Design options with VMware Cloud Foundation and ONTAP
Contributors sureshthoppay reno
You can start fresh with VCF 9 or reuse existing deployments to create a Private Cloud environment using VCF 9 and ONTAP. Learn about popular design blueprints for VCF 9 and how NetApp products add value.
Storage options
VMware Cloud Foundation with ONTAP supports a variety of storage configurations to meet different performance, scalability, and availability requirements. The following tables summarize principal and supplemental storage options available for your environment.
Table 1. Principal storage options
Product Family VMFS on FC NFSv3
ASA A-Series and C-Series
Yes
No
AFX
No
Yes
AFF A-Series and C-Series
Yes
Yes
FAS
Yes
Yes
Table 2. Supplemental storage options
Product Family VMFS on FC VMFS on iSCSI VMFS on NVMe-oF NFSv3 NFSv4.1
Yes
Yes
Yes
No
No
AFX
No
No
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes
FAS
Yes
Yes
Yes
Yes
Yes
Blueprints
The following blueprints illustrate common deployment models for VMware Cloud Foundation and ONTAP in various site and resource scenarios.
VCF fleet in a single site with minimal footprint
This design blueprint is for deploying Management and Workload components in a Single vSphere Cluster with minimal resources. It supports VMFS and NFSv3 Principal Datastores and a simple deployment option with a two-node configuration.
VCF Fleet in a Single Site with Minimal Footprint
To minimize resource consumption, use an existing ONTAP tools instance if possible. If unavailable, a single node with a Small profile is suitable. The SnapCenter Plug-in for VMware vSphere protects virtual machines and Datastores using native snapshots and replication to another ONTAP storage array.
Note If you lack resources to explore VCF, many Cloud Providers offer VCF as a service, and ONTAP is available as a first-party service from cloud providers.
This design blueprint is for customers with a single Primary Datacenter relying on application High Availability. Typically, it involves a single VCF environment. You can use ASA for block workloads and AFF for file/unified workloads.
Content Repository shares VM templates and container registries across VCF Domains. When hosted on FlexGroup Volume, FlexCache feature is available for subscription datastore.
Caution Hosting VMs on FlexCache Datastore is not supported.
A single instance of ONTAP tools in HA mode can manage all vCenters in the VCF Fleet. Refer to the Configuration Limits of ONTAP tools for more info. ONTAP tools integrate with VCF SSO and VCF OPS smart grouping for multi-vCenter access in the same UI.
VCF Supplemental Datastore with ONTAP Tools
You must deploy the SnapCenter Plug-in on each vCenter instance for VM and Datastore protection.
Storage policy-based Management is used with vSphere Supervisor to host control VMs of VKS. Tags are centrally managed at VCF Ops. NetApp Trident CSI is used with VKS for application backup protection using native array features. When you use vSphere CSI, persistent volume details appear on vCenter as well as on VCF Automation.
For more details on this blueprint, refer to the Broadcom Technical Documentation on VCF Fleet in a Single Site.
VCF fleet with multiple sites in a single region
This design is for customers providing cloud-like services with higher availability by spreading workloads across different fault domains.
For VMFS datastores, SnapMirror active sync provides an active-active storage unit for use with vSphere Metro Storage Cluster. Uniform access mode offers transparent storage failover, while Non-Uniform access mode requires VM restart on fault domain failure.
For NFS datastores, SnapMirror active sync for NAS (with ONTAP 9.19.1 & above) or ONTAP MetroCluster with vSphere Metro Storage Cluster ensures high availability. A mediator avoids split-brain scenarios and can now be hosted on NetApp Console.
VM placement rules control VMs within the same fault domain for Management Domain components.
VCF Fleet with Multiple Sites in a Single Region
ONTAP tools provide a UI to set up SnapMirror active sync relationships for iSCSI and FC. Storage Systems of both fault domains must be registered in ONTAP tools and SnapCenter Plug-in for VMware vSphere.
You can implement 3-2-1 backup policies using NetApp Backup and Recovery for VMs via SnapMirror and SnapMirror to Cloud. You can perform restores from any of the three locations.
Trident Protect or NetApp Console Backup and Recovery for Kubernetes protect VKS Cluster Applications.
VCF fleet with multiple sites across multiple regions
This design is for customers spread globally, providing services in close proximity and disaster recovery solutions.
You can manage Disaster Recovery for VMs with VMware Protect and Recovery or NetApp Console Disaster Recovery. ONTAP tools offer the SRA (Storage Replication Adapter) to orchestrate storage operations with ONTAP.
Product Family SnapMirror active sync SnapMirror active sync for NAS MetroCluster
Yes
No
Yes
AFX
No
Yes
NA
Yes
Yes
Yes
FAS
No
No
Yes
VCF Fleet with Multiple Sites across Multiple Regions
ONTAP tools provide a UI for datastore replication setup. NetApp Console can also be used for replication between storage arrays. SnapCenter Plug-in for VMware vSphere utilizes existing SnapMirror relationships for SnapShots.
VCF fleet with multiple sites in a single region plus additional regions
This design addresses both availability and disaster recovery of VMs and VKS applications.
ASA, AFX, AFF, and FAS support this design option.
VCF Fleet with Multiple Sites in a Single Region plus Additional Regions
You can use ONTAP tools or NetApp Console to set up the replication relationship.
