TR-4997: Oracle RAC Deployment and Protection in VCF with vVols
The solution provides an overview and details for Oracle deployment and protection in VMware Cloud Foundation (VCF) with vSphere Virtual Volumes (vVols) as primary database storage and Oracle database in Real Application Clusters (RAC) configuration.
Purpose
VMware vSphere Virtual Volumes (vVols) is a SAN/NAS management and integration framework that exposes virtual disks as native storage objects and enables array-based operations at the virtual disk level. In other words, vVols make SAN/NAS devices VM-aware and unlocks the ability to leverage array-based data services with a VM-centric approach at the granularity of a single virtual disk. vVols allows customers to leverage the unique capabilities of their current storage investments and transition without disruption to a simpler and more efficient operational model optimized for virtual environments that work across all storage types.
In TR-4996, we demonstrated single instance Oracle database deployment and protection in VCF with vVols. This documentation demonstrates the deployment and protection of an Oracle RAC database in a VMware Cloud Foundation environment with vVols as primary database storage in a NetApp ONTAP storage cluster. The Oracle RAC database is configured as if it is deployed in local file systems on a local storage system. This technical report focuses on steps in creating vVols in VCF for Oracle RAC deployment. We also demonstrate Oracle RAC database deployment in VCF on vVols with NetApp automation toolkit and RAC database protection with NetApp SnapCenter UI tool.
This solution addresses the following use cases:
Oracle RAC database deployment in VCF with vVols datastore on NetApp ONTAP AFF as primary database storage
Oracle database backup and restore in VCF with vVols datastore using NetApp SnapCenter UI tool
Audience
This solution is intended for the following people:
A DBA who would like to deploy Oracle RAC in VCF with vVols datastore on NetApp ONTAP AFF as primary database storage
A database solution architect who would like to test Oracle RAC workloads in VCF with vVols datastore on NetApp ONTAP AFF storage
A storage administrator who would like to deploy and manage an Oracle RAC database deployed to VCF with vVols datastore on NetApp ONTAP AFF storage
An application owner who would like to stand up an Oracle RAC database in VCF with vVol datastore
Solution test and validation environment
The testing and validation of this solution was performed in a lab environment in VCF with vVols datastore on NetApp ONTAP AFF storage that might not match the final deployment environment. For more information, see the section Key factors for deployment consideration.
Architecture
Hardware and software components
Hardware |
NetApp ONTAP AFF A300 |
Version 9.14.1P4 |
DS224 shelf with 24 NVMe disks, total capacity 35.2 TiB |
VMware VSphere cluster |
Version 8.02 |
12 CPU(s) x Intel® Xeon® Gold 5218 CPU @ 2.30GHz, 8 nodes (4 management and 4 workload domains) |
Software |
RedHat Linux |
RHEL-8.6, 4.18.0-372.9.1.el8.x86_64 kernel |
Hosting Oracle DB servers, deployed RedHat subscription for testing |
Windows Server |
2022 Standard, 10.0.20348 Build 20348 |
Hosting SnapCenter server |
Centos Linux |
CentOS Linux release 8.5.2111 |
Hosting Ansible controller |
Oracle Grid Infrastructure |
Version 19.18 |
Applied RU patch p34762026_190000_Linux-x86-64.zip |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
SnapCenter Server |
Version 6.0 |
Workgroup deployment |
SnapCenter Plug-in for VMware vSphere |
Version 6.0 |
Deployed as an ova VM to vSphere cluster |
ONTAP tool for VMware vSphere |
Version 9.13 |
Open JDK |
Version java-11-openjdk-11.0.23.0.9-3.el8.x86_64 |
SnapCenter plugin requirement on DB VMs |
Oracle RAC database configuration in VCF
RAC Node |
Database |
DB Storage |
ora01 |
NTAP(NTAP_pdb1,NTAP_pdb2,NTAP_pdb3) |
vVols datastores (VCF_ORA_BINS, VCF_ORA_CRS, VCF_ORA_DAT1, VCF_ORA_DAT2, VCF_ORA_LOGS) on NetApp ONTAP AFF A300 |
ora02 |
Protocol for vVols to ONTAP cluster connectivity. NFS or iSCSI are good choices. The performance levels are equivalent. In this solution demonstration, we used iSCSI as a storage protocol for vVols connectivity to the underlined ONTAP storage cluster. If VCF infrastructure supports, FC/FCoE, NVMe/FC protocols are also supported for vVols datastores on NetApp ONTAP.
Oracle storage layout on vVols datastores. In our tests and validations, we deployed five vVols datastores for Oracle binary, Oracle cluster registry/vote, Oracle data, and Oracle log files. It's good practice to separate different types of Oracle files into their own datastores so that database backup, recovery, or clone can be easily managed and executed. Create dedicate vVols for large databases and share vVols for smaller databases or databases with similar QoS profile.
