Configure replication relationships on FSx for ONTAP file systems
You can find additional information about SnapMirror configuration options in the ONTAP documentation at SnapMirror replication workflow (netapp.com).
Source FSx for ONTAP file system:
FsxId00fa9e3c784b6abbb -
Source SVM:
sapcc-hana-svm -
Target FSx for ONTAP file system:
FsxId05f7f00af49dc7a3e -
Target SVM:
sapcc-backup-target-zone5
Peer FSx for ONTAP file systems
FsxId00fa9e3c784b6abbb::> network interface show -role intercluster
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
inter_1 up/up 10.1.1.57/24 FsxId00fa9e3c784b6abbb-01
e0e true
inter_2 up/up 10.1.2.7/24 FsxId00fa9e3c784b6abbb-02
e0e true
2 entries were displayed.
FsxId05f7f00af49dc7a3e::> network interface show -role intercluster
inter_1 up/up 10.1.2.144/24 FsxId05f7f00af49dc7a3e-01
e0e true
inter_2 up/up 10.1.2.69/24 FsxId05f7f00af49dc7a3e-02
e0e true
FsxId05f7f00af49dc7a3e::> cluster peer create -address-family ipv4 -peer-addrs 10.1.1.57, 10.1.2.7 Notice: Use a generated passphrase or choose a passphrase of 8 or more characters. To ensure the authenticity of the peering relationship, use a phrase or sequence of characters that would be hard to guess. Enter the passphrase: Confirm the passphrase: Notice: Now use the same passphrase in the "cluster peer create" command in the other cluster.
peer-addrs are cluster IPs of the destination cluster.
FsxId00fa9e3c784b6abbb::> cluster peer create -address-family ipv4 -peer-addrs 10.1.2.144, 10.1.2.69
FsxId00fa9e3c784b6abbb::> cluster peer show
Peer Cluster Name Cluster Serial Number Availability Authentication
FsxId05f7f00af49dc7a3e 1-80-000011 Available ok
Peer SVMs
FsxId05f7f00af49dc7a3e::> vserver peer create -vserver sapcc-backup-target-zone5 -peer-vserver sapcc-hana-svm -peer-cluster FsxId00fa9e3c784b6abbb -applications snapmirror Info: [Job 41] 'vserver peer create' job queued
FsxId00fa9e3c784b6abbb::> vserver peer accept -vserver sapcc-hana-svm -peer-vserver sapcc-backup-target-zone5 Info: [Job 960] 'vserver peer accept' job queued
FsxId05f7f00af49dc7a3e::> vserver peer show
Peer Peer Peering Remote
Vserver Vserver State Peer Cluster Applications Vserver
peer-source-cluster
peered FsxId00fa9e3c784b6abbb
snapmirror sapcc-hana-svm
Create a target volume
You must create the target volume with the type DP to flag it as a replication target.
FsxId05f7f00af49dc7a3e::> volume create -vserver sapcc-backup-target-zone5 -volume PFX_data_mnt00001 -aggregate aggr1 -size 100GB -state online -policy default -type DP -autosize-mode grow_shrink -snapshot-policy none -foreground true -tiering-policy all -anti-ransomware-state disabled [Job 42] Job succeeded: Successful
Create a SnapMirror policy
The SnapMirror policy and the added rule define the retention and the Snapmirror label to identify Snapshots that should be replicated. When creating the SnapCenter policy later, you must use the same label.
FsxId05f7f00af49dc7a3e::> snapmirror policy create -policy snapcenter-policy -tries 8 -transfer-priority normal -ignore-atime false -restart always -type vault -vserver sapcc-backup-target-zone5
FsxId05f7f00af49dc7a3e::> snapmirror policy add-rule -vserver sapcc-backup-target-zone5 -policy snapcenter-policy -snapmirror-label snapcenter -keep 14
FsxId00fa9e3c784b6abbb::> snapmirror policy showVserver Policy Policy Number Transfer
Name Name Type Of Rules Tries Priority Comment
snapcenter-policy vault 1 8 normal -
SnapMirror Label: snapcenter Keep: 14
Total Keep: 14
Create SnapMirror relationship
Now the relation between the source and target volume is defined as well as the type XDP and the policy we created earlier.
FsxId05f7f00af49dc7a3e::> snapmirror create -source-path sapcc-hana-svm:PFX_data_mnt00001 -destination-path sapcc-backup-target-zone5:PFX_data_mnt00001 -vserver sapcc-backup-target-zone5 -throttle unlimited -identity-preserve false -type XDP -policy snapcenter-policy Operation succeeded: snapmirror create for the relationship with destination "sapcc-backup-target-zone5:PFX_data_mnt00001".
Initialize SnapMirror
With this command, the initial replication starts. This is a full transfer of all data from the source volume to the target volume.
FsxId05f7f00af49dc7a3e::> snapmirror initialize -destination-path sapcc-backup-target-zone5:PFX_data_mnt00001 -source-path sapcc-hana-svm:PFX_data_mnt00001 Operation is queued: snapmirror initialize of destination "sapcc-backup-target-zone5:PFX_data_mnt00001".
You can check the status of the replication with the snapmirror show command.
FsxId05f7f00af49dc7a3e::> snapmirror show
Progress
Source Destination Mirror Relationship Total Last
Path Type Path State Status Progress Healthy Updated
XDP sapcc-backup-target-zone5:PFX_data_mnt00001
Uninitialized
Transferring 1009MB true 02/24 12:34:28
Progress
Snapmirrored
Idle - true -
