Create the Oracle standby database with Google Cloud NetApp Volumes storage-layer seeding
Create the Oracle physical standby database using Google Cloud NetApp Volumes storage-layer replication, snapshots, or clones to accelerate standby initialization compared to traditional RMAN methods. This procedure covers configuring the listener, creating the standby pfile, seeding standby volumes with GCNV replication, finalizing the Oracle instance, and registering the standby with Oracle Restart. All HA tiers complete these steps. For Prod HA (Data Guard + FSFO) tier, continue with Data Guard finalization before configuring Data Guard Broker, Fast-Start Failover, and the Observer.
Step 1: Configure listener and Data Guard parameters
Configure the listener on both database hosts to support Data Guard connections, including the _DGMGRL service required for the broker. Set up the password file and configure archive log parameters on the primary database.
Configure the primary listener and verify the environment on
oracdb1:sudo su - oracle . ~/.bash_profile # ORACLE_SID=orcl, ORACLE_HOME set -
Configure the standby listener on
oracdb2to include theorclsandorcls_DGMGRLservices:GRID_HOME=/u01/app/26ai/grid sudo -u grid tee "$GRID_HOME/network/admin/listener.ora" >/dev/null <<'EOF' LISTENER = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = oracdb2.example.internal)(PORT = 1521))) SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (GLOBAL_DBNAME = orcls) (ORACLE_HOME = /u01/app/oracle/product/26ai/db_1) (SID_NAME = orcls)) (SID_DESC = (GLOBAL_DBNAME = orcls_DGMGRL) (ORACLE_HOME = /u01/app/oracle/product/26ai/db_1) (SID_NAME = orcls))) EOF -
Restart the listener through Oracle Restart on both hosts and verify the
_DGMGRLservice is registered:sudo -u grid bash -c ' export GRID_HOME=/u01/app/26ai/grid export ORACLE_HOME=$GRID_HOME $GRID_HOME/bin/srvctl stop listener $GRID_HOME/bin/srvctl start listener $GRID_HOME/bin/lsnrctl status 'lsnrctl statusmust list<SID>and<SID>_DGMGRL.
Step 2: Prepare standby pfile and NOMOUNT
Prepare the standby database instance by copying the password file from the primary, creating a minimal init.ora pfile with Data Guard parameters, and starting the instance in NOMOUNT mode.
Copy the primary password file to the standby host using IAP and
gcloud compute scp:PRIMARY_ZONE=us-west1-a # zone of oracdb1 STANDBY_ZONE=us-west1-b # zone of oracdb2 gcloud compute scp \ oracdb1:/u01/app/oracle/product/26ai/db_1/dbs/orapworcl ./orapworcl \ --zone=$PRIMARY_ZONE --tunnel-through-iap gcloud compute scp \ ./orapworcl oracdb2:/u01/app/oracle/product/26ai/db_1/dbs/orapworcls \ --zone=$STANDBY_ZONE --tunnel-through-iap -
Query the
compatibleparameter value from the primary database:# On oracdb1 sudo -u oracle sqlplus -s / as sysdba \ <<<"SELECT value FROM v\$parameter WHERE name='compatible';" -
Create the standby pfile on
oracdb2, set ownership on the password file, and start the instance in NOMOUNT mode. Substitute thecompatiblevalue from the previous step for<COPY_FROM_PRIMARY>:sudo -u oracle mkdir -p /u01/app/oracle/admin/orcls/adump sudo chown oracle:oinstall /u01/app/oracle/product/26ai/db_1/dbs/orapworcls sudo chmod 0600 /u01/app/oracle/product/26ai/db_1/dbs/orapworcls sudo -u oracle tee /u01/app/oracle/product/26ai/db_1/dbs/initorcls.ora >/dev/null <<'EOF' *.db_name='orcl' *.db_unique_name='orcls' *.audit_file_dest='/u01/app/oracle/admin/orcls/adump' *.diagnostic_dest='/u01/app/oracle' *.compatible='<COPY_FROM_PRIMARY>' *.sga_target=3072m *.pga_aggregate_target=1024m *.processes=320 *.remote_login_passwordfile='EXCLUSIVE' *.standby_file_management='AUTO' *.fal_server='orcl' *.log_archive_config='DG_CONFIG=(orcl,orcls)' *.log_archive_dest_1='LOCATION=+RECO VALID_FOR=(ALL_LOGFILES,ALL_ROLES) DB_UNIQUE_NAME=orcls' *.log_archive_dest_2='SERVICE=orcl AFFIRM SYNC VALID_FOR=(ONLINE_LOGFILES,PRIMARY_ROLE) DB_UNIQUE_NAME=orcl' *.log_archive_dest_state_2='DEFER' *.log_archive_format='%t_%s_%r.arc' *.dg_broker_start=TRUE *.undo_tablespace='UNDOTBS1' *.open_cursors=300 *.db_create_file_dest='+DATA' *.db_create_online_log_dest_1='+DATA' *.db_recovery_file_dest='+FRA' *.db_recovery_file_dest_size=25000m EOF echo "orcls:/u01/app/oracle/product/26ai/db_1:N" | sudo tee -a /etc/oratab sudo -u oracle bash -c ' export ORACLE_HOME=/u01/app/oracle/product/26ai/db_1 export ORACLE_SID=orcls sqlplus / as sysdba <<SQL STARTUP NOMOUNT PFILE=/u01/app/oracle/product/26ai/db_1/dbs/initorcls.ora; EXIT SQL 'The standby instance is now in NOMOUNT mode with no datafiles until Step 3: Initialize standby storage with GCNV.