Oracle storage redundancy. Use
Normal Redundancyfor critical Oracle RAC cluster registry/vote files so that three vote files on three ASM disk failgroups provide optimal cluster protection and the cluster registry is mirrored among the ASM disk failgroups. UseExternal Redundancyfor Oracle binary, data, and log files to optimize storage utilization. The underlined ONTAP RAID-DP provides data protection whenExternal Redundancyis employed. -
Credential for ONTAP storage authentication. Only use ONTAP cluster-level credentials for the ONTAP storage cluster authentication, including SnapCenter connectivity to the ONTAP storage cluster or ONTAP tool connectivity to the ONTAP storage cluster.
Provision storage from vVols datastore to database VM. Add only one disk at a time to the database VM from the vVols datastore. Adding Multiple disks from vVols datastores at the same time is not supported at this time.
Database protection. NetApp provides a SnapCenter software suite for database backup, restore with a user-friendly UI interface. NetApp recommends implementing such a management tool to achieve fast SnapShot backup, quick database restore and recovery.
Solution deployment
The following sections provide step-by-step procedures for Oracle 19c database deployment in VCF with vVols datastores on NetApp ONTAP storage in an Oracle RAC configuration.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
A VMware VCF has been setup. For information or instruction on how to create a VCF, please refer to VMware documentation VMware Cloud Foundation Documentation.
Provision three Linux VMs, two VMs for Oracle RAC database cluster and one VM for Ansible controller within VCF workload domain. Provision one Windows server VM for running NetApp SnapCenter server. For information on setting up Ansible controller for automated Oracle database deployment, referring to following resources Getting Started with NetApp solution automation^.
Oracle RAC database VMs should have provisioned at least two network interfaces - one for Oracle RAC private interconnect and one for apps or public data traffic.
SnapCenter plugin version 6.0 for VMware vSphere has been deployed in VCF. Refer to following resources for the plugin deployment: SnapCenter Plug-in for VMware vSphere documentation.
ONTAP tool for VMware vSphere has been deployed in VCF. Refer to following resources for the ONTAP tool for VMware vSphere deployment: ONTAP tools for VMware vSphere documentation
Ensure that you have allocated at least 50G in Oracle VM root volume in order to have sufficient space to stage Oracle installation files. |
Create storage capability profile
Details
First, create a custom storage capability profile for the underlined ONTAP storage that is hosting the vVols datastore.
From vSphere client shortcuts, open NetApp ONTAP tool. Ensure that ONTAP storage cluster has been added to
Storage Systemsas part of ONTAP tool deployment.
Click on
Storage capability profileto add a custom profile for Oracle. Name the profile and add a brief description.
Choose storage controller category: performance, capacity, or hybrid.
Select the protocol.
Define a QoS policy if desired.
Additional storage attributes for the profile. Be sure that the encryption is enabled on the NetApp controller if you want to have the encryption capability or it may cause issues when applying the profile.
Review the summary and finish the storage capability profile creation.
Create and configure vVols datastore
Details
With the prerequisites completed, login to the VCF as an admin user via vSphere client, navigating to workload domain. Do not use built-in VMware storage option to create vVols. Instead, use NetApp ONTAP tool to create vVols. Following demonstrates the procedures to create and configure vVols.
The vVols creation workflow can be triggered either from ONTAP tool interface or from VCF workload domain cluster.
Filling in general information for datastore including provisioning destination, type, name, and protocol.
Select the custom storage capability profile created from previous step, the
Storage system, andStorage VM, where vVols are to be created.
Choose
Create new volumes, fill in the volume name and size and click onADDthenNEXTto move to the summary page.
Click
Finishto create vVols datastore for Oracle binary.
Create datastore for Oracle cluster registry or CRS.
You could add more than one volume to a vVols datastore or span a vVols datastore volumes across ONTAP controller nodes for performance or redundancy. -
Create datastore for Oracle data. Ideally, create separate datastores on each ONTAP controller node and employ Oracle ASM to stripe data across controller nodes to maximize utilization of ONTAP storage cluster capacity.
Create datastore for Oracle log. Given sequential nature of Oracle log writing, it is good just place it on a single ONTAP controller node.
Validate the Oracle datastores after deployment.
Create VM storage policy based on storage capability profile
Details
Before provisioning storage from vVols datastore to database VM, add a VM storage policy based on storage capability profile created from previous step. Following are the procedures.
From vSphere client menus, open
Policies and Profilesand highlightVM Storage Policies. ClickCreateto openVM Storage Policiesworkflow.
