Go to the docs for the latest release.
Discovering ONTAP clusters
Cloud Manager can discover the ONTAP clusters in your on-premises environment, in a NetApp Private Storage configuration, and in the IBM Cloud. Discovering an ONTAP cluster enables you to provision storage, replicate data, back up data, and tier cold data from an on-prem cluster to the cloud.
A Connector installed in a cloud provider or on your premises.
If you want to tier cold data to the cloud, then you should review requirements for the Connector based on where you plan to tier cold data.
The cluster management IP address and the password for the admin user account to add the cluster to Cloud Manager.
Cloud Manager discovers ONTAP clusters using HTTPS. If you use custom firewall policies, they must meet the following requirements:
The Connector host must allow outbound HTTPS access through port 443.
If the Connector is in the cloud, all outbound communication is allowed by the predefined security group.
The ONTAP cluster must allow inbound HTTPS access through port 443.
The default "mgmt" firewall policy allows inbound HTTPS access from all IP addresses. If you modified this default policy, or if you created your own firewall policy, you must associate the HTTPS protocol with that policy and enable access from the Connector host.
On the Working Environments page, click Add Working Environment and select On-Premises ONTAP.
If you’re prompted, create a Connector.
Refer to the links above for more details.
On the ONTAP Cluster Details page, enter the cluster management IP address, the password for the admin user account, and the location of the cluster.
On the Details page, enter a name and description for the working environment, and then click Go.
Cloud Manager discovers the cluster. You can now create volumes, replicate data to and from the cluster, set up data tiering to the cloud, back up volumes to the cloud, and launch System Manager to perform advanced tasks.
