Stretch Cluster with ONTAP for VCF Management Domains
In this scenario we will demonstrate how to use ONTAP Tools for VMware vSphere (OTV) to configure a stretch cluster for a VCF management and workload domains.
Author: Suresh Thoppay
Scenario Overview
The stretch cluster solution can be implemented on default cluster or on additional cluster in VCF management or workload domains. VMFS on FC is supported on both principal datastore and supplemental datastores. VMFS on iSCSI is only supported with supplemental datastores. Refer IMT for support of VMFS on NVMe-oF with SnapMirror active sync.
Principal storage on Management Domain
With VCF 5.2 onwards managment domain can be deployed without VSAN using the VCF import Tool. The convert option of VCF import tool allows an existing vCenter deployment into a management domain. All the clusters in vCenter will become part of management domain. Each cluster need to have its own distributed switch to convert. Till VCF import tool supports multiple network profiles, consider using stretch VLANs for vMotion network.
Deploy vSphere hosts
Deploy vCenter server on local datastore (vCenter needs to co-exist on vSphere hosts that will be converted into management domain)
Deploy ONTAP tools for VMware vSphere
Deploy SnapCenter Plugin for VMware vSphere (optional)
Create datastore (FC zone configuration should be in place)
Migrate VMs to newly created datastore
Protect the vSphere cluster
Whenever the cluster is expanded or shrank, need to update the Host Cluster relationship on ONTAP tools for the cluster to indicate the changes made to source or target. |
Supplemental storage on Management Domain
Once the management domain is up and running, additional datastores can be created using ONTAP tools which will trigger the consistency group expansion.
If a vSphere cluster is protected, all the datastores in the cluster will be protected. |
If VCF environment is deployed with Cloud Builder tool, to create the supplmentional storage with iSCSI, deploy ONTAP tools to create the iSCSI datastore and protect the vSphere cluster.
Additional information
For information on configuring ONTAP storage systems refer to the ONTAP 9 Documentation center.
For information on configuring VCF refer to VMware Cloud Foundation Documentation.