Name the VM storage policy.
In
Datastore specific rules, checkEnable rules for "NetAPP.clustered.Data.ONTAP.VP.vvol" storage
For NetApp.clustered.Data.ONTAP.VP.vvol rules
Placement, select the custom storage capacity profile created from the previous step.
Replication, chooseDisabledif vVols are not replicated.
Storage compatibility page displays the compatible vVols datastores in VCF environment.
Review and finish to create the VM Storage Policy.
Validate the VM Storage Policy just created.
Allocate disks to RAC VMs from vVols datastores and configure DB storage
Details
From vSphere client, add desired disks from the vVols datastores to database VM by editing VM settings. Then, login to VM to format and mount the binary disk to mount points /u01. The following demonstrates the exact steps and tasks.
Before allocating disks from datastore to database VM, login to VMware ESXi hosts to validate and ensure multi-writer are enabled (GBLAllowMW value set to 1) on ESXi level.
[root@vcf-wkld-esx01:~] which esxcli /bin/esxcli [root@vcf-wkld-esx01:~] esxcli system settings advanced list -o /VMFS3/GBLAllowMW Path: /VMFS3/GBLAllowMW Type: integer Int Value: 1 Default Int Value: 1 Min Value: 0 Max Value: 1 String Value: Default String Value: Valid Characters: Description: Allow multi-writer GBLs. Host Specific: false Impact: none [root@vcf-wkld-esx01:~]
Add a new, dedicate SCSI controller for use with Oracle RAC disks. Disable SCSI bus sharing.
From RAC node 1 - ora01, add a disk to VM for Oracle binary storage without sharing.
From RAC node 1, add three disks to VM for Oracle RAC CRS storage and enable multi-writer sharing.
From RAC node 1, add two disks each from each datastore for data to VM for shared Oracle data storage.
From RAC node 1, add two disks to VM from logs datastore for shared Oracle log files storage.
From RAC node 2, add a disk to VM for Oracle binary storage without sharing.
From RAC node 2, add other shared disks by selecting
Existing Hard Disksoption and enable multi-writer sharing for each shared disk.
From VM
Edit Settings,Advanced Parameters, add Attributedisk.enableuuidwith ValueTRUE. The VM needs to be down to add the advanced parameter. Setting this option enables SnapCenter to precisely identify the vVol in your environment. This should be done on all RAC nodes.
Now, restart the VM. Login to VM as an admin user via ssh to review the newly added disk drives.
[admin@ora01 ~]$ sudo lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 50G 0 disk ├─sda1 8:1 0 600M 0 part /boot/efi ├─sda2 8:2 0 1G 0 part /boot └─sda3 8:3 0 48.4G 0 part ├─rhel-root 253:0 0 43.4G 0 lvm / └─rhel-swap 253:1 0 5G 0 lvm [SWAP] sdb 8:16 0 50G 0 disk sdc 8:32 0 10G 0 disk sdd 8:48 0 10G 0 disk sde 8:64 0 10G 0 disk sdf 8:80 0 40G 0 disk sdg 8:96 0 40G 0 disk sdh 8:112 0 40G 0 disk sdi 8:128 0 40G 0 disk sdj 8:144 0 80G 0 disk sdk 8:160 0 80G 0 disk sr0 11:0 1 1024M 0 rom [admin@ora01 ~]$ [admin@ora02 ~]$ sudo lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 50G 0 disk ├─sda1 8:1 0 600M 0 part /boot/efi ├─sda2 8:2 0 1G 0 part /boot └─sda3 8:3 0 48.4G 0 part ├─rhel-root 253:0 0 43.4G 0 lvm / └─rhel-swap 253:1 0 5G 0 lvm [SWAP] sdb 8:16 0 50G 0 disk sdc 8:32 0 10G 0 disk sdd 8:48 0 10G 0 disk sde 8:64 0 10G 0 disk sdf 8:80 0 40G 0 disk sdg 8:96 0 40G 0 disk sdh 8:112 0 40G 0 disk sdi 8:128 0 40G 0 disk sdj 8:144 0 80G 0 disk sdk 8:160 0 80G 0 disk sr0 11:0 1 1024M 0 rom [admin@ora02 ~]$
From each RAC node, partition the Oracle binary disk (/dev/sdb) as a primary and single partition by simply accepting the default choices.
sudo fdisk /dev/sdb -
Format the partitioned disks as xfs file systems.
sudo mkfs.xfs /dev/sdb1 -
Mount the disk to mount point /u01.
