Configure LVM Thin with ONTAP NVMe/TCP for OpenNebula
Configure Logical Volume Manager (LVM) datastore for shared storage across OpenNebula hosts using NVMe over TCP protocol with NetApp ONTAP. This configuration provides high-performance block-level storage access over standard Ethernet networks using the modern NVMe protocol.
Initial virtualization administrator tasks
Complete these initial tasks to prepare OpenNebula hosts for NVMe/TCP connectivity and collect the necessary information for the storage administrator.
Verify two Linux VLAN interfaces are available.
On every OpenNebula host, run the following command to collect the host initiator information.
nvme show-hostnqn -
Provide the collected host NQN information along with hostname to the storage administrator and request an NVMe namespace of the required size.
Storage administrator tasks
If you are new to ONTAP, use System Manager for a better experience.
Ensure the SVM is available with NVMe protocol enabled. Refer to NVMe tasks on ONTAP 9 documentation.
Create the NVMe namespace.
Create the subsystem and assign to host NQNs. Create one subsystem for all OpenNebula hosts in a cluster and also to Frontend servers. Frontend servers are optional in subsystem assignment but required for Image datastores.
Ensure Anti-Ransomware protection is enabled on the security tab.
Notify the virtualization administrator that the NVMe namespace is created.
Final virtualization administrator tasks
Complete these tasks to configure the NVMe namespace as shared LVM datastore in OpenNebula.
Navigate to a shell on each OpenNebula host in the cluster and create the /etc/nvme/discovery.conf file. Update the content specific to your environment.
root@onehost01:~# cat /etc/nvme/discovery.conf # Used for extracting default parameters for discovery # # Example: # --transport=<trtype> --traddr=<traddr> --trsvcid=<trsvcid> --host-traddr=<host-traddr> --host-iface=<host-iface> -t tcp -l 1800 -a 172.21.118.153 -t tcp -l 1800 -a 172.21.118.154 -t tcp -l 1800 -a 172.21.119.153 -t tcp -l 1800 -a 172.21.119.154 -
Log in to the NVMe subsystem.
nvme connect-all -
To persist the NVMe namespace across reboots, enable nvmf-autoconnect service.
systemctl enable nvmf-autoconnect -
Inspect and collect device details.
nvme list nvme netapp ontapdevices nvme list-subsys lsblk -N -
SSH to one of the fronend server and create a configuration file based on desired Datastore type. For complete attribute list, refer OpenNebula LVM documentation. Sample files are shown below:
Backup-
For Restic,
$cat nvmetcp-restic.conf NAME = "Backup-Restic-NVMETCP" TYPE = "BACKUP_DS" DS_MAD = "restic" TM_MAD = "-" RESTIC_PASSWORD = "<restic_password>" RESTIC_SFTP_SERVER = "<backup server>"
For Rsync,
$cat nvmetcp-rsync.conf NAME = "Backup-Rsync-NVMETCP" TYPE = "BACKUP_DS" DS_MAD = "rsync" TM_MAD = "-" RSYNC_USER = "<rsync_user>" RSYNC_HOST = "<backup server>"
File$cat nvmetcp-kernel.conf NAME = "File-Kernel-NVMETCP" TYPE = "FILE_DS" DS_MAD = "fs" TM_MAD = "local" SAFE_DIRS = "/var/tmp/files"Image$cat nvmetcp-image.conf NAME = "Image-NVMETCP01" TYPE = "IMAGE_DS" DS_MAD = "fs" TM_MAD = "fs_lvm_ssh" DISK_TYPE = "block" LVM_THIN_ENABLE = "yes"System$cat nvmetcp-system.conf NAME = "System-NVMETCP02" TYPE = "SYSTEM_DS" TM_MAD = "fs_lvm_ssh" DISK_TYPE = "block" BRIDGE_LIST = "<space-separated list of OpenNebula hosts>" # If NVMe namespace not presented to frontend hosts LVM_THIN_ENABLE = "yes" -
Execute
onedatastore create <configuration file>. Note the datastore ID returned after creation.onedatastore create nvmetcp-system.conf
Create volume group on the NVMe namespace using
vgcreate <vg_name> <nvme_device>command. For Image datastores, the volume group name can be named anything desired. For System datastores, the volume group name must be of formatvg-one-<datastore id>. This is required for OpenNebula to identify the correct volume group for system datastores. Proceed with following steps if you are creating Backup/File/Image datastore. For system datastores, stop here. -
Create logical volume thin pool using
lvcreate -l 100%FREE -n <logical volume name> <volume group name>command. For System datastores, OpenNebula automatically creates the LVM thin pool when required. -
Create filesystem on the logical volume using
mkfs.ext4 /dev/<volume group>/<logical volume>command. System datastores do not require filesystem creation. -
Update /etc/fstab or automount configuration to mount the datastore with desired mount options. Assuming the default datastore location as /var/lib/one/datastores. Can be validated with
onedatastore show <datastore_id>. If not check the DATASTORE_LOCATION parameter in /etc/one/oned.conf. Ensure the <datastore_id> folder exists under the datastores location. Sample entries are shown below:Using /etc/fstab/dev/<vg name>/<logical volume> /var/lib/one/datastores/<datastore_id> ext4 _netdev,noauto,x-systemd.automount,nofail 0 2Using automount/var/lib/one/datastores/<datastore_id> -fstype=ext4,_netdev,noauto,x-systemd.automount,nofail,rw :/dev/<vg name>/<logical volume> -
Mount the datastore using
mount -aorsystemctl reload autofscommand. -
Verify the datastore is mounted with mount command and verify the datastore capacity with
onedatastore show <datastore_id>command. -
Ensure oneadmin user and group own the datastore folder. Adjust permissions using
chown -R oneadmin:oneadmin /var/lib/one/datastores/<datastore_id>command.
