Networking requirements for Cloud Manager
Set up your networking so that Cloud Manager can deploy Cloud Volumes ONTAP systems in AWS, Microsoft Azure, or Google Cloud Platform. The most important step is ensuring outbound internet access to various endpoints.
If your network uses a proxy server for all communication to the internet, Cloud Manager prompts you to specify the proxy during setup. You can also specify the proxy server from the Settings page. Refer to Configuring Cloud Manager to use a proxy server. |
Connection to target networks
Cloud Manager requires a network connection to the VPCs and VNets in which you want to deploy Cloud Volumes ONTAP.
For example, if you install Cloud Manager in your corporate network, then you must set up a VPN connection to the VPC or VNet in which you launch Cloud Volumes ONTAP.
Outbound internet access
Cloud Manager requires outbound internet access to deploy and manage Cloud Volumes ONTAP. Outbound internet access is also required when accessing Cloud Manager from your web browser and when running the Cloud Manager installer on a Linux host.
The following sections identify the specific endpoints.
Endpoints to manage Cloud Volumes ONTAP in AWS
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in AWS:
Endpoints | Purpose |
AWS services (amazonaws.com):
The exact endpoint depends on the region in which you deploy Cloud Volumes ONTAP. Refer to AWS documentation for details. |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in AWS. |
https://api.services.cloud.netapp.com:443 |
API requests to NetApp Cloud Central. |
https://cloud.support.netapp.com.s3.us-west-1.amazonaws.com |
Provides access to software images, manifests, and templates. |
https://cognito-idp.us-east-1.amazonaws.com |
Enables Cloud Manager to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images. |
https://kinesis.us-east-1.amazonaws.com |
Enables NetApp to stream data from audit records. |
https://cloudmanager.cloud.netapp.com |
Communication with the Cloud Manager service, which includes Cloud Central accounts. |
https://netapp-cloud-account.auth0.com |
Communication with NetApp Cloud Central for centralized user authentication. |
https://w86yt021u5.execute-api.us-east-1.amazonaws.com/production/whitelist |
Used to add your AWS account ID to the list of allowed users for Backup to S3. |
https://support.netapp.com/aods/asupmessage |
Communication with NetApp AutoSupport. |
https://support.netapp.com/svcgw |
Communication with NetApp for system licensing and support registration. |
https://ipa-signer.cloudmanager.netapp.com |
Enables Cloud Manager to generate licenses (for example, a FlexCache license for Cloud Volumes ONTAP) |
https://packages.cloud.google.com/yum |
Required to connect Cloud Volumes ONTAP systems with a Kubernetes cluster. The endpoints enable installation of NetApp Trident. |
Various third-party locations, for example:
Third-party locations are subject to change. |
During upgrades, Cloud Manager downloads the latest packages for third-party dependencies. |
Endpoints to manage Cloud Volumes ONTAP in Azure
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in Microsoft Azure:
https://management.azure.com |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in most Azure regions. |
https://management.microsoftazure.de |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure Germany regions. |
https://management.usgovcloudapi.net |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure US Gov regions. |
https://mysupport.netapp.com |
Endpoints to manage Cloud Volumes ONTAP in GCP
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in GCP:
https://www.googleapis.com |
Enables Cloud Manager to contact Google APIs for deploying and managing Cloud Volumes ONTAP in GCP. |
Endpoints accessed from your web browser
Users must access Cloud Manager from a web browser. The machine running the web browser must have connections to the following endpoints:
The Cloud Manager host |
You must enter the host's IP address from a web browser to load the Cloud Manager console. Depending on your connectivity to your cloud provider, you can use the private IP or a public IP assigned to the host:
In any case, you should secure network access by ensuring that security group rules allow access from only authorized IPs or subnets. |
https://auth0.com |
Your web browser connects to these endpoints for centralized user authentication through NetApp Cloud Central. |
https://widget.intercom.io |
For in-product chat that enables you to talk to NetApp cloud experts. |
Endpoints to install Cloud Manager on a Linux host
The Cloud Manager installer must access the following URLs during the installation process:
http://dev.mysql.com/get/mysql-community-release-el7-5.noarch.rpm
https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
https://s3.amazonaws.com/aws-cli/awscli-bundle.zip
Ports and security groups
If you deploy Cloud Manager from Cloud Central or from the marketplace images, refer to the following:
If you install Cloud Manager on an existing Linux host, see Cloud Manager host requirements.