[admin@ora01 ~]$ df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 36K 7.7G 1% /dev tmpfs 7.8G 1.4G 6.4G 18% /dev/shm tmpfs 7.8G 34M 7.7G 1% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/mapper/rhel-root 44G 29G 16G 66% / /dev/sda2 1014M 249M 766M 25% /boot /dev/sda1 599M 5.9M 593M 1% /boot/efi /dev/sdb1 50G 24G 27G 47% /u01 tmpfs 1.6G 12K 1.6G 1% /run/user/42 tmpfs 1.6G 0 1.6G 0% /run/user/54331 tmpfs 1.6G 4.0K 1.6G 1% /run/user/1000
Add mount points to /etc/fstab so that disk drives will be mounted when VM reboots.
sudo vi /etc/fstab[oracle@ora_01 ~]$ cat /etc/fstab # # /etc/fstab # Created by anaconda on Wed Oct 18 19:43:31 2023 # # Accessible filesystems, by reference, are maintained under '/dev/disk/'. # See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info. # # After editing this file, run 'systemctl daemon-reload' to update systemd # units generated from this file. # /dev/mapper/rhel-root / xfs defaults 0 0 UUID=aff942c4-b224-4b62-807d-6a5c22f7b623 /boot xfs defaults 0 0 /dev/mapper/rhel-swap none swap defaults 0 0 /root/swapfile swap swap defaults 0 0 /dev/sdb1 /u01 xfs defaults 0 0
Oracle RAC deployment in VCF
Details
It's recommended to leverage NetApp automation toolkit to deploy Oracle RAC in VCF with vVols. Read the included instruction (READme) carefully and configure deployment parameter files such as deployment target file - hosts, global variables file - vars/vars.yml, and local DB VM variables file - host_vars/host_name.yml by following instructions in the toolkit. Following is the step by step procedures.
Login to Ansible controller VM as admin user via ssh and clone a copy of automation toolkit for Oracle RAC deployment in VCF with vVols.
git clone https://bitbucket.ngage.netapp.com/scm/ns-bb/na_oracle_deploy_rac.git -
Stage the following Oracle installation files in /tmp/archive folder on RAC node 1 database VM. The folder should allow all user access with 777 permission.
LINUX.X64_193000_grid_home.zip p34762026_190000_Linux-x86-64.zip LINUX.X64_193000_db_home.zip p34765931_190000_Linux-x86-64.zip p6880880_190000_Linux-x86-64.zip
Set up ssh keyless authentication between Ansible controller and database VMs, which requires to generate a ssh key pair and copy the public key to database VMs admin user root directory .ssh folder authorized_keys file.
ssh-keygen -
Configure the user defined target host parameters files. Following is an example of typical configuration for target hosts file - hosts.
#Oracle hosts [oracle] ora01 ansible_host=10.61.180.21 ansible_ssh_private_key_file=ora01.pem ora02 ansible_host=10.61.180.22 ansible_ssh_private_key_file=ora02.pem
Configure the user defined local host specific parameters files. Following is an example of typical configuration for local host_name.yml file - ora01.yml.
# Binary lun ora_bin: /dev/sdb # Host DB configuration ins_sid: "{{ oracle_sid }}1" asm_sid: +ASM1 -
Configure the user defined global parameters file. Following is an example of typical configuration for global parameters file - vars.yml
####################################################################### ### ONTAP env specific config variables ### ####################################################################### # ONTAP storage platform: on-prem, vmware-vvols ontap_platform: vmware-vvols # Prerequisite to create five vVolss in VMware vCenter # VCF_ORA_BINS - Oracle binary # VCF_ORA_CRS - Oracle cluster registry and vote # VCF_ORA_DAT1 - Oracle data on node1 # VCF_ORA_DAT2 - Oracle data on node2 # VCF_ORA_LOGS - Oracle logs on node1 or node2 # Oracle disks are added to VM from vVols: 1 binary disk, 3 CRS disks, 4 data disks, and 2 log disks. ###################################################################### ### Linux env specific config variables ### ###################################################################### redhat_sub_username: XXXXXXXX redhat_sub_password: "XXXXXXXX" # Networking configuration cluster_pub_ip: - {ip: 10.61.180.21, hostname: ora01} - {ip: 10.61.180.22, hostname: ora02} cluster_pri_ip: - {ip: 172.21.166.22, hostname: ora01-pri} - {ip: 172.21.166.24, hostname: ora02-pri} cluster_vip_ip: - {ip: 10.61.180.93, hostname: ora01-vip} - {ip: 10.61.180.94, hostname: ora02-vip} cluster_scan_name: ntap-scan cluster_scan_ip: - {ip: 10.61.180.90, hostname: ntap-scan} - {ip: 10.61.180.91, hostname: ntap-scan} - {ip: 10.61.180.92, hostname: ntap-scan} ##################################################################### ### DB env specific install and config variables ### ##################################################################### # Shared Oracle RAC storage ora_crs: - { device: /dev/sdc, name: ora_crs_01 } - { device: /dev/sdd, name: ora_crs_02 } - { device: /dev/sde, name: ora_crs_03 } ora_data: - { device: /dev/sdf, name: ora_data_01 } - { device: /dev/sdg, name: ora_data_02 } - { device: /dev/sdh, name: ora_data_03 } - { device: /dev/sdi, name: ora_data_04 } ora_logs: - { device: /dev/sdj, name: ora_logs_01 } - { device: /dev/sdk, name: ora_logs_02 } # Oracle RAC configuration oracle_sid: NTAP cluster_name: ntap-rac cluster_nodes: ora01,ora02 cluster_domain: solutions.netapp.com grid_cluster_nodes: ora01:ora01-vip:HUB,ora02:ora02-vip:HUB network_interface_list: ens33:10.61.180.0:1,ens34:172.21.166.0:5 memory_limit: 10240 # Set initial password for all required Oracle passwords. Change them after installation. initial_pwd_all: "XXXXXXXX" -
From Ansible controller, cloned automation toolkit home directory /home/admin/na_oracle_deploy_rac, execute prerequisites playbook to setup ansible prerequisites.
