Learn about SnapCenter supported configurations for SAP HANA
SnapCenter supports a wide range of SAP HANA system architectures and deployment scenarios across on-premises and cloud storage platforms. Learn about supported SAP HANA configurations, platform combinations, storage protocols, and available backup and restore operations for each environment.
Supported SAP HANA configurations
SnapCenter supports the following HANA configurations and features:
SAP HANA single host systems
SAP HANA multiple host systems
Requires a central plug-in deployment as described in "Deployment options for SnapCenter plug-in for SAP HANA".
SAP HANA MDC systems
with a single or with multiple tenants
SAP HANA systems with multiple partitions
SAP HANA System Replication
SAP HANA encryption (data, log, backup)
Supported platform and infrastructure configurations
SnapCenter supports the following combinations of host platforms, file systems and storage platforms.
| Host platform | SAP HANA storage connection and file system | Storage platform |
VMware |
In-guest NFS mounts |
ONTAP AFF |
VMware |
FC datastore with VMFS |
ONTAP AFF or ASA |
KVM |
ONTAP AFF |
Bare metal server |
NFS mounts |
ONTAP AFF |
Bare metal server |
FC SAN |
ONTAP AFF or ASA (*) |
Azure VM |
NFS mounts |
Azure NetApp Files |
AWS EC2 |
NFS mounts |
FSx for ONTAP |
(*): ASA support available starting with SnapCenter 6.2 release
The HANA and Linux plug-ins are only available for the Intel CPU platform. For Linux on IBM Power a central HANA plug-in deployment needs to be setup as described in "Deployment options for SnapCenter plug-in for SAP HANA". |
Supported features and operations
Abbreviation explanation
VBSR: Volume based SnapRestore
A volume based SnapRestore reverts the volume back to the state of the Snapshot. -
SFSR: Single file SnapRestore
A single file SnapRestore can be used to restore specific file(s) or LUN(s) within a volume.
ONTAP AFF and FSx for ONTAP
Only column 1 (NFS mounts) of the table below is relevant for FSx for ONTAP. |
| Operation | NFS mounts Bare metal or in-guest with VMware or KVM |
FC SAN Bare metal |
FC datastore VMware VMFS |
Snapshot backup and restore operations for HANA database |
Snapshot backup |
Yes |
Yes |
Yes |
Tamperproof Snapshot |
Yes |
Yes |
Yes |
Full restore |
VBSR or SFSR (selectable) |
SFSR of complete LUN |
Clone, mount, copy |
Single tenant restore |
SFSR |
SnapVault backup and restore operations for HANA database |
SnapVault replication |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Full restore |
Yes |
Yes |
Yes |
HANA recovery operation from primary Snapshot or SnapVault target |
Automated recovery MDC single tenant |
Yes |
Yes |
Yes |
Automated recovery MDC multiple tenants |
No |
No |
No |
Backup and restore non-data volumes |
Snapshot backup |
Yes |
Yes |
Yes (*) |
Restore from Snapshot |
VBSR (*) |
Yes |
Yes |
Yes (*) |
Restore from SnapVault target |
Yes |
Yes |
Yes (*) |
SAP System Refresh |
From primary Snapshot |
Yes |
Yes (**) |
Yes (**) |
From SnapVault target |
Yes |
Yes (**) |
Yes (**) |
HA and DR |
HSR support Snapshots and SnapVault |
Yes |
Yes |
Yes |
SnapMirror replication updates with SC |
Yes |
Yes |
Yes |
SnapMirror active sync |
NA |
Yes |
Yes |
(*): No VMware integration - crash image Snapshot and full volume restore
(**): Workarounds required for SnapCenter releases < 6.2
ONTAP ASA
| Operation | FC SAN Bare metal (*) |
Snapshot backup |
Yes |
Yes |
No |
No |
Full restore |
Yes |
Yes |
No |
No |
Full restore |
Yes |
Yes |
Yes |
No |
No |
Snapshot backup |
Yes |
Yes (*) |
SFSR of complete LUN (*) |
Yes |
Yes (*) |
Yes |
Yes (*) |
Yes |
Yes (**) |
Yes |
Yes (**) |
HA and DR |
Yes |
Yes |
SnapMirror replication updates triggered by SnapCenter |
Yes |
Yes |
Yes |
Yes |
(*): Support starting with SnapCenter 6.2 release
Azure NetApp Files
| Operation | NFS mounts |
Snapshot backup |
Yes |
No |
Full in-place restore |
Volume revert or SFSR (selectable) |
SFSR |
ANF backup and restore operations for HANA database |
ANF backup replication |
Yes |
No |
Yes |
Yes |
HANA recovery operation from primary Snapshot or ANF backup |
Yes |
No |
Snapshot backup |
Yes |
Volume revert |
Yes |
Full in-place restore from ANF backup |
No (*) |
Yes |
From ANF backup |
Yes |
HA and DR |
HSR support Snapshots and ANF backup |
Yes |
Cross region replication update triggered by SnapCenter |
No |
(*): With the current version, a restore operation must be done using Azure portal or CLI
