Deployment requirements for adding an iSCSI datastore to a VCF management domain
Contributors netapp-jsnyder netapp-lhalbert sureshthoppay
Review the requirements for adding iSCSI datastores as supplemental storage to a VMware Cloud Foundation (VCF) management domain.
Infrastructure requirements
Make sure the following components and configurations are in place.
  • An ONTAP AFF or ASA storage system with physical data ports on Ethernet switches dedicated to storage traffic.
  • VCF management domain deployment is complete and the vSphere web client is accessible.
You should configure fully redundant network designs for iSCSI. The following diagram shows an example of a redundant configuration, providing fault tolerance for storage systems, switches, networks adapters and host systems. Refer to the NetApp SAN configuration reference for additional information.
iSCSI network design
For multipathing and failover across multiple paths, create a minimum of two LIFs per storage node in separate Ethernet networks for all SVMs in iSCSI configurations. With ONTAP 9.19.1 and later, you can enable symmetric active-active multipathing option on SVMs on AFF. In ASA, symmetric active-active multipathing is enabled by default.
Tip In situations where multiple VMkernel adapters are configured on the same IP network, it is recommended to use software iSCSI port binding on the ESXi hosts to ensure that load balancing across the adapters occurs. Refer to KB article Considerations for using software iSCSI port binding in vSphere.
What's next?
After reviewing the deployment requirements, create the SVM and LIFs.
