Finalize the standby database for Data Guard on Google Cloud NetApp Volumes
Finalize the standby database for Oracle Data Guard on Google Cloud NetApp Volumes by creating standby redo log files, enabling flashback database, activating redo shipping, and verifying Data Guard state.
Tier-specific: This procedure is required only for Prod HA (Data Guard + FSFO) tier.
Step 1: Create standby redo log files
Create standby redo log files on both database hosts to support Fast-Start Failover. Size must be greater than or equal to the largest primary online redo log, and count should equal (online groups per thread) + 1. After GCNV seeding, drop and recreate standby redo logs on the standby to fix replicated paths.
Create standby redo log files on the primary database (
orcl):ALTER SYSTEM SET db_create_file_dest='+DATA' SCOPE=BOTH; ALTER DATABASE ADD STANDBY LOGFILE THREAD 1 ('+DATA') SIZE 1024M; -- repeat (online log groups + 1) times -
Drop and recreate standby redo log files on the standby database (
orcls) after GCNV seeding. Replicated paths under+DATA/ORCL/…causeORA-19527/ORA-16086until rebuilt:ALTER DATABASE RECOVER MANAGED STANDBY DATABASE CANCEL; ALTER SYSTEM SET standby_file_management=MANUAL SCOPE=BOTH; -- DROP STANDBY LOGFILE GROUP for each group# in v$standby_log; ALTER SYSTEM SET db_create_file_dest='+DATA' SCOPE=BOTH; ALTER SYSTEM SET standby_file_management=AUTO SCOPE=BOTH; ALTER DATABASE ADD STANDBY LOGFILE THREAD 1 ('+DATA') SIZE 1024M; -- repeat (online groups + 1) times; one member per group ALTER DATABASE RECOVER MANAGED STANDBY DATABASE USING CURRENT LOGFILE DISCONNECT FROM SESSION;
Step 2: Enable flashback and start recovery
Enable flashback database on the standby to support automatic reinstatement after failover, then start managed recovery with real-time apply. Flashback must be enabled before starting managed recovery because it cannot be enabled while MRP is active.
Shutdown the standby database, restart in MOUNT mode, and enable flashback database on
oracdb2:# On oracdb2 sudo -u oracle bash -c ' . ~/.bash_profile export ORACLE_SID=orcls sqlplus / as sysdba <<SQL SHUTDOWN IMMEDIATE; STARTUP MOUNT; ALTER SYSTEM SET db_flashback_retention_target=1440 SCOPE=BOTH; ALTER DATABASE FLASHBACK ON; EXIT SQL' -
Start managed recovery with real-time apply:
sudo -u oracle bash -c ' . ~/.bash_profile export ORACLE_SID=orcls sqlplus / as sysdba <<SQL ALTER DATABASE RECOVER MANAGED STANDBY DATABASE USING CURRENT LOGFILE DISCONNECT FROM SESSION; EXIT SQL'USING CURRENT LOGFILEenables real-time apply (redo applied as it lands in SRLs).
Step 3: Enable redo shipping
Enable redo transport from the primary to the standby by activating LOG_ARCHIVE_DEST_STATE_2, which was deliberately set to DEFER in Step 2 of the standby initialization procedure to suppress ORA-12154 errors during standby creation.
Switch
LOG_ARCHIVE_DEST_STATE_2toENABLEand force a log switch to initiate redo shipping:sudo -u oracle bash -c ' . ~/.bash_profile sqlplus / as sysdba <<SQL ALTER SYSTEM SET LOG_ARCHIVE_DEST_STATE_2=ENABLE SCOPE=BOTH; ALTER SYSTEM SWITCH LOGFILE; ALTER SYSTEM ARCHIVE LOG CURRENT; EXIT SQL' -
Verify redo shipping is working correctly:
sudo -u oracle bash -c ' . ~/.bash_profile sqlplus / as sysdba <<SQL SELECT dest_id, status, error FROM v\$archive_dest_status WHERE dest_id IN (1,2); EXIT SQL' # Expected: dest_id=2, STATUS=VALID, ERROR null.If
dest_2showsORA-12154, bounce the primary. After Step 1: Enable the broker on both databases, manage transport via DGMGRL.
Step 4: Verify Data Guard state
Verify that the primary database is in READ WRITE mode and the standby database is mounted with managed recovery applying redo logs.
Verify the primary database role and open mode on
oracdb1:sudo -u oracle sqlplus -s / as sysdba \ <<<"SELECT database_role || ' | ' || open_mode FROM v\$database;" # Expected: PRIMARY | READ WRITE -
Verify the standby database role, open mode, and managed recovery status on
oracdb2:gcloud compute ssh oracdb2 --tunnel-through-iap --zone=us-west1-b sudo -u oracle bash <<'BASH' . ~/.bash_profile export ORACLE_SID=orcls sqlplus -s / as sysdba <<'SQL' SELECT database_role || ' | ' || open_mode FROM v$database; SELECT process, status, sequence# FROM v$managed_standby WHERE process IN ('MRP0','RFS'); EXIT SQL BASHExpected on the standby:
PHYSICAL STANDBY | MOUNTED;MRP0withAPPLYING_LOG. -
If the standby reports
MOUNTEDbut apply is not running, restart managed recovery onoracdb2:sudo -u oracle bash -c ' . ~/.bash_profile export ORACLE_SID=orcls sqlplus / as sysdba <<SQL ALTER DATABASE RECOVER MANAGED STANDBY DATABASE CANCEL; ALTER DATABASE RECOVER MANAGED STANDBY DATABASE USING CURRENT LOGFILE DISCONNECT FROM SESSION; EXIT SQL'
What's next?
To activate automated role management and failover protection, continue with Configure Oracle Data Guard Broker, Fast-Start Failover, and the Observer.
