Create a VM from a snapshot copy with Red Hat OpenShift Virtualization
Create a VM from a snapshot with OpenShift Virtualization. This procedure includes creating a VolumeSnapshotClass, taking a snapshot of the VM's persistent volume claim (PVC), restoring the snapshot to a new PVC, and deploying a new VM that uses the restored PVC as the root disk.
Create VM from a Snapshot
With Trident and Red Hat OpenShift, users can take a snapshot of a persistent volume on Storage Classes provisioned by it. With this feature, users can take a point-in-time copy of a volume and use it to create a new volume or restore the same volume back to a previous state. This enables or supports a variety of use-cases, from rollback to clones to data restore.
For Snapshot operations in OpenShift, the resources VolumeSnapshotClass, VolumeSnapshot, and VolumeSnapshotContent must be defined.
A VolumeSnapshotContent is the actual snapshot taken from a volume in the cluster. It is cluster-wide resource analogous to PersistentVolume for storage.
A VolumeSnapshot is a request for creating the snapshot of a volume. It is analogous to a PersistentVolumeClaim.
VolumeSnapshotClass lets the administrator specify different attributes for a VolumeSnapshot. It allows you to have different attributes for different snapshots taken from the same volume.
To create Snapshot of a VM, complete the following steps:
Create a VolumeSnapshotClass that can then be used to create a VolumeSnapshot. Navigate to Storage > VolumeSnapshotClasses and click Create VolumeSnapshotClass.
Enter the name of the Snapshot Class, enter csi.trident.netapp.io for the driver, and click Create.
Identify the PVC that is attached to the source VM and then create a Snapshot of that PVC. Navigate to
Storage > VolumeSnapshotsand click Create VolumeSnapshots. -
Select the PVC that you want to create the Snapshot for, enter the name of the Snapshot or accept the default, and select the appropriate VolumeSnapshotClass. Then click Create.
This creates the snapshot of the PVC at that point in time.
Create a new VM from the snapshot
First, restore the Snapshot into a new PVC. Navigate to Storage > VolumeSnapshots, click the ellipsis next to the Snapshot that you wish to restore, and click Restore as new PVC.
Enter the details of the new PVC and click Restore. This creates a new PVC.
Next, create a new VM from this PVC. Navigate to Virtualization > Virtual Machines and click Create > With YAML.
In the spec > template > spec > volumes section, specify the new PVC created from Snapshot instead of from the container disk. Provide all other details for the new VM according to your requirements.
- name: rootdisk persistentVolumeClaim: claimName: rhel8-short-frog-rootdisk-28dvb-snapshot-restore -
Click Create to create the new VM.
After the VM is created successfully, access and verify that the new VM has the same state as that of the VM whose PVC was used to create the snapshot at the time when the snapshot was created.
