Configure networking for NFS on vSphere hosts in a VCF workload domain
Configure NFS networking on vSphere hosts in VMware Cloud Foundation workload domains to enable connectivity to ONTAP storage systems. You'll create distributed port groups with VLAN separation, configure uplink teaming for redundancy, and set up VMkernel adapters on each vSphere host to establish dedicated NFS paths for failover capabilities.
Perform the following steps on the workload domain cluster using the vSphere client. In this case vCenter Single Sign-On is being used so the vSphere client is common across the management and workload domains.
Step 1: Create a distributed port group for NFS traffic
Complete the following steps to create a new distributed port group for the network to carry NFS traffic.
From the vSphere client , navigate to Inventory > Networking for the workload domain. Navigate to the existing Distributed Switch and choose the action to create New Distributed Port Group….
Show example
In the New Distributed Port Group wizard, fill in a name for the new port group and click Next to continue.
On the Configure settings page, fill out all settings. If VLANs are being used be sure to provide the correct VLAN ID. Click Next to continue.
Show example
On the Ready to complete page, review the changes and click Finish to create the new distributed port group.
Once the port group has been created, navigate to the port group and select the action to Edit settings….
Show example
On the Distributed Port Group - Edit Settings page, navigate to Teaming and failover in the left-hand menu. Enable teaming for the uplinks to be used for NFS traffic by ensuring they are together in the Active uplinks area. Move any unused uplinks down to Unused uplinks.
Show example
Repeat this process for each vSphere host in the cluster.
Step 2: Create a VMkernel adapter on each vSphere host
Create a VMkernel adapter on each vSphere host in the workload domain.
From the vSphere client navigate to one of the vSphere hosts in the workload domain inventory. From the Configure tab select VMkernel adapters and click Add Networking… to start.
Show example
On the Select connection type window, choose VMkernel Network Adapter and click Next to continue.
Show example
On the Select target device page, choose one of the distributed port groups for NFS that was created previously.
Show example
On the Port properties page, keep the defaults (no enabled services) and click Next to continue.
On the IPv4 settings page, fill in the IP address, Subnet mask, and provide a new gateway IP address (only if required). Click Next to continue.
Show example
Review your selections on the Ready to complete page and click Finish to create the VMkernel adapter.
Show example
What's next?
After you configure networking for NFS on all vSphere hosts in the workload domain, configure storage for NFS vVols.
