Cloud Manager 3.8
Networking requirements to deploy and manage Cloud Volumes ONTAP in Azure
Contributors netapp-bcammett
Set up your Azure networking so Cloud Volumes ONTAP systems can operate properly. This includes networking for the Connector and Cloud Volumes ONTAP.
Requirements for Cloud Volumes ONTAP
The following networking requirements must be met in Azure.
Outbound internet access for Cloud Volumes ONTAP
Cloud Volumes ONTAP requires outbound internet access to send messages to NetApp AutoSupport, which proactively monitors the health of your storage.
Routing and firewall policies must allow HTTP/HTTPS traffic to the following endpoints so Cloud Volumes ONTAP can send AutoSupport messages:
Security groups
You do not need to create security groups because Cloud Manager does that for you. If you need to use your own, refer to the security group rules listed below.
Number of IP addresses
Cloud Manager allocates the following number of IP addresses to Cloud Volumes ONTAP in Azure:
  • Single node: 5 IP addresses
  • HA pair: 16 IP addresses
    Note that Cloud Manager creates an SVM management LIF on HA pairs, but not on single node systems in Azure.
    Tip A LIF is an IP address associated with a physical port. An SVM management LIF is required for management tools like SnapCenter.
Connection from Cloud Volumes ONTAP to Azure Blob storage for data tiering
If you want to tier cold data to Azure Blob storage, you don't need to set up a connection between the performance tier and the capacity tier as long as Cloud Manager has the required permissions. Cloud Manager enables a VNet service endpoint for you if the Cloud Manager policy has these permissions:
"Microsoft.Network/virtualNetworks/subnets/write",
"Microsoft.Network/routeTables/join/action",
JSON
These permissions are included in the latest Cloud Manager policy.
For details about setting up data tiering, see Tiering cold data to low-cost object storage.
Connections to ONTAP systems in other networks
To replicate data between a Cloud Volumes ONTAP system in Azure and ONTAP systems in other networks, you must have a VPN connection between the Azure VNet and the other network—for example, an AWS VPC or your corporate network.
Requirements for the Connector
Set up your networking so that the Connector can manage resources and processes within your public cloud environment. The most important step is ensuring outbound internet access to various endpoints.
Tip If your network uses a proxy server for all communication to the internet, you can specify the proxy server from the Settings page. Refer to Configuring the Connector to use a proxy server.
Connections to target networks
A Connector requires a network connection to the VPCs and VNets in which you want to deploy Cloud Volumes ONTAP.
For example, if you install a Connector in your corporate network, then you must set up a VPN connection to the VPC or VNet in which you launch Cloud Volumes ONTAP.
The Connector requires outbound internet access to manage resources and processes within your public cloud environment. A Connector contacts the following endpoints when managing resources in Azure:
Endpoints Purpose
https://management.azure.com
https://login.microsoftonline.com
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in most Azure regions.
https://management.microsoftazure.de
https://login.microsoftonline.de
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure Germany regions.
https://management.usgovcloudapi.net
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure US Gov regions.
https://api.services.cloud.netapp.com:443
API requests to NetApp Cloud Central.
https://cloud.support.netapp.com.s3.us-west-1.amazonaws.com
Provides access to software images, manifests, and templates.
https://repo.cloud.support.netapp.com
Used to download Cloud Manager dependencies.
http://repo.mysql.com/
Used to download MySQL.
https://cognito-idp.us-east-1.amazonaws.com
https://cognito-identity.us-east-1.amazonaws.com
https://sts.amazonaws.com
https://cloud-support-netapp-com-accelerated.s3.amazonaws.com
Enables Cloud Manager to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images.
https://cloudmanagerinfraprod.azurecr.io
Access to software images of container components for an infrastructure that's running Docker and provides a solution for service integrations with Cloud Manager.
https://kinesis.us-east-1.amazonaws.com
Enables NetApp to stream data from audit records.
https://cloudmanager.cloud.netapp.com
Communication with the Cloud Manager service, which includes Cloud Central accounts.
https://netapp-cloud-account.auth0.com
Communication with NetApp Cloud Central for centralized user authentication.
https://mysupport.netapp.com
Communication with NetApp AutoSupport.
https://support.netapp.com/svcgw
https://support.netapp.com/ServiceGW/entitlement
https://eval.lic.netapp.com.s3.us-west-1.amazonaws.com
https://cloud-support-netapp-com.s3.us-west-1.amazonaws.com
Communication with NetApp for system licensing and support registration.
https://ipa-signer.cloudmanager.netapp.com
Enables Cloud Manager to generate licenses (for example, a FlexCache license for Cloud Volumes ONTAP)
https://packages.cloud.google.com/yum
https://github.com/NetApp/trident/releases/download/
Required to connect Cloud Volumes ONTAP systems with a Kubernetes cluster. The endpoints enable installation of NetApp Trident.
