Go to the docs for the latest release.
Creating and managing volumes for Azure NetApp Files
After you set up your working environment, you can create and manage Azure NetApp Files accounts, capacity pools, volumes, and snapshots.
Creating volumes
You can create NFS or SMB volumes in a new or existing Azure NetApp Files account.
Open the Azure NetApp Files working environment.
Click Add New Volume.
Provide the required information on each page:
Azure NetApp Files Account: Choose an existing Azure NetApp Files account or create a new account.
Capacity Pool: Select an existing capacity pool or create a new capacity pool.
If you create a new capacity pool, you need to specify a size and select a service level.
The minimum size for the capacity pool is 4 TB. You can specify a size in multiples of 4 TB.
Details & Tags: Enter a volume name and size, the VNet and subnet where the volume should reside, and optionally specify tags for the volume.
Protocol: Choose the NFS or SMB protocol and enter the required information.
Here’s an example of details for NFS.
Here’s an example of details for SMB. You’ll need to provide Active Directory information when you set up your first SMB volume.
Click Add Volume.
Mounting volumes
Access mounting instructions from within Cloud Manager so you can mount the volume to a host.
Open the working environment.
Hover over the volume and select Mount the volume.
Follow the instructions to mount the volume.
Editing a volume’s size and tags
After you create a volume, you can modify its size and tags at any time.
Hover over the volume and select Edit.
Modify the size and tags as needed.
Click Apply.
Managing Snapshot copies
Snapshot copies provide a point-in-time copy of your volume. Create Snapshot copies, restore the data to a new volume, and delete Snapshot copies.
Hover over the volume and choose one of the available options to manage Snapshot copies:
Create a Snapshot copy
Restore to a new volume
Delete a Snapshot copy
Follow the prompts to complete the selected action.
Deleting volumes
Delete the volumes that you no longer need.
Hover over the volume and click Delete.
Confirm that you want to delete the volume.
Removing Azure NetApp Files
This action removes Azure NetApp Files from Cloud Manager. It doesn’t delete your Azure NetApp Files account or volumes. You can add Azure NetApp Files back to Cloud Manager at any time.
At the top right of the page, select the actions menu and click Remove Azure NetApp Files.
Click Remove to confirm.
