Migrate a VM from VMware to Red Hat OpenShift cluster
Contributors banum-netapp reno netapp-jsnyder kevin-hoke
Migrate VMs from VMware to an OpenShift cluster using the OpenShift Virtualization migration toolkit. This migration involves installing the Migration Toolkit for Virtualization (MTV), creating source and destination providers, creating a migration plan, and performing a cold or warm migration.
Cold Migration
This is the default migration type. The source virtual machines are shut down while the data is copied.
Warm Migration
In this type of migration, most of the data is copied during the precopy stage while the source virtual machines (VMs) are running. Then the VMs are shut down and the remaining data is copied during the cutover stage.
Video Demonstration
The following video shows a demonstration of the cold migration of a RHEL VM from VMware to OpenShift Virtualization using ontap-san storage class for persistent storage.
Using Red Hat MTV to migrate VMs to OpenShift Virtualization with NetApp ONTAP Storage
Migration of VM from VMware to OpenShift Virtualization using Migration Toolkit for Virtualization
This section describes how to use the Migration Toolkit for Virtualization (MTV) to migrate virtual machines from VMware to OpenShift Virtualization running on OpenShift Container Platform and integrated with NetApp ONTAP storage using Trident.
The following diagram shows a high-level view of the migration of a VM from VMware to Red Hat OpenShift Virtualization.
Figure showing input/output dialog or representing written content
Prerequisites for the sample migration
On VMware
  • A RHEL 9 VM using RHEL 9.3 with the following configurations was installed:
    • CPU: 2, Memory: 20 GB, Hard disk: 20 GB
    • User credentials: root user and admin user
  • After the VM was ready, PostgreSQL server was installed.
    • PostgreSQL server was started and enabled to start on boot
systemctl start postgresql.service
systemctl enable postgresql.service
These commands ensure that the server can start in the VM in OpenShift Virtualization after migration.
  • Added 2 databases, 1 table, and 1 row to the table. Refer to here for instructions on installing PostgreSQL server on RHEL and creating database and table entries.
Note Ensure that you start the PostgreSQL server and enable the service to start at boot.
On OpenShift Cluster
The following installations were completed before installing MTV:
  • OpenShift Cluster 4.17 or later
  • Multipath on the cluster nodes enabled for iSCSI (for ontap-san storage class). Multi-pathing can be enabled easily if you install Trident 25.02 using the node-prep flag. You can refer to the Trident installation section for details.
  • Install the required backend and storage classes and the snapshot class. Refer to the Trident installation section for details.
  • OpenShift Virtualization
Install MTV
Now you can install the Migration Toolkit for Virtualization (MTV). Refer to the instructions provided here for help with the installation.
The Migration Toolkit for Virtualization (MTV) user interface is integrated into the OpenShift web console.
You can refer to here to start using the user interface for various tasks.
Create source provider
To migrate the RHEL VM from VMware to OpenShift Virtualization, you need to first create the source provider for VMware. Refer to the instructions here to create the source provider.
You need the following to create your VMware source provider:
  • vCenter URL
  • vCenter credentials
  • vCenter server thumbprint
  • VDDK image in a repository
Sample source provider creation:
Note The Migration Toolkit for Virtualization (MTV) uses the VMware Virtual Disk Development Kit (VDDK) SDK to accelerate transferring virtual disks from VMware vSphere. Therefore, creating a VDDK image, although optional, is highly recommended.
To make use of this feature, you download the VMware Virtual Disk Development Kit (VDDK), build a VDDK image, and push the VDDK image to your image registry.
Follow the instructions provided here to create and push the VDDK image to a registry accessible from the OpenShift Cluster.
Create destination provider
The host cluster is automatically added as the destination provider.
Create migration plan
Follow the instructions provided here to create a migration plan.
While creating a plan, you need to create the following if not already created:
  • A network mapping to map the source network to the target network.
  • A storage mapping to map the source datastore to the target storage class. For this, you can choose the ontap-san storage class.
    Once the migration plan is created, the status of the plan should show Ready and you should now be able to Start the plan.
Perform Cold Migration
Click Start to run through a sequence of steps and complete the migration of the VM.
When all steps are completed, you can see the migrated VMs by clicking on the Virtual Machines under Virtualization in the left-side navigation menu.
To manage the virtual machines, see the OpenShift Virtualization documentation.
You can log into the virtual machine and verify the contents of the PostgreSQL databases. The databases, tables, and the entries in the table should be the same as what was created on the source VM.
Perform Warm Migration
To perform a warm migration, after creating a migration plan as shown above, you need to edit the plan settings to change the default migration type. Click on the edit icon next to the cold migration and toggle the button to set it to warm migration. Click on Save. Now click on Start to start the migration.
Note Ensure that when you are moving from block storage in VMware, you have block storage class selected for the OpenShift Virtualization VM. Additionally, the volumeMode should be set to Block and access mode should be ReadWriteMany (RWX) so that you can perform live migration of the VM at a later time.
1
Click on 0 of 1 VMs completed, expand the VM, and you can see the progress of the migration.
2
After some time, the disk transfer is completed, and the migration waits to proceed to the Cutover state. The DataVolume is in a Paused state. Go back to the plan and click on the Cutover button.
3
4
The dialog box shows the current time. Change the time to schedule the cutover for a later time, or click Set cutover to perform the cutover immediately.
5
After a few seconds, the DataVolume goes from the Paused to the ImportScheduled to ImportInProgress state when the cutover phase starts.
6
When the cutover phase is completed, the DataVolume comes to the Succeeded state and the PVC is bound.
7
The migration plan proceeds to complete the ImageConversion phase and finally, the VirtualMachineCreation phase is completed. The VM comes to the Running state on OpenShift Virtualization.
8
