This documentation is for a previous release of Cloud Manager.
Go to the docs for the latest release.
Before you create Cloud Volumes ONTAP systems
Before you use Cloud Manager to create and manage Cloud Volumes ONTAP systems, your Cloud Manager administrator should have prepared networking and installed and set up Cloud Manager.
The following conditions should exist before you start deploying Cloud Volumes ONTAP:
Networking requirements were met for Cloud Manager and Cloud Volumes ONTAP.
Cloud Manager has permissions to perform operations in your chosen cloud provider.
For AWS, you subscribed to the appropriate AWS Marketplace page:
If you want to deploy a PAYGO system, or enable an add-on feature: The Cloud Manager (for Cloud Volumes ONTAP) page.
If you want to deploy a BYOL system: The single node or HA page in the AWS Marketplace.
Cloud Manager was installed.