Seed the standby volumes in oracle-pool-b, attach them to oracdb2, mount ASM disk groups, and finalize the standby instance at MOUNT state.
Use GCNV replication for production seeding, and use snapshot seeding for one-time lab workflows.
Choose the seeding path
Choose the standby seeding method based on your environment and recovery requirements.
Recommended for production: Use the replication path in Replication path: create and sync replications and Replication path: cut over and attach standby volumes.
Alternative for labs: Use Alternate path: seed from snapshot.
All paths rejoin at Mount standby ASM disk groups and Finalize the standby instance.
Check prerequisites
Confirm the following prerequisites before you seed standby volumes.
gcloud netappwith volume replication support. -
Two Default-mode pools in different locations (
oracle-pool-a,oracle-pool-b). -
Source volumes on primary pool attached to
oracdb1-hg; destination volumes created by replication. -
Run replication from Cloud Shell or workstation — not from DB VMs.
On
oracdb2, complete iSCSI and ASM host setup from Step 4, Step 5, and Step 6.export PROJECT=<your-gcp-project> export LOC_A=us-west1-a export LOC_B=us-west1-b export DEST_POOL="projects/${PROJECT}/locations/${LOC_B}/storagePools/oracle-pool-b" -
Create a standby pool if needed:
gcloud netapp storage-pools create oracle-pool-b \ --project="${PROJECT}" --location="${LOC_B}" \ --service-level=flex --type=unified --mode=default \ --capacity=1024 --network=name=<your-vpc>
Create and sync replications
Create replication relationships from primary volumes to standby volumes, then wait for initial synchronization to finish.
gcloud netapp volumes replications create repl-oracdb2-data \
--project="${PROJECT}" --location="${LOC_A}" --volume=oracdb1_data \
--replication-schedule=EVERY_10_MINUTES \
--destination-volume-parameters="storage_pool=${DEST_POOL},volume_id=oracdb2_data,share_name=oracdb2_data"
gcloud netapp volumes replications create repl-oracdb2-reco \
--project="${PROJECT}" --location="${LOC_A}" --volume=oracdb1_reco \
--destination-volume-parameters="storage_pool=${DEST_POOL},volume_id=oracdb2_reco,share_name=oracdb2_reco"
Wait until mirrorState is MIRRORED and initial sync is complete for each replication.
Cut over and attach standby volumes
Quiesce the primary, stop replication after the final sync, and attach destination volumes to the standby host group.
On the primary, quiesce writes and capture recovery metadata:
ALTER DATABASE BEGIN BACKUP;
SELECT CURRENT_SCN FROM V$DATABASE;
ALTER DATABASE CREATE STANDBY CONTROLFILE AS '/tmp/orcls_stby.ctl';
Allow one final replication cycle, then stop replications:
gcloud netapp volumes replications stop repl-oracdb2-data \
--project="${PROJECT}" --location="${LOC_A}" --volume=oracdb1_data --force
gcloud netapp volumes replications stop repl-oracdb2-reco \
--project="${PROJECT}" --location="${LOC_A}" --volume=oracdb1_reco --force
Attach destination volumes to oracdb2-hg (replicated LUNs may keep source names):
HG=$(gcloud netapp host-groups describe oracdb2-hg --project="${PROJECT}" \
--location=us-west1 --format='value(name)')
gcloud netapp volumes update oracdb2_data --project="${PROJECT}" --location="${LOC_B}" \
--block-devices="name=oracdb1_data_lun,host-groups=${HG},os-type=LINUX"
Copy the standby controlfile to oracdb2, then end backup mode on the primary:
ALTER DATABASE END BACKUP;
Seed from snapshot
Use this path for one-time lab seeding when continuous replication is not required.
