Certain special characters do not work with reporting search
Issue
Using the special characters % and _ while searching within a report causes the operation to fail.
Corrective action
If you search for a string that contains % or _, you should use a double backslash before the specified character.
For example, to find a string containing S_10, you should enter S\\_10.
