Migrate VMs using the Shift Toolkit
Contributors kevin-hoke netapp-jsnyder
Use the Shift Toolkit to migrate VMs between virtualization platforms. The process involves preparing the VMs, converting disk formats, and configuring network settings on the target environment.
Migration workflow
After creating a blueprint, you can initiate the migration process. During migration, the Shift Toolkit performs a series of steps to convert disk formats and create virtual machines on the target host as defined in the blueprint.
The Shift Toolkit performs the following steps during migration:
  1. Delete existing snapshots for all VMs in the blueprint
  2. Trigger VM snapshots for the blueprint at the source
  3. Trigger volume snapshot before disk conversion
  4. Clone and convert VMDK to VHDx format for all VMs
  5. Power on VMs in the protection group at the target
  6. Register the networks on each VM
  7. Remove VMware Tools and assign IP addresses using trigger scripts or cron jobs depending on the OS type
Network tips and considerations
Consider the following network requirements and behaviors when planning your migration. The Shift Toolkit automatically copies network settings from source VMs and reapplies them to migrated VMs, but interface naming and network adapter configurations may vary between Windows and Linux systems.
General requirement
  • Ensure static IP addresses are available and not assigned to another VM
Windows VMs
  • The prepare script copies network configuration details (IP address space, gateway address, DNS servers)
  • The trigger script reapplies network settings during migration for single or multiple NICs based on blueprint mapping
  • After migration, Windows Device Manager may display old network adapter information from pre-migration, which doesn't affect the new adapter or cause IP conflicts
  • Upgrade to v4.0 to automatically remove orphaned network devices from the registry and Device Manager
Linux VMs
  • The prepare script copies network configuration details (IP address space, routes, DNS servers, network device names)
  • The script identifies the Linux distribution's networking type and applies IP settings accordingly
  • The network reassignment script is configured as a cron job using crontab and triggered on boot
  • The script reapplies network settings for single or multiple NICs based on blueprint mapping
Interface naming
  • Converted VMs may have interface names like eth0 or ensp0 instead of the source interface names (for example, ens192 or ens33)
  • The script updates network configuration details to match new interface names
  • If predictable names are used with proper udev matching rules and the interface name is retained on the target hypervisor, the script skips network configuration, removes VMware Tools, and reboots the VM
Note The Shift Toolkit allows overriding network preparation, enabling administrators to run custom scripts for IP assignment or other configurations.
Supported networking mechanisms
  • NetworkManager
  • Netplan
  • ifconfig
  • wicked
The Shift Toolkit retains IP addresses as specified in the blueprint.
Migration phases
The following are the migration phases you will follow to migrate VMs using the Shift Toolkit.
  1. Prepare VM: Prepare VMs for migration and verify that all prerequisites are completed.
  2. Migrate and validate: After preparation is complete, migrate VMware VMs to the target hypervisor.
    After migration completes, verify that VMs boot successfully and data has migrated properly.
  3. Test the migration: Test migration simulates the migration by converting the VMDK to the appropriate format and creating VMs using the converted virtual disk file on the qtree.
    Test migration does not include network mapping configuration, which should be performed manually to a test network.
Note The Shift Toolkit does not alter the source VM except for copying scripts needed for VM preparation. This allows for swift rollback in case of conversion failures.
Execute a migration
To trigger the migration workflow with the configuration specified in the blueprint, click Migrate.
Dialog showing how to trigger a VM migration
Once initiated, the workflow activates and the conversion process follows the outlined steps to register the VM. If VMs within the blueprint are not powered off, the Shift Toolkit prompts for a graceful shutdown before proceeding.
Migration process confirmation
Note NetApp recommends triggering no more than ten conversions in parallel from the same source to the same destination.
Migration progress
The conversion of VMDK to any file format completes in seconds, making this the fastest option available. This approach helps reduce VM downtime during migration.
Disk conversion progress
Once the job completes, the blueprint status changes to "Migration Complete".
Migration completed status