For a one-time lab seed, create a source snapshot and create standby volumes from that snapshot in oracle-pool-b (Cloud Console or API). Attach created volumes to oracdb2-hg, then continue with Mount standby ASM disk groups.
On the standby host, discover the attached storage paths and mount the ASM disk groups before database recovery.
On oracdb2, log in to standby-pool iSCSI portals and rescan multipath devices. If ASM disk headers match primary naming in a lab workflow, use primary-style aliases (for example ora_oracdb1_data_01, ora_oracdb1_arch_01), set asm_diskstring='/dev/mapper/ora_oracdb1_*p*', and confirm partition ownership is grid:asmadmin, then mount disk groups:
ALTER DISKGROUP DATA MOUNT FORCE;
ALTER DISKGROUP RECO MOUNT FORCE;
ALTER DISKGROUP FRA MOUNT FORCE;
Restore the standby controlfile, recover to the captured SCN, convert to physical standby, and start managed recovery.
STARTUP NOMOUNT;
RESTORE STANDBY CONTROLFILE FROM '/tmp/orcls_stby.ctl';
ALTER DATABASE MOUNT;
RECOVER DATABASE UNTIL SCN <quiesce_scn>;
ALTER DATABASE CONVERT TO PHYSICAL STANDBY;
SHUTDOWN IMMEDIATE;
STARTUP MOUNT;
ALTER DATABASE RECOVER MANAGED STANDBY DATABASE DISCONNECT FROM SESSION;
At this point, the standby should be PHYSICAL STANDBY and MOUNTED with managed recovery started.
Tier-specific next steps:
Prod HA (no Data Guard): Continue directly to Step 4: Register standby with Oracle Restart.
Prod HA (Data Guard + FSFO): Continue to Step 4: Register standby with Oracle Restart, then proceed to Data Guard finalization steps.
Register the standby database with Oracle Restart so that reboots automatically recover ASM disk groups, mount the standby database, and restart managed recovery. Also add the application service to both database resources.
Capture the spfile location from the standby database and register it with Oracle Restart on
oracdb2. Substitute<STANDBY_SPFILE_PATH>from the query (often under+DATA):sudo -u oracle bash -c ' export ORACLE_SID=orcls sqlplus -s / as sysdba <<< "SHOW PARAMETER spfile;" ' sudo -u oracle bash -c ' export GRID_HOME=/u01/app/26ai/grid export ORACLE_HOME=/u01/app/oracle/product/26ai/db_1 export PATH=$ORACLE_HOME/bin:$GRID_HOME/bin:$PATH srvctl add database \ -db orcls \ -dbname orcl \ -oraclehome /u01/app/oracle/product/26ai/db_1 \ -spfile <STANDBY_SPFILE_PATH> \ -pwfile /u01/app/oracle/product/26ai/db_1/dbs/orapworcls \ -role PHYSICAL_STANDBY \ -startoption MOUNT \ -stopoption IMMEDIATE \ -diskgroup DATA,RECO,FRA srvctl config database -db orcls srvctl status database -db orcls ' -
Verify and update the primary database resource on
oracdb1to include all ASM disk group dependencies:sudo -u oracle bash -c ' export GRID_HOME=/u01/app/26ai/grid export ORACLE_HOME=/u01/app/oracle/product/26ai/db_1 export PATH=$ORACLE_HOME/bin:$GRID_HOME/bin:$PATH srvctl config database -db orcl srvctl modify database -db orcl -diskgroup DATA,RECO,FRA srvctl config database -db orcl ' -
Add the application service to the standby database resource (
orclsonoracdb2). Userole PRIMARYon both sides soorclappis available after switchover:sudo -u oracle bash -c ' export GRID_HOME=/u01/app/26ai/grid export ORACLE_HOME=/u01/app/oracle/product/26ai/db_1 export PATH=$ORACLE_HOME/bin:$GRID_HOME/bin:$PATH srvctl add service \ -db orcls \ -service orclapp \ -pdb orclpdb \ -role PRIMARY \ -policy AUTOMATIC srvctl config service -db orcls -service orclapp ' -
Verify the standby database resource on
oracdb2:sudo -u oracle bash -c ' export GRID_HOME=/u01/app/26ai/grid export ORACLE_HOME=/u01/app/oracle/product/26ai/db_1 export PATH=$ORACLE_HOME/bin:$GRID_HOME/bin:$PATH srvctl status database -db orcls '
What's next?
Tier-specific:
Prod HA (no Data Guard): To maintain a storage-replication-based recovery target, standby initialization is complete and the standby database is registered with Oracle Restart as a backup instance.
Prod HA (Data Guard + FSFO): To enable broker-managed switchover and fast-start failover, continue with Finalize the standby database for Data Guard.
