Adding a dashboard from User Preferences
You might want to display a dashboard group of reports in a tab for easy access. You can add the tab from User Preferences.
Steps
Open the OnCommand Insight Reporting Portal.
At the upper right, click the Person icon to show a drop-down menu.
Select My Preferences.
In the Set preferences view, click the Portal Tabs tab.
In the Portal Tabs tab, click the Add link.
In the Public Folders and Dashboard folder, locate the dashboard that you want as a tab and check it.
Click the arrow to move it to the Selected Entries box, and click OK.