ansible-playbook -i hosts 1-ansible_requirements.yml -
Execute Linux configuration playbook.
ansible-playbook -i hosts 2-linux_config.yml -u admin -e @vars/vars.yml -
Execute Oracle deployment playbook.
ansible-playbook -i hosts 4-oracle_config.yml -u admin -e @vars/vars.yml -
Optionally, all above playbooks can be executed from a single playbook run as well.
ansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml
Oracle RAC deployment validation in VCF
Details
This section provides details on Oracle RAC deployment validation in VCF to ensure all Oracle RAC resources are fully deployed, configured, and functioning as expected.
Login to RAC VM as admin user to validate Oracle grid infrastructure.
[admin@ora01 ~]$ sudo su [root@ora01 admin]# su - grid [grid@ora01 ~]$ crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.LISTENER.lsnr ONLINE ONLINE ora01 STABLE ONLINE ONLINE ora02 STABLE ora.chad ONLINE ONLINE ora01 STABLE ONLINE ONLINE ora02 STABLE ora.net1.network ONLINE ONLINE ora01 STABLE ONLINE ONLINE ora02 STABLE ora.ons ONLINE ONLINE ora01 STABLE ONLINE ONLINE ora02 STABLE ora.proxy_advm OFFLINE OFFLINE ora01 STABLE OFFLINE OFFLINE ora02 STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.ASMNET1LSNR_ASM.lsnr(ora.asmgroup) 1 ONLINE ONLINE ora01 STABLE 2 ONLINE ONLINE ora02 STABLE ora.DATA.dg(ora.asmgroup) 1 ONLINE ONLINE ora01 STABLE 2 ONLINE ONLINE ora02 STABLE ora.LISTENER_SCAN1.lsnr 1 ONLINE ONLINE ora01 STABLE ora.LISTENER_SCAN2.lsnr 1 ONLINE ONLINE ora02 STABLE ora.LISTENER_SCAN3.lsnr 1 ONLINE ONLINE ora02 STABLE ora.RECO.dg(ora.asmgroup) 1 ONLINE ONLINE ora01 STABLE 2 ONLINE ONLINE ora02 STABLE ora.VOTE.dg(ora.asmgroup) 1 ONLINE ONLINE ora01 STABLE 2 ONLINE ONLINE ora02 STABLE ora.asm(ora.asmgroup) 1 ONLINE ONLINE ora01 Started,STABLE 2 ONLINE ONLINE ora02 Started,STABLE ora.asmnet1.asmnetwork(ora.asmgroup) 1 ONLINE ONLINE ora01 STABLE 2 ONLINE ONLINE ora02 STABLE ora.cvu 1 ONLINE ONLINE ora02 STABLE ora.ntap.db 1 ONLINE ONLINE ora01 Open,HOME=/u01/app/o racle2/product/19.0. 0/NTAP,STABLE 2 ONLINE ONLINE ora02 Open,HOME=/u01/app/o racle2/product/19.0. 0/NTAP,STABLE ora.ora01.vip 1 ONLINE ONLINE ora01 STABLE ora.ora02.vip 1 ONLINE ONLINE ora02 STABLE ora.qosmserver 1 ONLINE ONLINE ora02 STABLE ora.scan1.vip 1 ONLINE ONLINE ora01 STABLE ora.scan2.vip 1 ONLINE ONLINE ora02 STABLE ora.scan3.vip 1 ONLINE ONLINE ora02 STABLE -------------------------------------------------------------------------------- [grid@ora01 ~]$ -
Validate Oracle ASM.
