Preparing the source and target
Prepare to sync data by verifying that your source and target are supported and setup.
Supported sync relationships
Cloud Sync enables you to sync data from a source to a target (this is called a sync relationship). You should understand the supported relationships before you get started.
Source location | Supported target locations |
AWS EFS |
AWS S3 |
Azure Blob |
Azure NetApp Files (NFS) |
Azure NetApp Files (SMB) |
Cloud Volumes ONTAP (NFS) |
Cloud Volumes ONTAP (SMB) |
Cloud Volumes Service (NFS) |
Cloud Volumes Service (SMB) |
Google Cloud Storage |
IBM Cloud Object Storage |
NFS server |
On-prem ONTAP cluster (NFS) |
On-prem ONTAP cluster (SMB) |
ONTAP S3 Storage |
SMB server |
StorageGRID |
Notes:
You can choose a specific Azure Blob storage tier when a Blob container is the target:
Hot storage
Cool storage
You can choose a specific S3 storage class when AWS S3 is the target:
Standard (this is the default class)
Intelligent-Tiering
Standard-Infrequent Access
One Zone-Infrequent Access
Glacier
Glacier Deep Archive
Networking for the source and target
The source and target must have a network connection to the data broker.
For example, if an NFS server is in your data center and the data broker is in AWS, then you need a network connection (VPN or Direct Connect) from your network to the VPC.
NetApp recommends configuring the source, target, and data broker to use a Network Time Protocol (NTP) service. The time difference between the three components should not exceed 5 minutes.
Source and target requirements
Verify that your source and targets meet the following requirements.
AWS S3 bucket requirements
Make sure that your AWS S3 bucket meets the following requirements.
Supported data broker locations for AWS S3
Sync relationships that include S3 storage require a data broker deployed in AWS or on your premises. In either case, Cloud Sync prompts you to associate the data broker with an AWS account during installation.
Supported AWS regions
All regions are supported except for the China and GovCloud (US) regions.
Permissions required for S3 buckets in other AWS accounts
When setting up a sync relationship, you can specify an S3 bucket that resides in an AWS account that isn't associated with the data broker.
The permissions included in this JSON file must be applied to that S3 bucket so the data broker can access it. These permissions enable the data broker to copy data to and from the bucket and to list the objects in the bucket.
Note the following about the permissions included in the JSON file:
<BucketName> is the name of the bucket that resides in the AWS account that isn't associated with the data broker.
<RoleARN> should be replaced with one of the following:
If the data broker was manually installed on a Linux host, RoleARN should be the ARN of the AWS user for which you provided AWS credentials when deploying the data broker.
If the data broker was deployed in AWS using the CloudFormation template, RoleARN should be the ARN of the IAM role created by the template.
You can find the Role ARN by going to the EC2 console, selecting the data broker instance, and clicking the IAM role from the Description tab. You should then see the Summary page in the IAM console that contains the Role ARN.
Azure Blob storage requirements
Make sure that your Azure Blob storage meets the following requirements.
Supported data broker locations for Azure Blob
The data broker can reside in any location when a sync relationship includes Azure Blob storage.
Supported Azure regions
All regions are supported except for the China, US Gov, and US DoD regions.
Connection string required for relationships that include Azure Blob and NFS/SMB
When creating a sync relationship between an Azure Blob container and an NFS or SMB server, you need to provide Cloud Sync with the storage account connection string:
If you want to sync data between two Azure Blob containers, then the connection string must include a shared access signature (SAS). You also have the option to use a SAS when syncing between a Blob container and an NFS or SMB server.
The SAS must allow access to the Blob service and all resource types (Service, Container, and Object). The SAS must also include the following permissions:
For the source Blob container: Read and List
For the target Blob container: Read, Write, List, Add, and Create
Azure NetApp Files requirement
Use the Premium or Ultra service level when you sync data to or from Azure NetApp Files. You might experience failures and performance issues if the disk service level is Standard.
Consult a solutions architect if you need help determining the right service level. The volume size and volume tier determines the throughput that you can get. |
Google Cloud Storage bucket requirements
Make sure that your Google Cloud Storage bucket meets the following requirements.
Supported data broker locations for Google Cloud Storage
Sync relationships that include Google Cloud Storage require a data broker deployed in GCP or on your premises. Cloud Sync guides you through the data broker installation process when you create a sync relationship.
Supported GCP regions
All regions are supported.
NFS server requirements
The NFS server can be a NetApp system or a non-NetApp system.
The file server must allow the data broker host to access the exports.
NFS versions 3, 4.0, 4.1, and 4.2 are supported.
The desired version must be enabled on the server.
If you want to sync NFS data from an ONTAP system, ensure that access to the NFS export list for an SVM is enabled (vserver nfs modify -vserver svm_name -showmount enabled).
The default setting for showmount is enabled starting with ONTAP 9.2.
ONTAP S3 Storage requirements
ONTAP 9.7 supports the Amazon Simple Storage Service (Amazon S3) as a public preview. Learn more about ONTAP support for Amazon S3.
When you set up a sync relationship that includes ONTAP S3 Storage, you'll need to provide the following:
The IP address of the LIF that's connected to ONTAP S3
The access key and secret key that ONTAP is configured to use
SMB server requirements
The SMB server can be a NetApp system or a non-NetApp system.
SMB versions 1.0, 2.0, 2.1, 3.0 and 3.11 are supported.
Grant the "Administrators" group with "Full Control" permissions to the source and target folders.
If you don’t grant this permission, then the data broker might not have sufficient permissions to get the ACLs on a file or directory. If this occurs, you’ll receive the following error: "getxattr error 95"
SMB limitation for hidden directories and files
An SMB limitation affects hidden directories and files when syncing data between SMB servers. If any of the directories or files on the source SMB server were hidden through Windows, the hidden attribute isn't copied to the target SMB server.
SMB sync behavior due to case-insensitivity limitation
The SMB protocol is case-insensitive, which means uppercase and lowercase letters are treated as being the same. This behavior can result in overwritten files and directory copy errors, if a sync relationship includes an SMB server and data already exists on the target.
For example, let's say that there's a file named "a" on the source and a file named "A" on the target. When Cloud Sync copies the file named "a" to the target, file "A" is overwritten by file "a" from the source.
In the case of directories, let's say that there's a directory named "b" on the source and a directory named "B" on the target. When Cloud Sync tries to copy the directory named "b" to the target, Cloud Sync receives an error that says the directory already exists. As a result, Cloud Sync always fails to copy the directory named “b.”
The best way to avoid this limitation is to ensure that you sync data to an empty directory.
Permissions for a SnapMirror destination
If the source for a sync relationship is a SnapMirror destination (which is read-only), "read/list" permissions are sufficient to sync data from the source to a target.
