OnCommand Insight
Welcome to OnCommand Insight reporting
OnCommand Insight reporting is a business intelligence tool that enables you to view pre-defined reports or create custom reports. OnCommand Insight reporting generates reports from the Data Warehouse (DWH) data.
With OnCommand Insight reporting you can perform the following tasks:
  • Run a pre-defined report
  • Create a custom report
  • Customize the report format and delivery method
  • Schedule reports to run automatically
  • Email reports
  • Use colors to represent thresholds on data
Pre-defined reports are the standard OnCommand Insight reports. This guide describes the pre-defined reports that are available with all of the product licenses.