*.blob.core.windows.net
Required for HA pairs when using a proxy.
Various third-party locations, for example:
  • https://repo1.maven.org/maven2
  • https://oss.sonatype.org/content/repositories
  • https://repo.typesafe.org
Third-party locations are subject to change.
During upgrades, Cloud Manager downloads the latest packages for third-party dependencies.
While you should perform almost all tasks from the SaaS user interface, a local user interface is still available on the Connector. The machine running the web browser must have connections to the following endpoints:
Endpoints Purpose
The Connector host
You must enter the host's IP address from a web browser to load the Cloud Manager console.
Depending on your connectivity to your cloud provider, you can use the private IP or a public IP assigned to the host:
  • A private IP works if you have a VPN and direct connect access to your virtual network
  • A public IP works in any networking scenario
In any case, you should secure network access by ensuring that security group rules allow access from only authorized IPs or subnets.
https://auth0.com
https://cdn.auth0.com
https://services.cloud.netapp.com
Your web browser connects to these endpoints for centralized user authentication through NetApp Cloud Central.
https://widget.intercom.io
For in-product chat that enables you to talk to NetApp cloud experts.
Security group rules for Cloud Volumes ONTAP
Cloud Manager creates Azure security groups that include the inbound and outbound rules that Cloud Volumes ONTAP needs to operate successfully. You might want to refer to the ports for testing purposes or if you prefer your to use own security groups.
The security group for Cloud Volumes ONTAP requires both inbound and outbound rules.
Inbound rules for single node systems
The rules listed below allow traffic, unless the description notes that it blocks specific inbound traffic.
Priority and name Port and protocol Source and destination Description
1000
inbound_ssh
22
TCP
Any to Any
SSH access to the IP address of the cluster management LIF or a node management LIF
1001
inbound_http
80
TCP
Any to Any
HTTP access to the System Manager web console using the IP address of the cluster management LIF
1002
inbound_111_tcp
111
TCP
Any to Any
Remote procedure call for NFS
1003
inbound_111_udp
111
UDP
Any to Any
1004
inbound_139
139
TCP
Any to Any
NetBIOS service session for CIFS
1005
inbound_161-162 _tcp
161-162
TCP
Any to Any
Simple network management protocol
1006
inbound_161-162 _udp
161-162
UDP
Any to Any
1007
inbound_443
443
TCP
Any to Any
HTTPS access to the System Manager web console using the IP address of the cluster management LIF
1008
inbound_445
445
TCP
Any to Any
Microsoft SMB/CIFS over TCP with NetBIOS framing
1009
inbound_635_tcp
635
TCP
Any to Any
NFS mount
1010
inbound_635_udp
635
UDP
Any to Any
NFS mount
1011
inbound_749
749
TCP
Any to Any
Kerberos
1012
inbound_2049_tcp
2049
TCP
Any to Any
NFS server daemon
1013
inbound_2049_udp
2049
UDP
Any to Any
NFS server daemon
1014
inbound_3260
3260
TCP
Any to Any
iSCSI access through the iSCSI data LIF
1015
inbound_4045-4046_tcp
4045-4046
TCP
Any to Any
NFS lock daemon and network status monitor
1016
inbound_4045-4046_udp
4045-4046
UDP
Any to Any
1017
inbound_10000
10000
TCP
Any to Any
Backup using NDMP
1018
inbound_11104-11105
11104-11105
TCP
Any to Any
SnapMirror data transfer
3000
inbound_deny _all_tcp
Any port
TCP
Any to Any
Block all other TCP inbound traffic
3001
inbound_deny _all_udp
Any port
UDP
Any to Any
Block all other UDP inbound traffic
65000
AllowVnetInBound
Any port
Any protocol
VirtualNetwork to VirtualNetwork
Inbound traffic from within the VNet
65001
AllowAzureLoad BalancerInBound
Any port
Any protocol
AzureLoadBalancer to Any
Data traffic from the Azure Standard Load Balancer
65500
DenyAllInBound
Any port
Any protocol
Any to Any
Block all other inbound traffic
Inbound rules for HA systems
Note HA systems have less inbound rules than single node systems because inbound data traffic goes through the Azure Standard Load Balancer. Because of this, traffic from the Load Balancer should be open, as shown in the "AllowAzureLoadBalancerInBound" rule.
