NetApp Cloud Docs
  • Home
  • More From NetApp
  • Netapp.com
  • NetApp.com
Menu bars
netapp-mark NetApp
Cloud Docs
  • English globe
Select Your Language
    • English
Current Language: English
  • Cloud Manager 3.6 docs
  • Release notes
    • Cloud Manager
      • What's new
      • Known issues
      • Known limitations
    • Cloud Volumes ONTAP
  • Concepts
    • Product overview
    • NetApp Cloud Central
    • Accounts and permissions
    • Storage
      • Overview
      • Data tiering
      • Storage management
      • WORM storage
    • High-availability pairs
      • HA pairs in AWS
      • HA pairs in Azure
    • Evaluating
    • Licensing
    • Security
    • Performance
  • Getting started
    • Deployment overview
    • Getting started in AWS
    • Getting started in Azure
    • Setting up Cloud Manager
      • Adding cloud provider accounts
      • Adding NetApp Support Site accounts
      • Installing an HTTPS certificate
      • Setting up users and tenants
      • Setting up the AWS KMS
    • Networking requirements
      • Cloud Manager
      • Cloud Volumes ONTAP for AWS
      • Setting up an AWS transit gateway
      • Cloud Volumes ONTAP for Azure
    • Additional deployment options
      • Cloud Manager host requirements
      • Installing Cloud Manager on a Linux host
      • Deploying Cloud Manager from the AWS Marketplace
      • Deploying Cloud Manager from the Azure Marketplace
      • Deploying Cloud Manager in an Azure Gov region
      • Deploying Cloud Manager in the Azure Germany region
      • Getting started in the AWS C2S environment
  • Deploying Cloud Volumes ONTAP
    • Before you begin
    • Logging in to Cloud Manager
    • Planning your configuration
    • Enabling Flash Cache on Cloud Volumes ONTAP in AWS
    • Launching Cloud Volumes ONTAP in AWS
    • Launching Cloud Volumes ONTAP in Azure
    • Registering pay-as-you-go systems
    • Setting up Cloud Volumes ONTAP
  • Provisioning storage
    • Creating volumes, aggregates, and LUNs
    • Tiering inactive data to object storage
    • Using Cloud Volumes ONTAP as persistent storage
    • Encrypting volumes with NetApp Volume Encryption
    • Managing existing storage
    • Provisioning NFS volumes from the Volume View
      • Changing to the Volume View
      • Creating and mounting NFS volumes
      • Managing NFS volumes
  • Managing data across a hybrid cloud
    • Discovering and managing ONTAP clusters
    • Replicating data to and from the cloud
    • Syncing data to AWS S3
  • Administering Cloud Volumes ONTAP
    • Connecting to Cloud Volumes ONTAP
    • Updating software
    • Modifying system configurations
    • Stopping and starting systems
    • Monitoring AWS costs
    • Improving ransomware protection
    • Adding existing systems
    • Deleting systems
  • Administering Cloud Manager
    • Updating Cloud Manager
    • Backing up and restoring
    • Removing working environments
    • Editing user accounts
    • Configuring proxy settings
    • Renewing the HTTPS certificate
    • Uninstalling Cloud Manager
  • APIs and automation
    • API Developer Guide
    • Automation samples
  • Reference
    • FAQ for Cloud Central integration
    • Supported configurations for Cloud Volumes ONTAP
    • Supported regions
    • Security group rules for AWS
    • Security group rules for Azure
    • Permissions
    • Default configurations
    • User roles
    • Related links
  • Earlier versions
  • Legal notices
This documentation is for a previous release of Cloud Manager. Go to the docs for the latest release.
Known issues Edit on GitHub Request doc changes
06/03/2019 Contributors netapp-bcammett
Known issues identify problems that might prevent you from using this release of the product successfully.
There are no known issues in this release of Cloud Manager.
You can find known issues for Cloud Volumes ONTAP in the Cloud Volumes ONTAP Release Notes and for ONTAP software in general in the ONTAP Release Notes.
On this page:
    © 2019 NetApp, Inc.
    Legal
    • blog blog@
    • community community@
    • twitter twitter@
    • youtube youtube@
    Contribute
    Email your feedback
