This documentation is for a previous release of Cloud Manager.
Go to the docs for the latest release.
Changing to the Volume View
Cloud Manager provides two management views: the Storage System View for managing storage systems across a hybrid cloud and the Volume View for creating volumes in AWS without having to manage storage systems. You can switch between these views, but those instances should be rare because a single view should meet your needs.
For more information about the Volume View, see Simplified storage management using the Volume View.
Steps
In the upper right of the Cloud Manager console, click the menu, and then click View Selection.
On the View Selection page, select Storage System View, and then click Switch.
Result
Cloud Manager switches to the Volume View.