100
inbound_443
443
Any protocol
Any to Any
101
inbound_111_tcp
111
Any protocol
Any to Any
102
inbound_2049_tcp
2049
Any protocol
Any to Any
NFS server daemon
111
inbound_ssh
22
Any protocol
Any to Any
121
inbound_53
53
Any protocol
Any to Any
DNS and CIFS
65000
AllowVnetInBound
Any port
Any protocol
65001
Any port
Any protocol
65500
DenyAllInBound
Any port
Any protocol
Any to Any
Outbound rules
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
Port Protocol Purpose
All
All TCP
All outbound traffic
All
All UDP
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
Note The source is the interface (IP address) on the Cloud Volumes ONTAP system.
Service Port Protocol Source Destination Purpose
Active Directory
88
TCP
Node management LIF
Active Directory forest
Kerberos V authentication
137
UDP
Node management LIF
NetBIOS name service
138
UDP
Node management LIF
NetBIOS datagram service
139
TCP
Node management LIF
389
TCP & UDP
Node management LIF
LDAP
445
TCP
Node management LIF
464
TCP
Node management LIF
Kerberos V change & set password (SET_CHANGE)
464
UDP
Node management LIF
Kerberos key administration
749
TCP
Node management LIF
Kerberos V change & set Password (RPCSEC_GSS)
88
TCP
Data LIF (NFS, CIFS, iSCSI)
137
UDP
Data LIF (NFS, CIFS)
138
UDP
139
TCP
389
TCP & UDP
LDAP
445
TCP
464
TCP
464
UDP
749
TCP
Kerberos V change & set password (RPCSEC_GSS)
DHCP
68
UDP
Node management LIF
DHCP
DHCP client for first-time setup
DHCPS
67
UDP
Node management LIF
DHCP
DHCP server
DNS
53
UDP
Node management LIF and data LIF (NFS, CIFS)
DNS
DNS
NDMP
18600–18699
TCP
Node management LIF
Destination servers
NDMP copy
SMTP
25
TCP
Node management LIF
Mail server
SMTP alerts, can be used for AutoSupport
SNMP
161
TCP
Node management LIF
Monitor server
Monitoring by SNMP traps
161
UDP
Node management LIF
Monitor server
162
TCP
Node management LIF
Monitor server
162
UDP
Node management LIF
Monitor server
SnapMirror
11104
TCP
Intercluster LIF
ONTAP intercluster LIFs
Management of intercluster communication sessions for SnapMirror
11105
TCP
Intercluster LIF
Syslog
514
UDP
Node management LIF
Syslog server
Syslog forward messages
Security group rules for the Connector
The security group for the Connector requires both inbound and outbound rules.
Inbound rules
The source for inbound rules in the predefined security group is 0.0.0.0/0.
22
SSH
Provides SSH access to the Connector host
80
HTTP
Provides HTTP access from client web browsers to the local user interface
443
HTTPS
Provides HTTPS access from client web browsers to the local user interface
Outbound rules
The predefined security group for the Connector opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the Connector includes the following outbound rules.
All
All TCP
All
All UDP
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the Connector.
Note The source IP address is the Connector host.
Service Port Protocol Destination Purpose
Active Directory
88
TCP
139
TCP
389
TCP
LDAP
445
TCP
464
TCP
749
TCP
Active Directory Kerberos V change & set password (RPCSEC_GSS)
137
UDP
138
UDP
464
UDP
API calls and AutoSupport
443
HTTPS
Outbound internet and ONTAP cluster management LIF
API calls to AWS and ONTAP, and sending AutoSupport messages to NetApp
API calls
3000
TCP
API calls to ONTAP
DNS
53
UDP
DNS
Used for DNS resolve by Cloud Manager
