NetApp solutions for SAP
Supported infrastructure and scenarios
Contributors netapp-nbauer kevin-hoke
This document covers SAP system refresh and cloning scenarios for SAP HANA systems running on on-premises NetApp systems, on Amazon FSx for NetApp ONTAP systems and on Azure NetApp Files. However not all features and scenarios are available on every storage platform. The table below summarizes the supported configurations.
Within the document, we are using an SAP HANA landscape running on on-premises NetApp systems with NFS as the storage protocol. Most workflow steps are identical across the different platforms, and if there are differences, they are highlighted in this document.
On-premises NetApp systems AWS FSx for NetApp ONTAP Azure NetApp Files
Storage protocol and file system
Bare metal: NFS, FC with XFS
VMware: NFS in-guest mounts, FC with VMDKs and XFS
NFS
NFS
Thin clone (FlexClone)
Yes
Yes
Yes, but not integrated into SnapCenter
Clone split operation
Yes
Yes
Cloning from primary
Yes
Yes
Yes
Cloning from off-site backup
Yes
Yes
Yes, restore to new volume from ANF backup
Cloning at DR site
Yes
Yes
Additional information on SAP system refresh operations for HANA with VMware VMFS and NetApp ASAr2 systems can be found at SAP System Refresh.
