ora_ec2nfsx Cluster Summary: * Stack: corosync (Pacemaker is running) * Current DC: ip-172-30-15-111.ec2.internal (version 2.1.7-5.1.el8_10-0f7f88312) - partition with quorum * Last updated: Fri Sep 13 20:41:45 2024 on ip-172-30-15-111.ec2.internal * Last change: Fri Sep 13 20:41:18 2024 by root via root on ip-172-30-15-111.ec2.internal * 2 nodes configured * 8 resource instances configured Node List: * Online: [ ip-172-30-15-5.ec2.internal ip-172-30-15-111.ec2.internal ] Full List of Resources: * clusterfence (stonith:fence_aws): Started ip-172-30-15-5.ec2.internal * Resource Group: oracle: * privip (ocf::heartbeat:awsvip): Started ip-172-30-15-111.ec2.internal * vip (ocf::heartbeat:IPaddr2): Started ip-172-30-15-111.ec2.internal * u01 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * u02 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * u03 (ocf::heartbeat:Filesystem): Started ip-172-30-15-111.ec2.internal * ntap (ocf::heartbeat:oracle): Starting ip-172-30-15-111.ec2.internal * listener (ocf::heartbeat:oralsnr): Stopped Daemon Status: corosync: active/enabled pacemaker: active/enabled pcsd: active/enabled **Database now accepts connection on primary node** [oracle@ora_01 ~]$ sqlplus system@//172.30.15.33:1521/NTAP.ec2.internal SQL*Plus: Release 19.0.0.0.0 - Production on Fri Sep 13 16:46:07 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Enter password: Last Successful login time: Fri Sep 13 2024 16:34:12 -04:00 Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select instance_name, host_name from v$instance; INSTANCE_NAME ---------------- HOST_NAME ---------------------------------------------------------------- NTAP ip-172-30-15-111.ec2.internal SQL>
This completes the Oracle HA validation and solution demonstration in AWS EC2 with Pacemaker clustering and Amazon FSx ONTAP as database storage backend.
Oracle backup, restore, and clone with SnapCenter
Details
NetApp recommends SnapCenter UI tool to manage Oracle database deployed in AWS EC2 and Amazon FSx ONTAP. Refer to TR-4979 Simplified, Self-managed Oracle in VMware Cloud on AWS with guest-mounted FSx ONTAP section Oracle backup, restore, and clone with SnapCenter for details on setting up SnapCenter and executing the database backup, restore, and clone workflows.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
