Stretch Cluster with ONTAP for VCF VI Workload Domains
In this scenario we will demonstrate how to use ONTAP Tools for VMware vSphere (OTV) to configure a stretch cluster for a VCF VI workload domain.
Author: Suresh Thoppay
Scenario Overview
The datastores on VCF Workload domain can be protected with SnapMirror active sync to provide stretch cluster solution. The protection is enabled at vSphere cluster level and all ONTAP block datastores in the cluster will be protected.
Principal storage on Workload Domain
Workload domain can be created either importing using the VCF import tool or deploy using the SDDC manager. Deploying with SDDC manager will provide more networking options than importing an existing environment.
Create Workload domain with VMFS on FC
Register workload domain vCenter to ONTAP tools manager to deploy vCenter plugin
Register storage systems on ONTAP tools
Protect the vSphere cluster
Whenever the cluster is expanded or shrank, need to update the Host Cluster relationship on ONTAP tools for the cluster to indicate the changes made to source or target. |
Supplemental storage on Workload Domain
Once the workload domain is up and running, additional datastores can be created using ONTAP tools which will trigger the consistency group expansion.
If a vSphere cluster is protected, all the datastores in the cluster will be protected. |
Additional information
For information on configuring ONTAP storage systems refer to the ONTAP 9 Documentation center.
For information on configuring VCF refer to VMware Cloud Foundation Documentation.