[grid@ora01 ~]$ asmcmd ASMCMD> lsdg State Type Rebal Sector Logical_Sector Block AU Total_MB Free_MB Req_mir_free_MB Usable_file_MB Offline_disks Voting_files Name MOUNTED EXTERN N 512 512 4096 1048576 163840 163723 0 163723 0 N DATA/ MOUNTED EXTERN N 512 512 4096 1048576 163840 163729 0 163729 0 N RECO/ MOUNTED NORMAL N 512 512 4096 4194304 30720 29732 10240 9746 0 Y VOTE/ ASMCMD> lsdsk Path AFD:ORA_CRS_01 AFD:ORA_CRS_02 AFD:ORA_CRS_03 AFD:ORA_DATA_01 AFD:ORA_DATA_02 AFD:ORA_DATA_03 AFD:ORA_DATA_04 AFD:ORA_LOGS_01 AFD:ORA_LOGS_02 ASMCMD> afd_state ASMCMD-9526: The AFD state is 'LOADED' and filtering is 'ENABLED' on host 'ora01' ASMCMD>
List cluster nodes.
[grid@ora01 ~]$ olsnodes ora01 ora02
Validate OCR/VOTE.
[grid@ora01 ~]$ ocrcheck Status of Oracle Cluster Registry is as follows : Version : 4 Total space (kbytes) : 901284 Used space (kbytes) : 84536 Available space (kbytes) : 816748 ID : 118267044 Device/File Name : +VOTE Device/File integrity check succeeded Device/File not configured Device/File not configured Device/File not configured Device/File not configured Cluster registry integrity check succeeded Logical corruption check bypassed due to non-privileged user [grid@ora01 ~]$ crsctl query css votedisk ## STATE File Universal Id File Name Disk group -- ----- ----------------- --------- --------- 1. ONLINE 1ca3fcb0bd354f8ebf00ac97d70e0824 (AFD:ORA_CRS_01) [VOTE] 2. ONLINE 708f84d505a54f58bf41124e09a5115a (AFD:ORA_CRS_02) [VOTE] 3. ONLINE 133ecfcedb684fe6bfdc1899b90f91c7 (AFD:ORA_CRS_03) [VOTE] Located 3 voting disk(s). [grid@ora01 ~]$ -
Validate Oracle listener.
[grid@ora01 ~]$ lsnrctl status listener LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 16-AUG-2024 10:21:38 Copyright (c) 1991, 2022, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=LISTENER))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for Linux: Version 19.0.0.0.0 - Production Start Date 14-AUG-2024 16:24:48 Uptime 1 days 17 hr. 56 min. 49 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File /u01/app/grid/19.0.0/network/admin/listener.ora Listener Log File /u01/app/oracle/diag/tnslsnr/ora01/listener/alert/log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=LISTENER))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=10.61.180.21)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=10.61.180.93)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=ora01.solutions.netapp.com)(PORT=5500))(Security=(my_wallet_directory=/u01/app/oracle2/product/19.0.0/NTAP/admin/NTAP/xdb_wallet))(Presentation=HTTP)(Session=RAW)) Services Summary... Service "+ASM" has 1 instance(s). Instance "+ASM1", status READY, has 1 handler(s) for this service... Service "+ASM_DATA" has 1 instance(s). Instance "+ASM1", status READY, has 1 handler(s) for this service... Service "+ASM_RECO" has 1 instance(s). Instance "+ASM1", status READY, has 1 handler(s) for this service... Service "+ASM_VOTE" has 1 instance(s). Instance "+ASM1", status READY, has 1 handler(s) for this service... Service "1fbf0aaa1d13cb5ae06315b43d0ab734.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "1fbf142e7db2d090e06315b43d0a6894.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "1fbf203c3a46d7bae06315b43d0ae055.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "NTAP.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "NTAPXDB.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "ntap_pdb1.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "ntap_pdb2.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... Service "ntap_pdb3.solutions.netapp.com" has 1 instance(s). Instance "NTAP1", status READY, has 1 handler(s) for this service... The command completed successfully [grid@ora01 ~]$ [grid@ora01 ~]$ tnsping ntap-scan TNS Ping Utility for Linux: Version 19.0.0.0.0 - Production on 16-AUG-2024 12:07:58 Copyright (c) 1997, 2022, Oracle. All rights reserved. Used parameter files: /u01/app/grid/19.0.0/network/admin/sqlnet.ora Used EZCONNECT adapter to resolve the alias Attempting to contact (DESCRIPTION=(CONNECT_DATA=(SERVICE_NAME=))(ADDRESS=(PROTOCOL=tcp)(HOST=10.61.180.90)(PORT=1521))(ADDRESS=(PROTOCOL=tcp)(HOST=10.61.180.91)(PORT=1521))(ADDRESS=(PROTOCOL=tcp)(HOST=10.61.180.92)(PORT=1521))) OK (10 msec)
Change to oracle user to validate the clustered database.
