Deployment requirements for SAP HANA on SUSE KVM with NetApp storage
Review the requirements for deploying SAP HANA Single-Host on SUSE KVM using NetApp storage with SR-IOV network interfaces and NFS or FCP storage protocols.
The deployment requires certified SAP HANA servers, NetApp storage systems, SR-IOV capable network adapters, and SUSE Linux Enterprise Server for SAP Applications as the KVM host.
Infrastructure requirements
Make sure the following components and configurations are in place:
Certified SAP HANA servers and NetApp storage systems. Refer to the SAP HANA Hardware Directory for available options:
SUSE Linux Enterprise Server for SAP Applications 15 SP5/SP6 as the KVM host
NetApp ONTAP storage system with Storage Virtual Machine (SVM) configured for NFS and/or FCP traffic
Logical interfaces (LIFs) created on the appropriate networks for NFS and FCP traffic
SR-IOV capable network adapters (e.g., Mellanox ConnectX series)
Fibre Channel HBA adapters for FCP storage access
Network infrastructure supporting the required VLANs and network segments
VM configured according to the SUSE Best Practices for SAP HANA on KVM
Important considerations
SR-IOV shall be used for SAP HANA network communication and for storage access using NFS if possible, but bridged networking is supported as well. Each virtual function (VF) assigned to a VM requires at least 10 Gbit/s bandwidth.
Physical FCP HBA ports must be assigned to the VM as PCI devices for using FCP LUNs. A physical port can only be assigned to one VM.
SAP HANA Multiple-Host systems are not supported in this configuration.
Additional resources
For the latest information including supported CPU architecture and limitations, refer to the SAP Note 3741904 - SAP HANA on SUSE KVM Virtualization with SLES 15 SP7 - SAP for Me.
For information about configuring ONTAP storage systems, refer to the ONTAP 9 documentation.
For SAP HANA storage configuration with NetApp systems, refer to the NetApp SAP solutions documentation.
What's next?
After you've reviewed the deployment requirements, configure SR-IOV network interfaces.
