Supported versions for the NetApp Shift Toolkit
Verify that your Windows and Linux guest operating systems, ONTAP version, and hypervisors are supported by the NetApp Shift Toolkit.
Supported VM guest operating systems
The Shift Toolkit supports the following Windows and Linux guest operating systems for VM conversion.
Windows 10
Windows 11
Windows Server 2016
Windows Server 2019
Windows Server 2022
Windows Server 2025
CentOS Linux 7.x
Alma Linux 7.x
Red Hat Enterprise Linux 7.2 or later
Red Hat Enterprise Linux 8.x
Red Hat Enterprise Linux 9.x
Ubuntu 2018
Ubuntu 2022
Ubuntu 2024
Debian 12
SUSE Linux Enterprise Server 12
SUSE Linux Enterprise Server 15
CentOS Linux and Red Hat Enterprise Linux versions 5 and 6 are not supported. |
Windows Server 2008 is not officially supported. However, the conversion process may work, and some customers have successfully converted Windows Server 2008 VMs. After migration, manually update the IP address, as the PowerShell version used for IP assignment automation is not compatible with Windows Server 2008. |
Supported ONTAP versions
The Shift Toolkit supports ONTAP 9.14.1 or later.
Supported hypervisors
The Shift Toolkit supports the following hypervisor platforms for VM migration and conversion.
In the current release, end-to-end virtual machine migration is supported only with Hyper-V, VMware, OpenShift, Oracle Virtualization. For KVM destinations, only disk conversion is supported. |
The Shift toolkit is validated against vSphere 7.0.3 or later.
The Shift toolkit is validated against the following Hyper-V roles:
Hyper-V role running on Windows Server 2019
Hyper-V role running on Windows Server 2022
Hyper-V role running on Windows Server 2025
The Shift toolkit is validated against Red Hat OpenShift and OpenShift Virtualization running 4.17 and later.
The Shift toolkit is validated against the following Oracle Linux Virtualization Manager versions:
Oracle Linux Virtualization Manager 4.5 or later
The Oracle Linux Virtualization Manager host must have ovirt-engine-4.5.4-1.el8 RPM or later installed
For KVM destinations, the Shift Toolkit supports disk format conversion only (VMDK to QCOW2 or RAW). Hypervisor connection details are not required when selecting KVM from the destination dropdown. After conversion, use the QCOW2 disks to provision VMs on KVM-based platforms.
The Shift toolkit is validated against Proxmox VE running 9.X and later.