[oracle@ora02 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Fri Aug 16 11:32:23 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode, log_mode from v$database; NAME OPEN_MODE LOG_MODE --------- -------------------- ------------ NTAP READ WRITE ARCHIVELOG SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP_PDB1 READ WRITE NO 4 NTAP_PDB2 READ WRITE NO 5 NTAP_PDB3 READ WRITE NO SQL> select name from v$datafile 2 union 3 select name from v$controlfile 4 union 5 select member from v$logfile; NAME -------------------------------------------------------------------------------- +DATA/NTAP/1FBF0AAA1D13CB5AE06315B43D0AB734/DATAFILE/sysaux.275.1177083797 +DATA/NTAP/1FBF0AAA1D13CB5AE06315B43D0AB734/DATAFILE/system.274.1177083797 +DATA/NTAP/1FBF0AAA1D13CB5AE06315B43D0AB734/DATAFILE/undo_2.277.1177083853 +DATA/NTAP/1FBF0AAA1D13CB5AE06315B43D0AB734/DATAFILE/undotbs1.273.1177083797 +DATA/NTAP/1FBF0AAA1D13CB5AE06315B43D0AB734/DATAFILE/users.278.1177083901 +DATA/NTAP/1FBF142E7DB2D090E06315B43D0A6894/DATAFILE/sysaux.281.1177083903 +DATA/NTAP/1FBF142E7DB2D090E06315B43D0A6894/DATAFILE/system.280.1177083903 +DATA/NTAP/1FBF142E7DB2D090E06315B43D0A6894/DATAFILE/undo_2.283.1177084061 +DATA/NTAP/1FBF142E7DB2D090E06315B43D0A6894/DATAFILE/undotbs1.279.1177083903 +DATA/NTAP/1FBF142E7DB2D090E06315B43D0A6894/DATAFILE/users.284.1177084103 +DATA/NTAP/1FBF203C3A46D7BAE06315B43D0AE055/DATAFILE/sysaux.287.1177084105 NAME -------------------------------------------------------------------------------- +DATA/NTAP/1FBF203C3A46D7BAE06315B43D0AE055/DATAFILE/system.286.1177084105 +DATA/NTAP/1FBF203C3A46D7BAE06315B43D0AE055/DATAFILE/undo_2.289.1177084123 +DATA/NTAP/1FBF203C3A46D7BAE06315B43D0AE055/DATAFILE/undotbs1.285.1177084105 +DATA/NTAP/1FBF203C3A46D7BAE06315B43D0AE055/DATAFILE/users.290.1177084125 +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.266.1177081837 +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.265.1177081837 +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.267.1177081837 +DATA/NTAP/CONTROLFILE/current.261.1177080403 +DATA/NTAP/DATAFILE/sysaux.258.1177080245 +DATA/NTAP/DATAFILE/system.257.1177080129 +DATA/NTAP/DATAFILE/undotbs1.259.1177080311 NAME -------------------------------------------------------------------------------- +DATA/NTAP/DATAFILE/undotbs2.269.1177082203 +DATA/NTAP/DATAFILE/users.260.1177080311 +DATA/NTAP/ONLINELOG/group_1.262.1177080427 +DATA/NTAP/ONLINELOG/group_2.263.1177080427 +DATA/NTAP/ONLINELOG/group_3.270.1177083297 +DATA/NTAP/ONLINELOG/group_4.271.1177083313 +RECO/NTAP/CONTROLFILE/current.256.1177080403 +RECO/NTAP/ONLINELOG/group_1.257.1177080427 +RECO/NTAP/ONLINELOG/group_2.258.1177080427 +RECO/NTAP/ONLINELOG/group_3.259.1177083313 +RECO/NTAP/ONLINELOG/group_4.260.1177083315 33 rows selected. -
Or login to EM express to to validate RAC database after successful playbook execution.
Oracle RAC database backup and recovery in VCF with SnapCenter
SnapCenter Setup
Details
SnapCenter version 6 has many feature enhancements over version 5, including support for VMware vVols datastore. SnapCenter relies on a host-side plug-in on a database VM to perform application-aware data protection management activities. For detailed information on NetApp SnapCenter plug-in for Oracle, refer to this documentation What can you do with the Plug-in for Oracle Database. The following provides high-level steps to set up SnapCenter version 6 for Oracle RAC database backup and recovery in VCF.
Download the version 6 of SnapCenter software from NetApp support site: NetApp Support Downloads.
Login to the SnapCenter hosting Windows VM as administrator. Install prerequisites for SnapCenter 6.0.
As administrator, install latest java JDK from Get Java for desktop applications.
If Windows server is deployed in a domain environment, add a domain user to SnapCenter server local administrators group and run SnapCenter installation with the domain user. -
Login to SnapCenter UI via HTTPS port 8846 as installation user to configure SnapCenter for Oracle.
Review
Get Startedmenu to get up to speed on SnapCenter if you are a new user.
Update
Hypervisor Settingsin global settings.
Add ONTAP storage cluster to
Storage Systemswith cluster management IP and authenticated via cluster admin user ID.
Add Oracle RAC database VMs and vSphere plugin VM
Credentialfor SnapCenter access to DB VM and vSphere plugin VM. The credential should have sudo privilege on the Linux VMs. You may create different credentials for different management user IDs for the VMs. vShpere plugin VM management user ID is defined when the plugin VM is deployed in vCenter.
Add Oracle RAC database VM in VCF to
Hostswith DB VM credential created in previous step.
Similarly, add NetApp VMware plugin VM to
Hostswith vSphere plugin VM credential created in previous step.
Finally, after Oracle database is discovered on DB VM, back to
Settings-Policiesto create Oracle database backup policies. Ideally, create a separate archive log backup policy to allow more frequent backup interval to minimize data loss in the event of a failure.
Ensure that the SnapCenter server name can be resolved to the IP address from the DB VM and vSphere plugin VM. Equally, the DB VM name and vSphere plugin VM name can be resolved to the IP address from the SnapCenter server. |
Database backup
Details
SnapCenter leverages ONTAP volume snapshot for much quicker database backup, restore, or clone compared with traditional RMAN based methodology. The snapshots are application-consistent as the database is put in Oracle backup mode before a snapshot.
From the
Resourcestab, any databases on the VM are auto-discovered after the VM is added to SnapCenter. Initially, the database status shows asNot protected.
Click on database to start a workflow to enable protection for the database.
Apply backup policy, setup scheduling if needed.
Setup backup job notification if required.
Review the summary and finish to enable database protection.
On-demand backup job can be triggered by click on
Back up Now.
The backup job can be monitored at the
Monitortab by clicking on the running job.
Click on database to review the backup sets completed for RAC database.
Database restore/recovery
Details
SnapCenter provides a number of restore and recovery options for Oracle RAC database from snapshot backup. In this example, we demonstrate to restore from a older snapshot backup, then roll forward the database to the last available log.
First, run a snapshot backup. Then, create a test table and insert a row into table to validate that recovered database from snapshot image before test table creation regains the test table.
[oracle@ora01 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Mon Aug 19 10:31:12 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP_PDB1 READ WRITE NO 4 NTAP_PDB2 READ WRITE NO 5 NTAP_PDB3 READ WRITE NO SQL> alter session set container=ntap_pdb1; Session altered. SQL> create table test (id integer, dt timestamp, event varchar(100)); Table created. SQL> insert into test values (1, sysdate, 'validate SnapCenter rac database restore on VMware vVols storage'); 1 row created. SQL> commit; Commit complete. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 19-AUG-24 10.36.04.000000 AM validate SnapCenter rac database restore on VMware vVols storage SQL> -
From SnapCenter
Resourcestab, open the database NTAP1 backup topology page. Highlight the snapshot data backup set created 3 days ago. Click onRestoreto launch restore-recover workflow.
Choose restore scope.
Choose recovery scope to
All Logs.
Specify any optional pre-scripts to run.
Specify any optional after-script to run.
Send a job report if desired.
Review the summary and click on
Finishto launch the restoration and recovery.
From RAC DB VM ora01, validate that a successful restore/recovery of database rolled forward to its most recent state and recovered the test table created 3 days later.
[root@ora01 ~]# su - oracle [oracle@ora01 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Mon Aug 19 11:51:15 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- NTAP READ WRITE SQL> sho pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP_PDB1 READ WRITE NO 4 NTAP_PDB2 READ WRITE NO 5 NTAP_PDB3 READ WRITE NO SQL> alter session set container=ntap_pdb1; Session altered. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 19-AUG-24 10.36.04.000000 AM validate SnapCenter rac database restore on VMware vVols storage SQL> select current_timestamp from dual; CURRENT_TIMESTAMP --------------------------------------------------------------------------- 19-AUG-24 11.55.20.079686 AM -04:00 SQL> exit Disconnected from Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0
This completes the demonstration of SnapCenter backup, restore, and recovery of Oracle RAC database in VCF with vVols.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
